Old 10-01-2008, 03:16 PM   #21 (permalink)
sfelise's Avatar
Here's how I mounted my voltphreaks 4.5lb battery. I used a piece of 1/8"x1" aluminum bent it to fit the battery and bolted it to the bracket that holds the A/C hoses using the original screws. To make sure the battery does not slip I cut a slot in the tabs of its case for the aluminum to fit into. Its kind of overkill but its not going anywhere now
Name:  New Battery Location 1.jpg
Name:  New Battery Location 2.jpg
Eric Jennings
2005 Elise
2004 S4 Avant
1995 M3 (RIP)
sfelise is offline   Reply With Quote
Old 10-01-2008, 03:23 PM   #22 (permalink)
06 SY Exige
LordZ's Avatar
The only reservation I have is that some people with the tilting clam left off the gas overfill tube and cup (I didn't, but it's not glued onto the clam any more though) when they re-assembled everything. The thought of gas sloshing out and over the battery is kinda scary.
LordZ is offline   Reply With Quote
Old 10-01-2008, 03:30 PM   #23 (permalink)
sfelise's Avatar
Yeah I thought the same thing. I left the cup on, but it doesn't seal except by friction now, so I am careful on fill-ups. Having the battery that close to the fuel tank in general is probably not optimal, but I think the added risk is pretty small. These cars go up in flames easily for lots of reasons so a fire extinguisher is probably a good idea.
Eric Jennings
2005 Elise
2004 S4 Avant
1995 M3 (RIP)
Old 10-01-2008, 04:42 PM   #24 (permalink)
Plug Whisperer
turbophil's Avatar
Images: 3
Well done Eric!
I also thought about the gas issue... but then I thought that would be some pretty bad luck if I just happen to flood a bunch of gas on the battery and it just happen to be shorting out at the same time to create a spark to ignite the fuel... I figure there's a better chance of setting off the fuel tank with static electricity So I proceeded without any concerns and really enjoy the new location
Best,
Phil
| '05 GG LSS Elise | A Track Chariot | BOE ClamHinge | BOE TVS SuperCharger 275whp/175wtq | EFI Standalone Engine Management |
See my car at BOE Fabrication: www.boefabrication.com ----->Last Updated: 11/09/08
If something ain't worth doing right, it ain't worth doing at all...
turbophil is online now   Reply With Quote
HTML code is On
