Old 10-31-2008, 09:41 AM   #1 (permalink)
Alarmed & Dangerous
TheViper's Avatar
Battery Choices & Information
SEE TABLE AT BOTTOM FOR CHOICES
DEAD BATTERY IN THE ELISE / EXIGE
If the battery is dead and the Remote Fob was used to lock the doors and arm the alarm system, the doors can't be unlocked using either the Remote Fob or the key. The method used, is to open the Engine/Trunk cover on the Elise and Exige and gain access to the battery, the alarm may not sound due to low battery voltage. Now apply a 12V power source to the battery, using either "jumper cables", "power pack" or a "battery charger", and then use the Remote Fob to turn off the alarm and open the doors. On the Exige the front "power post" can be accessed as an alternative. If the battery is disconnected before disarming the alarm, the system will switch over the the back-up battery and sound the siren.
LOTUS RELATED INFORMATION
1) Due to the risk of battery leakage in the trunk, replace the existing OEM wet (flooded) cell with an AGM battery, which can't leak, spill, & emits no flammable hydrogen gas under normal circumstances.
2) The choice between "weight" & "capacity" (Amp Hour)
If you track, then you may consider the battery weight to be the most important.
If you don't drive the car often, (especially in colder climates) and don't have access to a "battery maintainer", a greater amp hour (AH) capacity is desirable.
3) The Elise/Exige uses a "BCI group 26R" size battery, however a "35" will also fit. Batteries of other physical size will need a custom support.
4) The OEM "Exide X-tra" is European only model
5) The "Black" OEM has the reputation for leaking.
6) Wet cell batteries typically loose 1% of their energy per day, without any load applied.
AGM batteries will typically loose 1 to 3% per month, without any load applied.
7) Parasitic load on the battery is;
Alarm/Immobilizer OFF + Radio + ECU = 20.5ma
Alarm/Immobilizer ON + Radio + ECU = 42.5.5ma
SULFATION - THE DEATH OF A BATTERY
THE SYMPTOM
The first thing you notice is that the battery is either not accepting a full charge or not lasting as long as it used to. The main reason is that the battery is dying due to sulfation. During it's life, sulfate forms on the plates and can solidify, insulating them, and inhibiting the chemical reaction. The more a battery is neglected the quicker the sulfate forms, but eventually it is inevitable that it will kill the battery.
THE CAUSE
Batteries sulfate because;
a) Sit too long between charges. As little as 24 hours in hot weather and several days in cooler weather.
b) Battery is stored without some type of energy input.
c) "Deep cycling" an engine starting battery. Remember these batteries can't stand deep discharge.
d) Undercharging of a battery, to charge a battery (lets say) to 90% of capacity will allow sulfation of the battery using the 10% of battery chemistry not reactivated by the incomplete charging cycle.
e) Heat of 100 plus F., increases internal discharge. As temperatures increase so does internal discharge. A new fully charged battery left sitting 24 hours a day at 110 degrees F for 30 days would most likely not start an engine.
f) Low electrolyte level - battery plates exposed to air will immediately sulfate.
g) Incorrect charging levels and settings. Most cheap battery chargers can do more harm than good.
h) Cold weather is also hard on the battery. The chemistry does not make the same amount of energy as a warm battery. A deeply discharged battery can freeze solid in sub zero weather.
i) Parasitic drain is a load put on a battery with the key off.
j) Battery voltage falls below 12.4V
THE SOLUTION
Simply keep the battery fully charged by either regular driving or keeping it on a maintainer.
De-sulfating (conditioning) the battery is possible if you have a charger, or maintainer with that function. It is recommended to de-sulfate regularly and though a number of cycles in order to keep the plates clean and prolong the battery life. If the sulfation has progressed too far, it may not be possible to rectify. One such maintainer/conditioner is the BatteryMINDer Plus and from the same company is the conditioning only BatteryMINDer On Board Restorer-Conditioner
BATTERY TESTINGThe best method is "load testing" (many places that sell batteries will do this test), but without suitable equipment the following voltage measurement method can be used;
Measure the battery voltage across the two battery terminals.
Although a vehicle battery is called a 12 volt battery, 12 volts is considered discharged.
Before measuring, the "surface charge" has to be removed. The surface charge, which results from recent charging, will make a deficient battery seem good. The best way to remove the surface charge is to leave the battery for 6 to 12 hours in a warm area. Alternatively, with the engine off, the high beam headlights should be left on for 5 minutes, turned off and then left for 5 to 10 minutes.
100% charged & healthy battery will measure 12.66V.
75% charged will measure 12.45V
50% charged will measure 12.24V
25% charged will measure 12.06V
Below 12V a battery is considered discharged
A shorted or dead cell will read 10.5V
Check the battery cable connections for a secure fit or signs of corrosion.
Typically, an alternator will not bring an AGM battery to a full charge condition.
THE ALTERNATOR
BASIC ALTERNATOR TEST
At idle the voltage across the battery terminals should be between 13.5 & 14.5V
At 1500rpm the voltage should not exceed 14.8V
ALTERNATOR WARNING LIGHT
Check that the alternator belt is not broken or slipping.
Check that all battery & alternator connections are secure and clean.
The red ALT light, basically, means that either the alternator output voltage is lower than the battery voltage, or the battery voltage is lower than the alternator output voltage. If the light gets dimmer as you rev up the engine, then you most likely have a problem with the alternator. If it gets brighter, then the battery is most likely bad.
ALTERNATOR PROBLEMS
Many times one or more diodes in the alternator rectifier assembly will have failed, causing a drop in the unit's output. The alternator will still produce current, but not enough to keep the battery fully charged.
JUMP STARTING FROM ANOTHER VEHICLE
The Elise/Exige does not start easily when being jump started. Frequently, a series of clicks will be heard from the starter solenoid, but the starter motor will not operate. I have had success with the following method;
Connect the cables, making sure you have good connections on both ends.
Start the other "donor" vehicle and let it run for 5 minutes at high idle, about 1500 - 2500 rpm, this will give your battery a boost. Now with the other car still running try to start your car.
Old 10-31-2008, 10:40 AM   #2 (permalink)
I just called your Mom
snuggles1's Avatar
man, this is so helpful - thanks a million.
i assume that the stock Elise battery is at the top of the list?
also, how nerdy does it look to ask for a lightweight battery for Xmas?
-"You really have a battery on your wish list?"
-"Well I need to lose 20lbs of body weight"
-"That's nice, son"
2002 Brian Moore C55 >> 2002 Ibanez AR250 with Gibson Burstbuckers >> 2001 Taylor Grand Auditorium >> 2000 Les Paul Custom 3 pickup >> 1998 Brian Moore C90 >> SRF chassis 543 >> 1976 Rickenbacker 4001 >> 1972 Fender Telecaster >> 1939 Gibson Archtop
snuggles1 is offline   Reply With Quote
Old 10-31-2008, 10:50 AM   #3 (permalink)
Alarmed & Dangerous
TheViper's Avatar
Stock are #1 or 3.
Number 2 is what Lotus specify in the handbook.
-"That's nice, son"
Old 11-19-2008, 06:32 AM   #4 (permalink)
Mods are good for you
Dave's Avatar
I'm now running the Braille B129 - super lightweight 9lbs. Almost 5lbs lighter than my PC625 with +200 PCA @ 813A! Fired my car up this morning in 24F ambient the second I pushed the button. Data: Braille Battery - B129 and good price here: Braille No-Weight Race Use Battery (9.5lb) [BR-B129] EDO Performance
2008 Solar S240 Exige
2005 Saffron Elise - BOE TVS Supercharger 291WHP w/ EFI Engine Mgmt
Dave is offline   Reply With Quote
Old 11-19-2008, 07:14 AM   #5 (permalink)
Buz
weights
The Odyssey batteries are usually lighter than the advertised weights. I just weighed a PC1200 and it is 32lbs 12.3 oz. and definitely has more reserve capacity than the oem 45ah battery. I can post actual weights of the pc925 and pc625 later. The older Voltphreaks 3lb battery was actually 2lb 12 oz but the latest version might be heavier.
Buz is offline   Reply With Quote
Old 11-19-2008, 08:00 AM   #6 (permalink)
Alarmed & Dangerous
TheViper's Avatar
Thanks Dave I have added the 106 & 129 to the table.
Old 11-19-2008, 04:21 PM   #7 (permalink)
tmr
ATL
tmr's Avatar
Remember that Odyssey batteries can be had with or without the metal jacket. I think it can add up to about a pound or so.
tmr is offline   Reply With Quote
Old 11-30-2008, 12:52 PM   #8 (permalink)
BANNED
SweetDaddyD's Avatar
Images: 2
subscribed. Think I'll be needing a battery within the next year. I do drive a lot so it's been holding up well, but as of lately I have not been driving the car every day.
on an almost related side note my factory BMW battery lasted 10 years when the car was driven every day. (and for quite a miles around 100 miles per day). Like most other parts of the car sitting is harder on them than using them.
SweetDaddyD is offline   Reply With Quote
Old 11-30-2008, 01:05 PM   #9 (permalink)
JnC
Thread unraveler
JnC's Avatar
I suspect Braille gets their batteries from Deka, as Deka is a major manufacturer and their batteries seem to have the same form factors.
On average a Deka is approx $100 cheaper than Braille. But Braille does claim higher capacities, so perhaps there is a difference?
2007 Cross Country Travelblog
06 Lotus Elise :: Chrome Orange :: Base :: Black Pack :: TC :: SS
00 VW Golf GLS TDI
JnC is offline   Reply With Quote
Old 01-20-2009, 01:21 PM   #10 (permalink)
Juvenile Delinquent
Joecooool's Avatar
Lets be clear about something.
If you are looking for a battery that WILL FIT in the stock area, you need to buy one that is the same size as the stock one.
All the other batteries will require brackets that you will have to install in the car.
ORDER YOUR BRACKET FIRST. I ordered a PC680 and then found out every supplier - Sector 111, Force Fed, etc - were all out of brackets. I kept getting promises that the brackets would be in any day, in the mean time I went six weeks without a working battery setup in the car.
Joecooool is offline   Reply With Quote
Old 02-14-2009, 02:37 PM   #11 (permalink)
Rom
Rom's Avatar
Hi all,
Based on some calculations I did, using a 35mA draw (15mA immobilisor, 20mA alarm), it appears that an Odyssey PC680 (what I myself have now - it came with the car) will reach 50% capacity in only 6 days, under ideal conditions (80F). Anything colder, and 50% would be reached quicker.
The PC680, according to Odyssey, is not designed for reserve capacity. Assuming that starting the car requires at least 150A, a PC680 rated at 300CCA would not last more than 7 days before it struggles to start the engine.
The PC925 should reach the 150CCA point after around 17 days.
The PC1200 should reach the 150CCA point after around 30 days.
These calculations assume a relatively linear power drop, and in an AGM-based battery should be relatively accurate. Wet cell would probably be more unpredictable. The calculations seem to fit the relative experiences with the different ratings I have had.
Note that CCA is taken at zero degrees celcius (32F), so under "normal" weather conditions, you should be able to gain a little more time. However, since the reserve power ratings are done at 80F, it may compensate for this gain.
DISCLAIMER: These calculations are an approximation, and the age of the battery, condition of the charging systems, use and abuse of the battery, etc, can (and will) have a major impact on the figures.
If weight is a major concern for you at the track, but you drive on the street too, then I'd suggest getting a PC680 for the track and a PC925 or PC1200 for the street. Just swap the battery when you get there. AGM-type batteries can be stored up to two years (make sure it's fully charged before storing). This will ensure the best battery life overall - IMHO, PC680's on the street cycle too much, reducing their lives significantly as the battery should always be kept nearly fully-charged (unless you have a power outlet nearby with a good battery maintainer!).
One other thing - you should also ensure your regular charger is designed for AGM-type batteries.
HTH!
Thanks!
S.
Lotus Elise Series-2 - US Spec: SSR Comps, PES ECU Remap, F5 Fujita Induction, Larini SE Exhaust (Euro-style), B&M Short Shifter
Mitsubishi Evolution IX MR SE: Stock.
Porsche Boxster: Stock.
Lotus Elise Series-1 - UK Spec: Stock. (sold)
Rom is offline   Reply With Quote
Old 02-15-2009, 05:50 AM   #12 (permalink)
Alarmed & Dangerous
TheViper's Avatar
Intersting info Rom, but I believe there really is no "accurate" way of calculating how long a battery will last until such time that it is incapable of starting the vehicle, so many variables. Even identical batteries will have different durations. The best way, is to look at the AH rating as just a guide to compare different batteries e.g. a 20 AH battery should last about twice as long as a 10AH. Even a fully charged battery at 12.66V will dip to around
9.6V under starting conditions. But, I agree that a small, light weight battery can not be expected to nomally last for weeks with an appreciable parasitic load. Incidentally, I believe that the total parasitic load on the vehicle, with the immobilizer and alarm set was 20ma, with only the immobilizer it is 15ma, not combined, but I will check that tomorrow. I also believed that included in that 20ma is a small 7ma from the ECU. This total does not include any radio loads.
Batteries are my friend
Old 02-15-2009, 07:05 AM   #13 (permalink)
Wizard of Pugz!
qball's Avatar
Images: 3
Add this as a cheaper alternative to the PC680
New Sealed Battery Option - Cheaper, Better!
Its the exact size as the PC680, and will fit the Sector 111 bracket. It's half the price, and has more reserve.
It's gone 3 1/2 weeks sitting in the garage and I have still been able to crank it over with ease (My PC680 would last 10-14 days).
Highly recommended!
qball is offline   Reply With Quote
Old 02-15-2009, 01:08 PM   #14 (permalink)
Rom
Rom's Avatar
Yep - hence my disclaimer . The time values are only meant to be an approximation.
I'll measure it on mine too... If the parasitic is only 20mA total, then the time intervals should be quite a bit longer (I searched through the forums for the parasitic value). I'd be interested to know your measured values - I'll measure mine too for comparison. It would be good to see if our cars are all the same, and what the difference is between model years and Elise vs Exige.
Thanks!
S.
Old 02-15-2009, 01:19 PM   #15 (permalink)
Rom
Rom's Avatar
Oh yea, and I just installed an Optima 35 yesterday. Although it's quite a bit heavier than my PC680, I was fed-up of not being able to drive when I wanted (due to consistant flat batteries)!! Since I moved to within walking distance of work, I rarely drive any of my cars now (wife & kids means when I do drive, we take the Evo)... The Lotus goes 2-3 weeks without moving, and I don't have an outlet nearby.
The slight weight saving is more than made up by my lighter SSR's and Larini
I'll report any issues the Optima may have in the coming months.
Thanks!
S.
Old 02-15-2009, 03:25 PM   #16 (permalink)
Alarmed & Dangerous
TheViper's Avatar
I installed a Optima 75/25 a few months ago. I have no access to an electrical outlet and somtimes don't drive the car often so I needed the security of high AH.
Thanks!
S.
Old 02-15-2009, 04:35 PM   #17 (permalink)
BANNED
Images: 2
Good luck with the Optima's guys. I had one a few years back that was garbage. It was in a car stored in MI for a couple months in the winter and was deader than could be when it was time to come out of storage and would not take a charge. Several other guys that got them from the same stereo shop had the same thing happen. We all got left high and dry on any kind of warranty either and could never get a response from anyone at Optima.
Hope they aren't as big a pile of garbage as the batch my friends and I had an experience with.
Old 02-15-2009, 08:32 PM   #18 (permalink)
xxxotic's Avatar
Mine is working OK. I have had it for a few months now and drive the car about once a week. The longest I went without driving it is about 2 weeks
It starts up fine without any problems. I left the radio on with the old battery for about 15 minutes and it killed it.
I cant complain about the stock one, it lasted over 4 years for me.
Got the Optima at Costco. They have a pretty good return policy, so if it dies on me I don't think I will have a problem.
xxxotic is offline   Reply With Quote
Old 02-15-2009, 08:51 PM   #19 (permalink)
eTard
craracer's Avatar
Anyone have any concerns of off-gassing corrosion when charging a battery still in the vehicle?
craracer is offline   Reply With Quote
Old 02-15-2009, 09:39 PM   #20 (permalink)
tesprit's Avatar
When I used to charge the stock battery, I was quite concerned over this. All of the other cars I have owned with a battery in the trunk (3 BMWs and a Turbo Esprit) all had batteries with a vent hose attached that directed any hydrogen produced or acid vented through the hose which passed through a grommet in the trunk floor to the outside of the car. With no vent hose to the outside on my Elise, I was always careful to leave the trunk lid open and to check for spilled acid around the battery. With the new sealed AGM batteries, there is no trouble with the lack of a proper vent to the outside of the trunk, but out of habit I still leave the trunk lid open when charging the battery.
