Alarmed & Dangerous
Battery Alarm Problem Solved
As this is my first experience of this happening I thought that posting would be helpful to others:
I try to disarm the alarm this morning with no response from either transmitter, except that I did get 4 beeps, an indication of an ignition issue. The locks opened (strange) but the alarm remained active as indicated by the single led flash on the dash. I deduced that because neither transmitter worked, the problem was probably low voltage at the car battery. Upon opening the car door there was no alarm, remember the dash light indicated it was active. I noted that the interior cockpit light, between the seats was very dim, confirming my low battery theory. Opening the trunk there again was no alarm, I now realise was due to the low 4.5V reading of the battery. I attempted to disconnected the battery to charge it and as I did the siren's back up power kicked in and it sounded on and off until I reconnected the battery. Because the battery voltage was so low my "smart" charger would not charge, because if it sees a voltage below about 8V it indicates a defective battery cell, etc. In order to try to charge the battery I now had jump start the car and at the same time used the transmitter to deactivate the alarm. I let the engine idle for a while and drove a little to charge the battery, which after I turned off the engine, had enough power to restart the car. Now the battery voltage was over the 8V threshold, I now used my charger to complete the charging. Almost 3 years on my Exide OEM, I am now going to purchase a Optima Red top 35.
It's a Lotus
New battery is a good thing on slightly old Lotus cars!
2005 Saffron Yellow Elise. Stage II Exhaust. 2007 ProBax seats. "We know they're magical and worth every minute we spend on them. The whole Lotus owners' world is like a secret handshake among people who understand that." (R&T) |
They say after 2 yrs. batteries are on borrowed time.
I haven't had much luck with Optima. We stopped using them at work. Too many problems. We have installed a couple of dozen over the past 3 yrs. The failure rate was too high. Just fyi. WE switched to Odyssey but for the price you can get 3 red tops. ![]()
2005 Elise Storm Titanium |
Live from the Bubble Room
Viper
I installed odyessy PC 625 ($85.00) so far it has doubled the life of the factory battery and shows no sign of weakness even in the past two summers with AC and cooling fans running full time. BTW thanks for all the good work on AC mods, opening up the drivers side footwell and installing the elec. thermostat kit plus the heater core bypass I now have an 05 with a pretty good AC that does not freeze up. ![]() Odyssey Battery PC625 - Odyssey Drycell Batteries - summitracing.com
"Never leave well enough alone" Raymond Loewy |
insert clever title here
For what it's worth, my stock battery had four years on it when I replaced it about a month ago, and it was still going strong - the only reason I replaced it was to reduce weight. I always kept it plugged in to a battery maintainer though which probably helped it last as long as it did.
#6 (permalink) | |
Alarmed & Dangerous
Great to hear about your successful A/c mods.
The reason I went with Optima is because I needed the best Amp Hour rating I could. My car is kept outside with no electrical outlet and sometimes is not driven for a week or so. Additionally I have the extra electrical load of an additional alarm system draining the battery. Michael Quote:
#7 (permalink) |
Alarmed & Dangerous
Interesting addendum, seemingly, after power was removed from the alarm module it reverted to a default program. I had previously increased the volume of the signal "buzzer" and now it was back to where it used to be. This seems to be the only function so effected.
#8 (permalink) |
2/3 hp to the paws.
I use an Optima yellow top in my Elise, and all my other cars for that matter. The Elise can go upwards of two weeks without being started, and that's with a Viper alarm, GPS tracking, radio memory, and so forth all sucking up a fair bit of juice.
The red tops are less happy with deep cycling in my experience. |
#9 (permalink) |
Mods are good for you
I used a red top on a BMW (once) and it's performance was less than sub-par...you should consider a yellow top or PC series Odyssey instead.
2008 Solar S240 Exige 2005 Saffron Elise - BOE TVS Supercharger 291WHP w/ EFI Engine Mgmt |
#10 (permalink) |
Alarmed & Dangerous
Done, installed, I am not going to worry, it has a 3 year 100% replacement warranty.
#11 (permalink) |
just installed a replacement optima redtop that i bought 6 months ago. i guess that warranty is going to come in useful
![]() i considered switching to a yellow top but the warranty is not nearly as good. when the warranty expires i will look at something else. i wonder how many i will go trhough in 3 years
Storm Titanium, LSS, touring, hard top. my other car is a ...oh yeah i remember the other car...a spyder club111 member. i tried to buy a lower spot and become member #13 but was spurned! "They that can give up essential liberty to obtain a little temporary safety deserve neither liberty nor safety" -benjamin franklin |
#12 (permalink) |
A bunch.
Something weird about those batteries. A normal lead acid from 1940 will last longer. They had good hype when they first came out but folks are getting wise to the "less than" Optima.
