i read the manual my Battery Tender Junior 12V came with and I was a little confused on which side I should connect first. It was talking about positive ground, negative ground and I don't know which one to follow.
KG Exige Delivered 5-9-2006 POLL:check for scratches "in" your headlights Excessive tire wear? It may be your alignment My Example Hiro's Example codymac's Example to be installed: stebel horn, fumoto valve current mods: arqray twin muffler, itg intake, 3M film full wrap and full rockers by X-Perts, rear lotus letters removed, locking gas cap, CF Mirror Covers, CF Side Scoops, black lotus nose/wheel badges future mods:wheels, forced induction |
GR8 SCAPE
+1.
FWIW, mine came with a permanently installed wire harness that connects the two wires from the battery to a snap plug connection. I only have to plug it in. Very quick hookup. Regards, Wayne
_______________________ '05 Elise Magnetic Blue, Black, Touring, Hard Top, Star Shield, Stage II Exhaust, Arqray decat pipe, S2 Front Splitter (UK), Sector 111 Rear Tow Hook, Driving Lights, De-Snorkled, K&N Air Filter, Shift-I System, LSS Dampers & Springs, Sector 111 V-Bar, Schroth Profi II 5 point harness, Exige S Probax seats, 1/4 turn undertray screws, Stealth bulbs, BWR SC with PES tune, Innovative engine mounts, SS brake lines. |
Alarmed & Dangerous
+1 First red to battery positive, second, black to a chassis ground ( if it is an AGM battery you can connect it directly to the battery as there are no flammable gases) BTW this unit has reverse polarity protection.
Left Lane Assasin
The best battery charger now on the market is the Tecmate-Optimate 4. Sealed, lots of indicators and features. A really intelligent charger. I am getting rid of my Battery Tender.
2007 Exige-All Black and Mean , Factory TouringPak/TrackPak/StarShield/LSD/TractionControl/iPodDock. All stock but not for long.![]() v = square root ((2 * e) / m) |
i think i have the pc625, so can i connect directly to the positive and then the negative posts and plug the battery tender in?
#7 (permalink) |
Alarmed & Dangerous
Yep
#8 (permalink) |
G-200 Driver
Pretty sure it's + ....but I'm not......positive
#9 (permalink) |
the designer
If its battery tender the actual brand...it doesn't matter + or - as it has a smart feature to take care of it for you. Just hook it up...
2008 Exige S 240 For Sale: 2005 stock shifter console and change holder. PM if your interested. |
#10 (permalink) |
Alarmed & Dangerous
Actually, it really does matter, otherwise it won't work. It simply has reverse polarity protection so that if it is connected incorrectly, in reverse, it won't damage the battery or the charger
.Michael
#11 (permalink) |
thanks everyone. positive first
#12 (permalink) |
Register Abuser
..right into the Cigarette lighter for me
![]() (just in case you hadn't considered that option, it's quite handy)
2005 Starlight Black Elise, -hardtop/touring/black interior/sector111 carpet buttons! 2008 Infiniti G37-S 1991 300ZX 2+2 1974 MGB Roadster |
#13 (permalink) | |
the designer
SPECIAL FEATURES: The Battery Tender ® Junior and Plus Chargers have the following special features: SPARKPROOF: The battery charger DC output leads, either ring terminals or alligator clips must be connected to a battery before an output voltage is developed by the battery charger. SHORT CIRCUIT PROTECTION: The battery charger can sustain a short circuit connection directly across its DC output terminals indefinitely without any risk of either electric shock or excessive heat. REVERSE POLARITY PROTECTION: The battery charger is protected internally against any damage due to the DC output leads being connected to the opposite polarity battery post. No damage will result to either the battery or the battery charger.
#14 (permalink) |
British Car Restoration
+1
When you hook up the ground last, there is less chance of arcing. In fact, don't connect that ground clamp to the battery, but to something else on the car that is a metal ground. I have personally seen a car battery explode as the arc was created just above the battery. An invisible hydrogen cloud was there, created from the battery chemistry. The top of the battery lifted, exposing the sulfuric acid. If connecting to a free standing battery, hook up both clamps before plugging in the charger. |
#15 (permalink) | |
Alarmed & Dangerous
Actually, this is only true with flooded cell batteries, with AGM's, no gas is expelled, therefore there is no risk of an explosion.
Michael Quote:
