Regurgitated User
custom fitfan voltphreaks bracket
so i figured if i shot 450 bucks on a battery, it deserves a fancy smancy bracket! ....out went the steel - in went alumn!!
i went to home depot, got some flat alumn stock, and with nothing more than a vise, torch, hammer, some pliers, drill and some filing to clean it up here it is ![]() i made a bracket to replace against the wheel well and a new bracket on the trunck floor - these pass a #10 bolt and allow the clamp to be drawn down on both side. I covered the bracket with a bicycle inner tube to protect and grip the battery. finished it off with some thumb nuts to make it easy to tighten up at tech inspec. i lined the "bed" of the battery with industrial velco, and matched it on the battery. i like it - i like the battery! 4.5 lbs... its no joke - and my car started up alot better than before, guess my going on 40 month old battery was getting weaker than i had noticed. no leaks from it though... just heavy. Cheers, -Rod Thing is rock solid!
Driving it around!
Regurgitated User
thanks - yeah "it aint going anywhere"
the bracket keeps is pressed down into the velcro, and the velcro has crazy monkey kunfu hold of it. i am going to rig up a little plastic box to cover up the terminal ends later. i know some people have this battery - so wanted to share how i installed it - 100% reversible, and better than stock.
Driving it around!
Regurgitated User
$100 a pound, or a lot less $ than the weight savings of a muffler...
past the drivetrain there are really only 2 things back there - battery and exhaust. i agree, it is STUPID money for a BATTERY but i got if to shed 24bs - so for lossing that weight in the tail - it is a bargin! ...weird huh?
Driving it around!
#7 (permalink) |
McLareghini Bugatterrari
What is the sheer force required to overcome crazy monkey kunfu hold?
xtn
#8 (permalink) | |
![]() ![]() ![]() ![]() BTW... I like the bracket. I need to do something like that for mine. ![]()
2006 Lotus Elise - Solar Yellow, HT, LSS, LSD/TC, Touring, StarShield, S111 RTDbrace, S111 microMirror, S111 Carpet Buttons, Painted A/C Surround, CF Center Console, Nitron S/A, Tempest BAB26-12 AGM Battery, Fujita Intake, Top Speed Pro 1 Exhaust, 4Tress Harness Bar, 6000k 35w HID kit, Moroso Oil Pan, Plinthless front clam, Team Dynamics Pro Race 1.2 Wheels w/ RE01-R's for street use, Heater Core By-Pass, Shifter Reinforcement, LETSLA v2 Shift Kit |
