Old 06-19-2009, 03:21 PM   #1 (permalink)
Access front Power Block 2005 Elise
From previous posts I understand there is a power block I can tie into up in the front drivers side of the car; however, I have been unable to locate it. Any help on accessing it would be appreciated. I want to create a second fuse block for accessories.
Can I access it from under the Clam?( I have the Clam off) or from underneath the dash? or do I have to remove the dash to access.
Thanks
PMcTighe is offline   Reply With Quote
Old 06-19-2009, 03:39 PM   #2 (permalink)
Photochopper
chapster5's Avatar
Images: 6
Isnt it under one of the access panels on the front clam?
http://www.chuforiagraphics.com/
FOR ALL YOUR GRAPHICS NEEDS CONTACT KEITH ON:
sweetdaddydelicious (AT) hotmail (DOT) com
chapster5 is offline   Reply With Quote
Old 06-19-2009, 03:53 PM   #3 (permalink)
Service animal
dbisbee's Avatar
Yes it is on the right hand side. You will need to remove the dash. The last picture in this post Dash removal and on the far left you can see a large wire above the aluminum. That is it. Depending on what you want to do there are easier but less amperage places to get 12v in the dash.
The word "PASSION" should aways be uppercase.
#349 '05 AS Elise Touring, Hardtop, Starshield, Plinth delete, GPS Garmin 680, V1, V1 mirror, Leather console, Multivex, Alpine CDA9887, JL stealthbox, Focals, Alpine PDX 5, HID, RAC Monolites, R888's, Stage II, Front Slotted rotors, R4-S pads, Stebel nautilus, TitanQR and Odyssey 925 now with bracket.
dbisbee is offline   Reply With Quote
Old 06-20-2009, 03:18 AM   #4 (permalink)
Do tell, what other options other than splicing into the fuze block are there?
Old 06-21-2009, 01:23 AM   #5 (permalink)
Anybody?
Old 06-21-2009, 05:02 AM   #6 (permalink)
Alarmed & Dangerous
TheViper's Avatar
To install a fuse box up front this would be the way to go for relatively unrestricted power. If the amperage needed is small, there are other options, such as tapping off an existing fuse. If you don't have driving lamps installed there is a unused fuse C5 under the passenger side dash, plus 3 unwired fuse fuse locations in the same block.
Cheers,
