Braille B2015 mounting options?
Greetings all,
I have a Braille B2015 that I'd like to mount in my Elise. I don't really need the S111 Extender option. Is there anything else readily available? I really like the RLS bracket for the Odyssey PC680, but it doesn't fit the Braille B2015. Thanks,
Frank Amoroso Whatever Press Vehicle(s) I'm driving this week www.twitter.com/famoroso Ever take a risk? A real risk? The kind of risk that makes you feel alive? It's... spectacular, isn't it? |
Alarmed & Dangerous
See here
Battery Choices & Information
Thread unraveler
Frank,
Here's how I mounted my B2015. I used the battery bracket from Sector111 as shown. I stuck black foam weatherstripping on the inside of the bracket to avoid having the aluminum contact the battery case (and potentially rub). I also put a 1cm thick pad of dense black packing foam between the battery and firewall. I think if you didn't pad it, it might move around. As it is now, it's quite snug. To get the height just right and to allow clearance for the top padding, there's a washer between the trunk and the S111 bracket. You can just see it in the photo under the bracket. Regards, Jared
2007 Cross Country Travelblog 06 Lotus Elise :: Chrome Orange :: Base :: Black Pack :: TC :: SS 00 VW Golf GLS TDI |
#5 (permalink) | |
That would be... (in the words of Chris Farley)... AWESOME! It is marginally lighter (0.4 lbs per the table here Battery Choices & Information), but most importantly it purportedly has much higher specs for amp hours, cranking amps, etc. More info on the battery: Braille Battery USA - B2015 I was going to purchase one of their mounts and try and mod it to work like one of yours, but their mounting tabs are on the sides of the battery... Braille Battery USA - B2015 / B2015C Aluminum Mount Kit Anyway, if you were to offer a mount (please!) I would happily be the first in line. Thanks,
#7 (permalink) | |
My older, yet still microprocessor controlled, 20/15/10/2 amp Sears battery charger (http://manuals.batterychargers.com/m...-00-000600.pdf) has a setting for 'regular' batteries and well as 'gel cell.' I know the Braille is an AGM type, so which setting should I use? Also, can I use my 500mA Porsche battery maintainer on it if it says 'Charge only Pb type batteries' as per the following pic? Thanks!
#8 (permalink) | |
Alarmed & Dangerous
Frank,
Different battery types have different charging voltages to ensure a complete charge. Wet Cell 14.75V AGM 14.65V GEL 14.55V If you don't have an AGM charger I would charge at the Wet cell rate. Pb refers to a lead based battery which applies to all those above. Michael Quote:
#9 (permalink) |
Ok y'all, NCI is taking a look at a battery bracket for the B2015.
![]() Next step is for me to figure out a way to use the side 'post' mount as opposed to the top 'post' option (as seen in post #4 of this thread). I want the battery cables to lay flat against the front side of the battery (i.e. the top side when the battery is mounted in the Elise 'lying down'). The problem is that there is a gap between the face of the side terminal and the body of the battery of 0.125". How do I fill this gap? Copper spacer? Copper washer (although I'd like to go with a spacer to get the maximum contact area between the battery cable lug and the battery terminal). You can see what I mean by top post and side post (the threaded sections of the terminals that accept bolts) in the first pic and you can see the gap in the second pic. The battery cable would need to sit where the ruler is and I need to fill the gap under the ruler in the pic.
#11 (permalink) | |
| Display Modes | |
