Old 12-09-2008, 01:26 PM   #1 (permalink)
Battery tender
Need a little help...when attaching a battery tender where would be the best place to attach the negative alligator clip or ring?
yelotail is offline   Reply With Quote
Old 12-09-2008, 01:35 PM   #2 (permalink)
no more gnawing
Mr_Baker's Avatar
Images: 1
to the negative post of the battery? Is this a more subtle question than it appears to be?
'05 Yellow, LSS, Touring
Mr_Baker is offline   Reply With Quote
Old 12-09-2008, 01:38 PM   #3 (permalink)
G-200 Driver
kestrel74's Avatar
I think you're supposed to attach it to the small part....the part that's not lit...
kestrel74 is online now   Reply With Quote
Old 12-09-2008, 01:47 PM   #4 (permalink)
Will There Be Cake?
ItsThaMonsta's Avatar
Ill give you the same great advice someone gave me..... Just buy the attachment that allows you to connect it through the power outlet inside the car. You wont even have to touch the battery.
ItsThaMonsta is offline   Reply With Quote
Old 12-09-2008, 01:51 PM   #5 (permalink)
NSR
NSR's Avatar
OP,
First time charging, I had the same question, the instruction states to hook it up to a metal part of the engine or frame and in our car, a little difficult. I've hooked it up directly onto the neg. terminal with the rings and have not had any problems.
NSR is offline   Reply With Quote
Old 12-09-2008, 01:59 PM   #6 (permalink)
AR #0369
foosh's Avatar
Images: 4
I assume you're talking about connecting the BT pig-tail so it can be easily plugged in.
Find a bolt that fits the hole (should be threaded as mine is) in the picture below. Attach the negative (black) terminal here, and the positive (red) to the battery positive terminal. This works well because the pigtail can then be fed through the louvers for easy plug-in.
foosh is offline   Reply With Quote
Old 12-09-2008, 02:06 PM   #7 (permalink)
perfututum futūtor
RoadDad's Avatar
foosh,
How long is your "pigtail" connector? There is no way that my connector would go from the engine bay through the divider between the bay and the boot to get to the battery. It's just not long enough.
Mine is connected directly to the battery terminals, fed out the back of the battery cover and hangs along the front of the cover in the boot. No fires or blowing up so far when I connect it.
Me... I don't need to.
Bite me." -Randy
Old 12-09-2008, 02:08 PM   #8 (permalink)
Register Abuser
Gizmo3000's Avatar
+1 ^10
2005 Starlight Black Elise, -hardtop/touring/black interior/sector111 carpet buttons!
2008 Infiniti G37-S
1991 300ZX 2+2
1974 MGB Roadster
Gizmo3000 is online now   Reply With Quote
Old 12-09-2008, 02:12 PM   #9 (permalink)
AR #0369
foosh's Avatar
Images: 4
Originally Posted by RoadDad View Post
foosh,
Sure it is, just split the red and black sides of the cable by pulling them apart, until you have enough lead. My cable is the std. one that came with the std. $19 BT. However, connecting to the battery is fine in 99.999999% of cases. Attaching to a ground away from the battery is just an added precaution.
Old 12-09-2008, 02:53 PM   #10 (permalink)
Alarmed & Dangerous
TheViper's Avatar
Even though it is unlikely you will get a spark from such a low amperage unit it can be completely avoided by only plugging in the maintainer after it has been connected to the battery, just like you would, charging a battery out of the car.
Old 12-10-2008, 04:55 AM   #11 (permalink)
perfututum futūtor
RoadDad's Avatar
I guess I have a shorter than standard unit
and my cord is too short to do that also
Bite me." -Randy
Old 12-10-2008, 05:40 AM   #12 (permalink)
thanks guys for the input
