Prez: The K.G.B.
dead battery charging
This question is about my Miata, but probably covers the Elise too.
The interior lights on the Miata were left on over night and now the battery is very, very weak. So weak that the engine won't start and the dash lights are low. If I jump start it and drive the car around for about 2 hours, will that charge the battery enough that it won't have to be replaced? BTW, the battery itself is only about 3 or 4 months old. Thanks.
2007 Exige S265 - Krypton Green - Gotham 265 ECU - Volk TE37s - Toyo R888s - B&M Shifter - QuickSilver exhaust - stripes - harnesses - Pagid pads - Green air filter 2002 Jaguar XKR convertible 2000 BMW 528i President - Lotus Limited Southeast http://autos.groups.yahoo.com/group/LLSE/ |
#2 (permalink) | |
That will charge the battery but the alternator is a fast charge and not as good for the battery as a slow charge. I have found that a regular car, motorcycle, jet ski battery can get away with one really deep discharge and still last fairly long. The second deep discharge usually diminishes the capacity to where it really needs to be replaced. A deep cycle battery like an Odyssey or Optima is built to take repeated deep discharges without damage.
Prez: The K.G.B.
So I'd be better off buying a trickle charger and charging it overnight?
#5 (permalink) | |
not a Mod, just an Admin
Doesn't anyone use hydrometers anymore? Voltage is different than potential. The problem with a quick charge vs. a trickle is the heat produced. That heat boils the battery and converts water to O2 and H2. If you monitor the battery temp and replace the water, what is wrong with a quick charge?
#7 (permalink) |
Thread unraveler
I thought stock Miata batteries were gell cells that could be deep discharged. But I don't know if they got away from this on later versions.
2007 Cross Country Travelblog 06 Lotus Elise :: Chrome Orange :: Base :: Black Pack :: TC :: SS 00 VW Golf GLS TDI |
#9 (permalink) |
Prez: The K.G.B.
This is a replacement battery from Advanced Auto Parts, made for a wide variety of vehicles.
#10 (permalink) |
Original OEM Miata batteries are AGM (Absorbed Glass Matrix or something like that) batteries. They are completely sealed (although they have vents attached in case they are overcharged and "blow" gases. Miata's use these sealed batteries since they are mounted in the closed trunk of the car (like the Elise's). Some after market batteries (WestCo and ones sold specifically for the Miata) are also AGM. Some vendors (including Mazda) sell replacement wet cell batteries - then need to have vent hoses attached to vent the gases that will be produced to the outside of the car (the standard Miata vent tubes).
The advantage of the AGM batteries is the total absence of gases and any related corrosion. The disadvantage is that they don't take a charge very quickly. If the battery is drained, you can often jump start the car, but after driving it, the battery will not be charged like it would be with a regular battery (which is why Mazda uses a wet cell replacement so they don't get the normal customer complaining). AGM batteries need to be charged at a slow rate for a long period of time. Usually around 1 amp (or less) charge for 24-48 hours after being discharged. Once recharged (at a slow rate), the battery should be back to normal. Instead of buying a trickle charger, buy a BatteryMINDer or Battery Tender Jr. and use that to charge the Miata's battery. They are designed to do the slow charge and then to monitor and maintain that charge for long periods of times. Trickle chargers simply slow chargers, but if left on for too long, will overcharge and "cook" the battery. If the battery is an relatively recent aftermarket replacement battery that is specifically called out for the Miata, it is quite possible that it is an AGM battery. If it's a general battery, then it may or may not be AGM (probably a wet cell). In either case, make sure that it has vent tubes attached, and if it doesn't have vent fittings, replace the battery with a battery that does have them (preferably an AGM battery)...
#11 (permalink) |
Yah mon, it's irie !!!
Similar problem ... I think.
I tried to start my E this morning after it had sat for the last 2.5 weeks in the garage. I just get a clicking noise from the starter but no turn over. Just a weak battery? I'm thinking I go ahead and try a jump start and drive around for a few hours. Should that work OK for me? I'm a mechanical idiot and have never had a battery die on me before. Any reason the battery on my E would crap out so fast after only a couple weeks? |
#12 (permalink) | |
I took the battery out of the car and it appeared to be frozen solid (mind you this was in near-zero F temperature). I assumed the battery would be toast, but I figured I'd try to see if I could resurrect it. I let it warm up overnight and then began charging it (at a 2 amp rate). I suspect the battery is a little weaker than it used to be but it's still going fine. I had no problem starting the car last month in low single-digit temperatures so you might be allright Mick. Is your battery also an absorbed glass mat type? I think most Miata batteries are of this type - I couldn't even buy an aftermarket Miata battery from Sears or local auto parts stores.
Alan '05 Elise, Magnetic Blue |
