Complete Intermittent Electrical Power Loss - LotusTalk - The Lotus Cars Community
post #1 of 12 (permalink) Old 02-19-2010, 08:15 PM Thread Starter
Flash G's Avatar
While driving today, I lost all electrical power in the Elise. Dash went dead, lights off, radio off, engine power cut... no power anywhere. It happened about 2 or 3 times within an hour and lasted about 3 seconds - then mysteriously comes back on.
I checked the battery connections. They're solid as a rock.
Any ideas? I'm reluctant to drive the car knowing that it may lose all power at any moment.
Turn your flatscreen TV into a work of art.
Modern Art DVD | Plasma Aquarium DVD | Widescreen Fireplace DVD
07 Exige S - Ardent Red, Stage II Exhaust, LSD, Touring pack
06 Range Rover Supercharged - Java Black
06 Range Rover Sport - Java Black
05 Elise - Ardent Red, Stage II Exhaust, Touring pack
Flash G is offline
post #2 of 12 (permalink) Old 02-20-2010, 04:19 AM
Check;
1) The battery cable terminal adapters.
2) Although they are tight, there could be corrosion on the terminals.
3) Could be a loose connection within the battery.
4) There are two studs, a positive and a ground (see below) where ALL outgoing main feeders terminate, could be loose. Positive is in the engine by adjacent to the ECU and the ground is in on the chassis, accessible from below.
SirLotus is offline
post #3 of 12 (permalink) Old 02-20-2010, 04:48 AM
polojcp's Avatar
Also could very well be the infamous A/C relay issue.
like this thread
Engine cutting out
07 Elise Phantom Black
polojcp is offline
post #4 of 12 (permalink) Old 02-20-2010, 05:21 PM Thread Starter
Flash G's Avatar
Thanks guys. Will check out both and let you know what I find.
Flash G is offline
post #5 of 12 (permalink) Old 02-21-2010, 12:11 PM
ChrisH's Avatar
Or it could be a bad ignition switch. I had that problem on my 1998 Honda Accord. Honda even did a recall on it.
ChrisH is offline
post #6 of 12 (permalink) Old 06-13-2010, 02:44 PM Thread Starter
Flash G's Avatar
SO the problem reappeared yesterday. While driving down Wilshire blvd, I flashed my high-beams at a passing car and the entire car went dead. The electrical power came back on in about 5 seconds.
About a half hour later I went to turn the lights on and the car died again. Power popped back on after I slammed the driver's side door.
Any ideas? I've tried everything.
Flash G is offline
post #7 of 12 (permalink) Old 06-17-2010, 04:46 PM
Backpain's Avatar
I had this issue when I first got my car, the only difference is my gauge cluster went nuts as well. I brought the car in and they said it was a firmware issue with the cluster and they had a flash/fix which didn't require a replacement cluster. It might have been a line of BS but whatever they did, it worked. The car has not shut off and lost power since. Here's my post from last year about it.
"When driving the car yesterday I looked down and my gauge cluster was totally dead with no tach, speedo, or anything. I had read here about this happening on some new cars I think. The messed up part is I figured it's an electrical problem so I turned on my headlights to see if those still worked, when I did the whole gauge cluster lit up like a x-mas tree with everything on for a second and then off again, then the tachometer started to work and the ABS light was on. At this point I didn't know if I should pull over and get it towed or keep going.. I drove for another mile or so just going off my rpm since I know what speed I'm going at 4k, all the sudden the bottom half of the cluster comes on and I can see my mileage again and the trip OD. At this point I figure it will be ok to finish the drive home, well I drive for another 10 miles or so with no speedometer when all the sudden i lose all power to the car and it felt like someone turned the key off, this lasted about 5 seconds and then pop, the speedometer starts working with all the other cluster operations but the ABS light was still on.I drove the car off the highway and shut it off for 20 mins, then restarted it and the cluster was working and the ABS light has now turned off"
2008 Persian Blue Exige S240/2014 Quad cab Ford F-150 Fx4 Ecoboost
Backpain is offline
post #8 of 12 (permalink) Old 06-17-2010, 05:23 PM
I am thinking it is the ignition switch.
SirLotus is offline
post #9 of 12 (permalink) Old 06-19-2010, 11:37 AM Thread Starter
Flash G's Avatar
But this would only explain power loss to the gauges, engine, etc... The ENTIRE car loses power as if someone disconnected the battery. Not even the interior light works when the power mysteriously goes out.
Flash G is offline
post #10 of 12 (permalink) Old 06-19-2010, 11:39 AM Thread Starter
Flash G's Avatar
Do you recall any technical service bulletin about this that the dealer may have mentioned?
I'll probably wind up taking it back to the dealer, but I don't want them to go on an electrical fishing expedition replacing components until they find the problem.
Flash G is offline
post #11 of 12 (permalink) Old 06-19-2010, 11:53 AM
If the lights are going out too then it has to be a battery or battery connection issue. Connection within the battery, connection at the battery or in the main cable, either positive or ground, see diagram above for ground cable to chassis connection. This is my best guess.
SirLotus is offline
post #12 of 12 (permalink) Old 06-19-2010, 12:01 PM Thread Starter
Flash G's Avatar
I checked that before, but I'm going to go through it all again.
Thanks for the diagram!
Flash G is offline
Human Verification
