Old 12-21-2006, 08:26 AM   #1 (permalink)
femagaca's Avatar
Unhappy Alarm problem
my alarm went of last night for no reason, now when i try to lock the car with the alarm control there is a continious beep, does any one know what's the problem or how to fix it. thanks
femagaca is offline   Reply With Quote
Old 12-21-2006, 08:38 AM   #2 (permalink)
Ian
Certified Fun Stopper
Ian's Avatar
Sounds like something is open. I would start by checking the boot lid and the front access covers. Also make sure your interior light is in the down position.
'06 Exige; Polar Blue; Track/Touring/Stage II/LSD-TC
Old 12-21-2006, 09:19 AM   #3 (permalink)
RegGuy's Avatar
I've had three issues with the alarm. One was the light inside, I bumped it and it was on. You get the beeps with that. The second common one was the alarm going off when leaves and rain hit the windshield. To eliminate that I set the alarm then hit the small button twice. That turns the internal sensor off. The other problem was kinda like what you are having. I solved it by starting the car. After starting the car the alarm reset or something.
Also make sure your passenger door is closed all the way as well as the boot and front access panels.
Good luck. If all else fails, rtfm and count the codes it blinks that'll tell you what the problem is.
My car can be scary quiet...Ford Fusion Hybrid...A technological wonder. Power to spare, high mpg for the environment.
RegGuy is offline   Reply With Quote
Old 12-21-2006, 09:32 AM   #4 (permalink)
femagaca's Avatar
Gracias. I had started the car and did not work, i opend and closed the doors and the boot lid, put the ligth in the down position, and one of those did it. Thanks again
Old 12-24-2006, 12:04 PM   #5 (permalink)
My new wheels
What are the front access panels? I tried everything above and it's still not working
I'm having the same problem. I lock the doors, the lights flash and then a few seconds later I get a continuous beep noise.
I just got my car back Friday after having the front clam replaced. Could they have done something to it? I locked the car and set the alarm no problem Friday night and Saturday night ... today it's jacked.
Crow331 is offline   Reply With Quote
Old 12-24-2006, 12:07 PM   #6 (permalink)
Ian
Ian's Avatar
The front access panels are the triangular? shaped panels on the front clam that are removed with the supplied torx. (Where the fusebox etc. are). They definitely could have replaced them incorrectly when replacing the clam.
Old 12-24-2006, 12:17 PM   #7 (permalink)
My new wheels
Thanks, I think it was the one on the right side away from the fuse box. I just gave it a little push down, I didn't hear anything snap into place or anything, but the beeping stopped. I engaged and disengaged the alarm a few times and it seems to be fixed. Thanks!
If I want to open one up, how do they come off exactly? Is there a release button or do just give them a tug? I don't see anything in the manual about how to take it off
Old 12-24-2006, 12:31 PM   #8 (permalink)
Alarmed & Dangerous
TheViper's Avatar
They are secured by 2 pins on the inside (center of the car) edge that have to be slid out in the direction of the side of the car. There is also a retaining tab on the front edge. Hope this helps.
Old 12-24-2006, 01:54 PM   #9 (permalink)
Adminatrix
RacyTracy's Avatar
Images: 2
You'll need one of the tools that came with your car.....don't just pull!!!
RacyTracy is online now   Reply With Quote
Old 12-25-2006, 04:00 PM   #10 (permalink)
I'm Lovin' It!
ChrisB's Avatar
Images: 1
Loosen the screw on the outside point, then pull the panel towards the side of the car while wiggling it a little. When reinstalling it, make sure that the leading edge is properly slotted into the radiator grill.
Old 12-25-2006, 05:44 PM   #11 (permalink)
Drives just like it looks
PedalPounder's Avatar
Make sure the interior light is in the down position. That will fix it.
PedalPounder is offline   Reply With Quote
Old 12-26-2006, 12:13 PM   #12 (permalink)
My new wheels
I was still having problems with it. I ended up finding the page in the owner's manual on how to take the panel off .... not sure what I did differently than they did, but I reinstalled it and it stopped. Hopefully it's permanently fixed now
Thanks again and thanks for the tip on the allen wrench.
Old 12-26-2006, 04:54 PM   #13 (permalink)
e-Lise's Avatar
My alarm went off when I was starting the car a couple weeks ago - I couldn't shut it off unless the special code was entered by switching on and off the ignition. I tried replacing batteries in the fob - no luck. To make a long story short, the whole alarm system had to be replaced.
e-Lise is offline   Reply With Quote
Old 12-26-2006, 09:58 PM   #14 (permalink)
My new wheels
Ugh ... all day it was fine ... just got home 10 pm and it's back, the buzzing. Give a slight push to the right corner of right access panel and it stops .... any suggestions?? Is there a contact point that it needs to hit or something?
I'll have to take a closer look at in the morning
Old 12-26-2006, 11:03 PM   #15 (permalink)
is the interior light in the down position??
Old 12-27-2006, 08:19 AM   #16 (permalink)
My new wheels
Yes, the light is down. It's not the light.
The problem is the right front access panel which is why the buzzing stops when I give it a little press down.
Old 12-27-2006, 08:23 AM   #17 (permalink)
It's a Lotus
LARRY's Avatar
femagaca - What's it like to drive a Lotus in the Baja?
Lotus body work and maintenance at Lotus Talk sponsor Specialty Car Craft (310.838.5551)
See more of Larry's Photoblog at http://www.larrysphotoblog.net/
LARRY is offline   Reply With Quote
Old 01-28-2007, 06:48 PM   #18 (permalink)
Alarmed & Dangerous
TheViper's Avatar
Glue a thin spacer to the inside of the access panel where it contacts the switch.
Old 01-28-2007, 07:04 PM   #19 (permalink)
femagaca's Avatar
there are some nice roads not top condition and short drives, but since thery are the roads that everybody uses there could be a lot of trafic, unless you go like 300 miles south of the border. I usally ride around san diego and the toll from tijuana to ensenada thet is a fast ride if you know where police are. there is a road thet i want to do on the elise up copper cayon in chihuahua i did it last year in my ducati and it was the best just paved awsom curves, no police and no traffic. But what you get most of in mexico are looks a questions about the car what's that? etc
Old 01-29-2007, 05:09 PM   #20 (permalink)
My new wheels
Yeah, that's basically what I ended up doing ... when I take the car in for service I'll have them take a look, but it's good enough for now
