Old 07-22-2009, 05:46 PM   #1 (permalink)
Alarmed & Dangerous
TheViper's Avatar
Alarm Emergency Overide
NOW AVAILABLE; Alarm/Immobilizer/CDL Emergency Overide
Trying to get an idea as to interest and demand before I produce.
As some of us have unfortunately found out, that if the car is locked with the alarm wireless remote, it can’t then be opened with the key. If the wireless remote is lost, or should fail, because of low battery, a defect, or loss of synchronization or programming, the result is being locked out of the car and the inability to disarm the alarm / immobilizer.
I may be putting together a kit that will allow the capability of arming and disarming of the alarm / immobilizer, including the unlocking of the doors, all from the outside of the car without using a operating wireless remote.
An additional benefit is that should you gain entry without disarming the alarm / immobilizer and the system goes into an alarm condition with the siren sounding and the lights flashing, there is no need to try to remember and enter the PIN to turn off the alarm, instead, simply use this new device.
Cheers,
Old 07-22-2009, 05:55 PM   #2 (permalink)
G-200 Driver
kestrel74's Avatar
I'm sure the DD people would be quite interested ! I almost never use my alarm, as I am usually by my car when I'm out....other than that, I'd go for it.
Old 07-22-2009, 06:16 PM   #3 (permalink)
insert clever title here
MattG's Avatar
Images: 11
Nice idea, I'd be interested!
Old 07-22-2009, 10:07 PM   #4 (permalink)
glb
Unattractive Nuisance
glb's Avatar
I might be interested
Old 07-22-2009, 11:03 PM   #5 (permalink)
Chris Mackey's Avatar
Interested.
2006 Elise, Ardent Red, Black Pack, LSS wheels, shocks and springs.
ChuforiaGraffix.com SDD Lives On! SweetDaddyDelicious(at)hotmail(dot)com
Chris Mackey is offline   Reply With Quote
Old 07-23-2009, 04:01 AM   #6 (permalink)
Exige Cup 255
Noel's Avatar
Location: 33.87°S 151.21°E Car: ロータス MKII エキシージ Type: Komo-Tec S300
I will buy one if it works. More than interested.
Noel is offline   Reply With Quote
Old 07-23-2009, 05:42 AM   #7 (permalink)
Denuo Volatilis
...m...'s Avatar
...sounds like a good idea...
Old 07-23-2009, 05:56 AM   #8 (permalink)
Vexige's Avatar
Interested
Vexige is offline   Reply With Quote
Old 07-27-2009, 07:44 AM   #9 (permalink)
Alarmed & Dangerous
TheViper's Avatar
Here is some more details on this project
To address this problem I have an OEM integrated system kit that will allow the capability of arming and disarming of the alarm / immobilizer, including the unlocking of the doors, all from the outside of the car without using a operating wireless remote.
The basis of the system is a small coded electronic key that attaches to your key ring and a receptacle that would be mounted externally in a location that makes it almost undetectable.
On the Elise there are no permanent modifications or drilling to the car necessary. The installation would entail, easy mounting of the receptacle, and routing of just two wires, one to the alarm module and one locally to ground. I have simplified the routing of the single wire from the alarm module so that virtually no disassembly is required. Location of the receptacle on Elise models is on the exterior of the car adjacent to the center brake light, under the rear window overhang where it is concealed. On the Exige models that have it, the mounting would be inside the rectangular hole above the license plate. A tiny hole, for wiring, would have to be drilled in the trunk floor corresponding to the other side of the hole. On Exige models without the rectangular hole it is up to the individual owner where the receptacle is mounted. All components, including 1 Touch Key & 1 Receptacle in a water tight enclosure, wiring, connectors and detailed instructions are supplied; you need only to supply some silicone adhesive.
The kit includes OEM Cobra components that were developed to be integrated into the Cobra 8186 that is used in all 2005 to 2007 Elise and Exige models. This system is totally secure, as each key is electronically coded to your car's system, just like the wireless remote. A key from another person's car will not work on yours. Lotus decided not to include the touch key, however I believe this is very desirable feature to have.
I am endeavoring to keep the price below $100, at least for the initial introduction, which should be soon.
Cheers,
Old 07-27-2009, 07:48 AM   #10 (permalink)
On the Elise there are no permanent modifications or drilling to the car necessary. The installation would entail, easy mounting of the receptacle, and routing of just two wires, one to the alarm module and one locally to ground. I have simplified the routing of the single wire from the alarm module so that virtually no disassembly is required. Location of the receptacle on Elise models is on the exterior of the car adjacent to the center brake light, under the rear window overhang where it is concealed. On the Exige models that have it, the mounting would be inside the rectangular hole above the license plate. A tiny hole, for wiring, would have to be drilled in the trunk floor corresponding to the other side of the hole. On Exige models without the rectangular hole it is up to the individual owner where the receptacle is mounted. All components, including 1 Touch Key & 1 Receptacle in a water tight enclosure, wiring, connectors and detailed instructions are supplied; you need only to supply some silicone adhesive.The kit includes OEM Cobra components that were developed to be integrated into the Cobra 8186 that is used in all 2005 to 2007 Elise and Exige models. Lotus decided not to include this feature, however I believe it is desirable to have.
I am endeavoring to keep the price below $100, at least for the initial introduction, but am not quite ready for introduction yet.
Cheers,
I'm so there! anytime I can prevent myself from being locked out of my own car, I'm all for it!
2005 Magnetic Blue Elise - "the Lotus" (original I know)
2001 Jeep Wrangler - "soul crusher".
If you dont GET it after you drive it, then you dont GET it - serpent
mrcarcrazy is offline   Reply With Quote
Old 07-27-2009, 08:25 AM   #11 (permalink)
tesprit's Avatar
I've been helping The Viper with some of the detail information needed to get this upgrade rolling and this is a really great product. The best part is that these are genuine OEM Cobra alarm parts and the touch key is coded to your car just like the standard remotes, so it is secure from anyone else trying to use their touch key to try to gain entry to your car. Lotus should have installed this part of the Cobra alarm right from the factory and I can't wait for these to go on sale so I can upgrade my alarm.
Old 07-27-2009, 09:39 AM   #12 (permalink)
s4norice's Avatar
I am in...
05 Lotus Elise
06 Infiniti FX35
s4norice is offline   Reply With Quote
Old 07-27-2009, 09:52 AM   #13 (permalink)
A7594217's Avatar
Yeah. My alarm goes off so I have been manually locking the doors so the alarm does not arm. It sucks!
05 GG Elise-BWR S/C-Nitrons-Intake-Exhaust-Test Pipe-Cf Scoops-Cf Lip-Cf Diffuser-Piaa Wheels-And all the little stuff
A7594217 is offline   Reply With Quote
Old 07-27-2009, 01:23 PM   #14 (permalink)
Alarmed & Dangerous
TheViper's Avatar
Here is the Touch Key Receptacle in it's waterproof enclosure.
Old 07-27-2009, 01:38 PM   #15 (permalink)
This looks cool. If it doesn't take an engineering degree to install, I'd be interested.
2005 Saffron Elise :: Pro-1 Exhaust, Cup Car Airbox w/ TRD filter, Manly Engine Mounts, Shift-I, Bollock, 1/4-turn fasteners, Esta C/F Decklid, de-stuffification, other stuff...
cobrabyte is offline   Reply With Quote
Old 07-27-2009, 02:00 PM   #16 (permalink)
Alarmed & Dangerous
TheViper's Avatar
One wire from the alarm module to the outside of the rear window. Wire is hidden under trim panels. One ground wire terminated inches from the receptacle. Programming is as simple as first entering your PIN and then inserting the key into the receptacle.
Cheers,
Old 07-28-2009, 04:19 AM   #17 (permalink)
Why not just use the mod I did a while back?
Emergency Unlock Switch – Easy Mod Pictorial
Old 07-28-2009, 04:26 AM   #18 (permalink)
Alarmed & Dangerous
TheViper's Avatar
Because in addition to unlocking the doors, it can be used to disarm the alarm and immobilizer without a PIN, all from outside of the vehicle, the alarm will not go off. Additionally, the car doors can be locked manually with the car key, while still arming the alarm /immobilizer, an option which is not available normally.
Old 07-28-2009, 06:25 AM   #19 (permalink)
ishur's Avatar
Definitely interested. Hard to tell from the pictures--what is the size of the electronic key, especially thickness?
ishur is offline   Reply With Quote
Old 07-28-2009, 06:38 AM   #20 (permalink)
Alarmed & Dangerous
TheViper's Avatar
The diameter of the enclosure that the receptacle is in measures 1-1/8" and the depth is 1-1/4". Here is a photo of the completed installation.
