Old 02-25-2009, 02:50 PM   #1 (permalink)
SKYVUE
SKYVUE's Avatar
Images: 1
The best battery?
My ODYSSEY PC680 is at the end of it's life, I assme it has 3 years or more in the Elise. If I leave the Elise for two days, the car needs a jump to start. I've invested in a battery tender and that seems to work now, but I need another battery soon.
Is the Odyssey PC680 the best for replacement? It was $159 from Battery Plus Stores.
When I replace it, will I go through problems with the alarm/immobilizer/key fobs? Or it will be easy by connecting the old, connect the new and it's ready to go?
Thanks
--Hal
--SKYVUE
Resident Astronomer
'05 Saffron Elise,SOLD!
'07 CaymanS
SKYVUE is offline   Reply With Quote
Old 02-25-2009, 03:38 PM   #2 (permalink)
Go ahead....back up.
Rondo Fondu's Avatar
I was in a local race car shop and was asking about the batteries they used in their race cars and they turned me on to the Genesis EP. Genesis EP is the Industrial/military version of the Oddessy (Oddessy and Genesis are both made by Enersys) and weighs 13.5 lbs, 2 lbs lighter than the Oddessy. I have had one now for about 8 months with no issues. Battery Store/TNR Technical/TNR Batteries, your Extreme Batteries Source has these for $95.00 on the website. The one thing is they like a charge of 13 to 14 volts from the battery tenders not a 12 volt charge.
Genesis EP G12V16AH10EP
Part # G16EP 0769-2007
width = 7.15
height =3.00
depth = 6.60
lbs = 13.5
"Whatsa behind me isa not important" - Franco Bertolinni (Raul Julia) The Gumball Rally 1976
Rondo Fondu is offline   Reply With Quote
Old 02-25-2009, 04:22 PM   #3 (permalink)
Wizard of Pugz!
qball's Avatar
Images: 3
I highly recommend this
New Sealed Battery Option - Cheaper, Better!
Same size as the PC680 but considerably more reserve. My PC680 would last 10 days or less without use before being unable to start the car. This new battery has gone 3.5 weeks (and could probably go longer) and zero issues.
qball is offline   Reply With Quote
Old 02-25-2009, 06:06 PM   #4 (permalink)
jeavis's Avatar
I recently installed one of these batteries on qball's recommendation with the sector111 bracket and cutoff switch and it's been wonderful. So far the car has only sat for 1 week without being started but there hasn't been a single problem cept for slightly having to modify the sector111 bracket, but it was only a minor adjustment and I took care of it with a metal file.
2005 Elise, Storm Ti
www.98Bottles.net
jeavis is offline   Reply With Quote
Old 02-25-2009, 06:35 PM   #5 (permalink)
Alarmed & Dangerous
TheViper's Avatar
Battery Choices & Information
Old 02-25-2009, 08:01 PM   #6 (permalink)
Statistical Anomaly
Monsi's Avatar
Images: 21
width = 7.15
height =3.00
depth = 6.60
lbs = 13.5
you need a higher voltage on the charger than the battery puts out... otherwise it wont charge that goes for any battery
Dude, there's my car!
Monsi is offline   Reply With Quote
Old 02-25-2009, 08:05 PM   #7 (permalink)
Alarmed & Dangerous
TheViper's Avatar
Optimum charge for flooded cells is 14.4V, AGM 14.7V
