Old 10-11-2008, 05:27 PM   #1 (permalink)
There's your car dude!
Monsi's Avatar
Images: 21
Backup camera help
so I searched and didnt find what I was looking for... but I am trying to figure out how to get the wire from the camera on the rear license plate into the boot...
I wanted to ask before I start taking my new car apart
Dude, there's my car!
Monsi is offline   Reply With Quote
Old 10-11-2008, 05:35 PM   #2 (permalink)
K2S
K2S's Avatar
i pulled my wire in between the two license plate lights
K2S is offline   Reply With Quote
Old 10-11-2008, 05:39 PM   #3 (permalink)
Monsi's Avatar
Images: 21
in between the body and the back plate?
did you take off the back plate?(butt plate/whatever its called)
Old 10-11-2008, 06:11 PM   #4 (permalink)
XViperDude's Avatar
I loosened up one of the license plate lights and slid the wire up through there.
2007 Phantom Black Exige S
XViperDude is offline   Reply With Quote
Old 10-11-2008, 06:51 PM   #5 (permalink)
Monsi's Avatar
Images: 21
ahh will give that a try... is there a specific hole in the boot you used?
I tried pulling off the butt plate but I forgot to bring all my metric wrenches so will have to wait till I go home
Old 10-11-2008, 11:17 PM   #6 (permalink)
Keep it simple and real
Lotusmotion's Avatar
Monsi, I just finished installing a Boyo VTL420 and a 3.5 inch monitor in my Exige.
After searching / reviewing all the postings (there are many) about back-up cameras, I chose to do the following:
- I drilled a 1/4 inch hole in the trunk floor, about 1 inch away from the back seam) above the rectangular opening above the license plate area. I installed a rubber grommet and pulled the camera wire through it. The wire is routed along the trunl heading toward the battery area.
- I drilled another 1/4 hole in between the battery cable grommet and rear lights harness grommet, located at the front driver's side of the trunk. Again, I installed a grommet there and pulled the camera wire through that hole into the engine bay.
- From there, I routed the wire (with ties) under the airbox , to the driver's corner of the firewall, down and across to the center, and routed the wire through the shifter cable opening / channel.
- I ran the wire under the center console, up through the floor divider, around the back of the passnger footwell and into the passenger side dash panel (below the vent). There, I connected the camera wires up to the monitor wires, protected them wire convoluted wire covering, tucked the bundle into the dash area, and closed up the panel.
- I removed the mirror (had a S111 Micro Mirror) and installed the monitor in its place. The monitor cable, between the dash and monitor, is held in place by tucking the cable into the header just behind the windshield and crevice where the windshield meets the A-pillar.
- I wired the camera so it is always on 100% of the time.
- Total parts = $160.
- Install looks factory.
'06 Exige - Ph. Black/Touring/Track/LSD/TC/SS. Mods: corner balanced - RTD brace - Manly's inserts - decambered - Pagid Blacks - Motul fluid - tow hooks - Schroth belts - extinguisher - AIM timer - Green Filter - Larini - oil temp & pressure gauges - AO48s & Rotas on track - T1Rs & OEM wheels on street - rear camera & monitor - Stebel horn - speakers upgraded, sub & iPod controller - DRL disable switch - aux. fuse panel - sill pockets - leather console - Bootie - roof scoop functional.
Lotusmotion is offline   Reply With Quote
Old 10-12-2008, 06:16 AM   #7 (permalink)
Ex-Brit
TheViper's Avatar
This is the opening above the license, plate. Simply, drill a small hole through and you are in the trunk, just be careful to avoid the wires.
A/C Improvement Modifications
http://www.lotustalk.com/forums/f3/e...ent-mod-59938/
1) Insulate the cockpit from Solar (3M Crystalline Tint) & Convected (insulate sills) heat.
2) Replace evaporator thermostat with an upgraded electronic version to prevent freeze up.
3) Increase airflow into cockpit by removing both driver & passenger side footwell intake panels & blocking 2 outside air intakes in nose.
Old 10-12-2008, 07:23 AM   #8 (permalink)
+1!
Old 10-12-2008, 09:41 AM   #9 (permalink)
disproving HD MTBF daily
charliex's Avatar
i just went between the plate holder and clam/trunk into the engine bay, no drilling, goes under the heatshield , no problem.
Black Exige S - http://goth.am 265 Mule / Elan M100 ECU Tuning, http://www.elisetalk.com/forums/showthread.php?t=39660
Arguing with an engineer is like wrestling with a pig in mud. After a while, you realise the pig is enjoying it.
charliex is online now   Reply With Quote
Old 10-18-2008, 05:30 PM   #10 (permalink)
Monsi's Avatar
Images: 21
thats what I am attempting but I cant seem to get the license plate holder out so I can see what I am doing... is there a trick to this? do you need to drop the whole difuser?
Old 10-19-2008, 01:31 AM   #11 (permalink)
Monsi's Avatar
Images: 21
the 2008s seem to have a slightly different set up back there :|
Old 10-19-2008, 01:37 AM   #12 (permalink)
British by extrapolation
Mr. Know's Avatar
Images: 5
Careful Monsi...if you can't get this one, we are going to have to revoke your Lotus Owner Card.
Kidding aside, good luck. I've gotta install one myself soon. Getting tired of trying to get out of parking spaces blind.
07 Magnetic Blue Exige S
Mr. Know is online now   Reply With Quote
Old 10-19-2008, 01:51 AM   #13 (permalink)
Monsi's Avatar
Images: 21
I took out all the bolts holding the damn thing to the diffuser but it still wont move... I cant find whatever it is thats holding it in place
you will have to excuse me for not tearing into my brand new exige
HTML code is On
