Statistical Anomaly
Backup camera help
so I searched and didnt find what I was looking for... but I am trying to figure out how to get the wire from the camera on the rear license plate into the boot...
I wanted to ask before I start taking my new car apart ![]()
Dude, there's my car!
#5 (permalink) | |
Statistical Anomaly
I tried pulling off the butt plate but I forgot to bring all my metric wrenches so will have to wait till I go home ![]()
Keep it simple and real
Monsi, I just finished installing a Boyo VTL420 and a 3.5 inch monitor in my Exige.
After searching / reviewing all the postings (there are many) about back-up cameras, I chose to do the following: - I drilled a 1/4 inch hole in the trunk floor, about 1 inch away from the back seam) above the rectangular opening above the license plate area. I installed a rubber grommet and pulled the camera wire through it. The wire is routed along the trunl heading toward the battery area. - I drilled another 1/4 hole in between the battery cable grommet and rear lights harness grommet, located at the front driver's side of the trunk. Again, I installed a grommet there and pulled the camera wire through that hole into the engine bay. - From there, I routed the wire (with ties) under the airbox , to the driver's corner of the firewall, down and across to the center, and routed the wire through the shifter cable opening / channel. - I ran the wire under the center console, up through the floor divider, around the back of the passnger footwell and into the passenger side dash panel (below the vent). There, I connected the camera wires up to the monitor wires, protected them wire convoluted wire covering, tucked the bundle into the dash area, and closed up the panel. - I removed the mirror (had a S111 Micro Mirror) and installed the monitor in its place. The monitor cable, between the dash and monitor, is held in place by tucking the cable into the header just behind the windshield and crevice where the windshield meets the A-pillar. - I wired the camera so it is always on 100% of the time. - Total parts = $160. - Install looks factory.
'06 Exige - Ph. Black/Touring/Track/LSD/TC/SS. Mods: corner balanced - RTD brace - Manly's inserts - decambered - Pagid Blacks - Motul fluid - tow hooks - Schroth belts - extinguisher - AIM timer - Green Filter - Larini - oil temp & pressure gauges - AO48s & Rotas on track - T1Rs & OEM wheels on street - rear camera & monitor - Stebel horn - speakers upgraded, sub & iPod controller - DRL disable switch - aux. fuse panel - sill pockets - leather console - Bootie - roof scoop functional. Last edited by Lotusmotion : 10-14-2008 at 03:14 PM. Reason: add pictures |
#7 (permalink) |
Alarmed & Dangerous
This is the opening above the license, plate. Simply, drill a small hole through and you are in the trunk, just be careful to avoid the wires.
#8 (permalink) |
+1!
#9 (permalink) |
OSX Black hat
i just went between the plate holder and clam/trunk into the engine bay, no drilling, goes under the heatshield , no problem.
#13 (permalink) | |
Statistical Anomaly
![]() you will have to excuse me for not tearing into my brand new exige ![]()
