BANNED
Canyon Driving Lights...[aka daytime]
**Anyone with Lotus Driving Lights. If you would like to take control of these little beauties and use them as you like AKA daytime runing lights, great in canyons or just to be seen.....This is what I've done...Locate Driving light relay under dash center, remove relay, remove philips head screw holding relay socket and locate High Beam triger wire [Blue with "small black stripe"]. Cut triger wire 3" from socket and butt splice a wire from Relay socket to" Fuse C3 Audio" in also under dash. Don't forget to tape off old triger wire. Now cut and butt splice between "Yellow and Green stripe" wire going to C3 Audio in fuse.There you go now you have control of your Driving Lights...PS they will turn off when the key is removed......now they can see you coming because you know they watched you leave,,,,,,Do it if you want. You don't need the blessings of know it alls..
insert clever title here
Good info, thanks! How bright are they, though? Do you think it's likely to be an issue driving around town at night (ie, too bright for fulltime use)? Are you able to turn off the driving lights and run with just low beams if needed (there's a separate switch for them, right?)?
Nerd on wheels
Interesting idea..
![]() Driving around with your high beams on all the time (which is what the driving lights are: auxilliary high beams)Would be a highly illegal modification on this side of the pond though. Bye, Arno. |
#4 (permalink) | |
You might annoy people driving around in the daylight with them... ![]()
#5 (permalink) | |
OhioLotus.com
#6 (permalink) | |
Personally, I get a bit annoyed when the SUV behind me has his brights on during the daylight and I have to flip the mirror to the night setting (and I can't see anything else in the mirror). I try not to do thing's that annoy other drivers if I can help it. I do have high quality fog lights installed on my black Miata to function as DRLs. They make me more visible in the daylight and don't blind people with the glare - day or night. But I don't drive around with my high beams on with other drivers around...
#7 (permalink) | |
OhioLotus.com
before? Why are you always so confused Mr Mullin? 'I have high quality fog lights for DRLs' - you're killing me man! ![]() |
#8 (permalink) | |
Thread unraveler
2007 Cross Country Travelblog 06 Lotus Elise :: Chrome Orange :: Base :: Black Pack :: TC :: SS 00 VW Golf GLS TDI |
#9 (permalink) | |
to denote "whatever". Kind of like when I would shrug my shoulders in real life. It could be one way or the other.And my name is Mullen...
#10 (permalink) | |
I'm Lovin' It!
#11 (permalink) | |
I'm Lovin' It!
As just an honest question, not judgemental, why the driving lights instead of just using your headlights? |
#12 (permalink) | |
#13 (permalink) | |
I think the NHTSA information is useful, as it shed some insight as to how the rest of society may view a vehicle with high beams as DRLs.
#15 (permalink) | |
You could always install your own fog lights if that is desired. I have Hella Micro DEs installed on my Miata and recommend them. They are extremely small and you put out a very well controlled fog light pattern. They have magnesium housings to withstand the trapped heat caused from the very small size. But I like my Lotus Driving Lights for use with my high beams - when I turn them on while driving a back road, they really light things up. ![]()
#16 (permalink) | |
#17 (permalink) | |
BANNED
canyon lights
#18 (permalink) |
I'd run with my headlights (low beams) on even during the day. I figure with such a little car I want to be seen!
Why doesn't Lotus offer true DRLs? Like other cars, the high beam may be used, but they only run at something like 50% so they aren't annoying anyone during the day. My Highlander has them and I think they're great. Funny to hear about the recall on those older Saturns. I remember seeing them around thinking, "Why The F--- are those DRLs so Freakin' bright!" I guess GM wasn't running the high beams at a lower wattage for DRLs??? |
#19 (permalink) | |
Elise #76
Owner of '05 Elise S/T- touring- LSS-Stage 2 '07 Audi RS4 4.2L V-8 420 HP - 6 Sp..(sold) '07 Toyota Prius |
#20 (permalink) | ||
If you really want the fog lights, you could possibly mount the DEs into the existing grill without changing to the driving light grill. But I have no idea for sure... Quote:
But the question was how to install fog lights to use as DRLs instead of the Lotus Driving Lights. For that, I'd recommend the Hella Micro DE fog lights. I have them installed on my black Miata for visibility, but for the Elise, I figure that if people can't see my florescent orange Elise, then fog light DRLs isn't going to help... If I'm really worried about visibility, then I turn on the low beam headlights.But I didn't mount fog lights on my Elise - I really like the Driving Lights at night with the high beam on.
