#21 (permalink) |
Ok, for those of us out of warranty when this happens, how do we get Lotus to pay??? Should I start a "Official Door Lock thread" to find out how many of there are of us?
Lotus should pay for this, maybe it should be a recall or "campaign" as they like to call it. Make sure you save your receipts for future reimbursement. I believe the job costs about $300-400 as the part is $90 and then 2-3 hours taking apart the dash. This part should not be "going" in a 3-5 year old car, ESPECIALLY, since we probably only open/close the car about 5-10% a normal car. So technically, if you used your Elise everday, this part would have broken within the first year?!?!? LUCAS is that you?!?!?! Sorry for the rant. I'm also having an AC issue where it won't keep a charge. |
#23 (permalink) |
the devil's advocate...
just noticed this thread... if both door locks exhibit the same problem (e.g. bloth locks are sluggish) then its not a mechanical problem and probably not a problem with the CDL module.. the signs point to a supply (current) problem. This means that the CDL circuit is not getting enough power to move the lock solenoids and could be a grounding issue, a wiring/connector issue or a supply side issue ( e.g. problem at the fuse.)
the way to resolve this (also with any of the other various CDL problems here) is with a little bit of testing with a voltmeter... the guess and replace method is only going to waste money. check pins 9 and 10 of the CDL for 12v and ground. (10 should show 0 ohms to battery ground and 9 should show greater than 12v.) |
#24 (permalink) |
Hydrocarbons Rule
The one I ordered shipped last week, so I should get it some time this week... I'll post in this thread as to if it fixes the problem or not once it comes in... It will only take me about 15 min's to swap out with the EU dash, so I'll be doing it the day it arrives as long as it's not raining.
#25 (permalink) |
Hydrocarbons Rule
CDL came in today. I swapped it out and YAY!
MY DOOR LOCKS WORK!!! 4-5 weeks of manually locking them was starting to become quite the pain in the a$$. Especially when you have your hands full of $hit.
#26 (permalink) |
Alarmed & Dangerous
Great news
Probably too late, but it would be great to post photos of removal of the top of the dash and location of CDL for future reference, as this keeps popping up.Michael
#27 (permalink) |
Hydrocarbons Rule
My car's EU spec so it has a different dash. Evidently it's WAY easier swap on my car than the FED models. It literally only took me about 5 min's.
#28 (permalink) |
Alarmed & Dangerous
But didn't you have to remove the dash top?
#29 (permalink) |
Hydrocarbons Rule
Nope... Just remove the speaker cover/Light switch piece then move the air vent tube out of the way and it's right there behind it... Not to difficult on my car.
Behind this... (not my car) Mine has a air vent instead of the hazard light switch and the light switches are mounted more towards the door pannel. I still haven't found where the alarm unit is mounted on my car yet... I need to find it so I can do the antenna mod and have more than 5 ft of range. Edit: This is my car. I also have my navigation / radar detector / notifies me when a police cell phone in the area is in use / notifies me when police frequency radio in the area is in use / notifies me of speed trap areas / tells me where the traffic cameras are etc unit mounted to it... It kicks butt ![]() ![]()
2006 Exige; BWR Supercharger, Adj Sway Bar, Ohlins Suspension, BSK Oil Catch Can, Moroso Oil Pan, ORC Clutch, Custom Exhaust, Black Volk Racing CE28N's w/ Toyo R1R's, 2 piece rotors, Pagid Blue Pads, BSK Wet Carbon (Side Skirts, Front Lip Spoiler, Gas Cap Cover, Center Console, Door Panels), Dry Carbon rear Diffuser, Harness Bar, BWR Gauge Mount, OMP Superquadro steering wheel, LETSLA Short Shifter, V2arms, Rear Tow Link Brace, RLS Battery Bracket, BOE Tow Bar, Stickers. Last edited by Dragon : 06-03-2009 at 06:42 AM. |
#30 (permalink) | |
Alarmed & Dangerous
I guess it would be easier on EU spec cars as the dash is different, with the speakers on top. I am also wondering if the CDL is on the left side in a U.S. car.
Michael Quote:
#31 (permalink) | |
SE Georgia
In an effort to give back just a small amount of the knowledge I have gained from this group over the years, it is my intent to document and photograph my dash removal and CDL module replacement. I know there are other posts with dash removal photos, but I figure a post specifically devoted to the apparently common CDL problem wouldn't hurt. My car is still under warranty, but the nearest dealer is 4 hours away, plus I kinda wanna do it myself . Only hitch is that I spent pretty much all last weekend (which happened to be my 6th wedding anniversary ) installing oil temp and pressure gauges. I think I'd rather try to teach chinese to a monkey than do that again. So I'm not sure if I can get to it this week. Anyway, that is my intent. |
#32 (permalink) |
SE Georgia
CDL Module Replaced - Success!!
Replaced my central door locking module last night on my '06 Elise after my doors locked but refused to unlock with the fob or central switch. The problem was definitely the CDL module and now everything works fine.
I used the excellent dash removal instructions from Buzzy, which were very detailed and easy to follow: (My Dash Removal Instructions) The problem is that Lotus bolts the CDL module in almost the most inaccessible place to the far left side of the car underneath the dash top. I couldn't even see it at first after I took off the dash. It is hidden under a wad of foam padding that separates the dash components from the fiberglass body and also an immovable a/c vent tube. The padding is very stubborn and I could only move it a little before seeing the edge of the module box. The good news is that the wiring harness plugs in from the driver's side, so it was easy to unplug. I removed the retaining screw and washer from one side of the old module, but found it impossible to get to the other screw due to its inaccessibility. I ended up simply leaving the old one where it was. I wedged the new box in an almost perfectly fitted groove behind the instrument panel, using double-sided trim tape to wedge it in good. Next time the CDL fails (which I expect it will after another mere 12,000 miles), I should be able to access it by simply removing the driver's side cubby. I am still wondering why a) Lotus continues to use a CDL module that apparently fails regularly and b) they installed it where it is, rather than placing it in one of the many more accessible spots inside the dash. Overall, the project cost ~$85 for the new module and about 6 hours of time. Hope this helps anyone who wants/needs to do this themselves. |
#33 (permalink) | |
Hydrocarbons Rule
I'm also now very happy I have an EU version / dash... Now if I could only find where the alarm unit is mounted so I can pull out that antenna wire so I can use the remote from more than 2 ft from the car.
#34 (permalink) | |
Alarmed & Dangerous
#35 (permalink) |
Hydrocarbons Rule
Yes, just need to pop the vent air tube out of the way and push it off to the side so you can reach threw... It's in the right corner under the dash... You have to watch out for all the sharp stuff though...
#36 (permalink) |
Alarmed & Dangerous
Dragon, your dash is different from us "normal" owners here in the U. S of A, I was actually hoping D Britt would respond
![]() Michael
Cobra OEM - Alarm, Immobilizer, CDL Emergency Override with warranty Additional Emergency Touch Keys - see link above Brand New Cobra Alarm Remote with warranty Cobra Remote Key Fob Strap Cobra Window Closing Module - Add to your existing Cobra alarm 3 Piece Front Clam Protection Kit with Center Bumper Undertray Removal Tool INFORMATION Improved AC & Heating System Battery Choices & Information Remote Key Fob, Alarm & Immobilizer Programming Light Bulb Conversions 2005 Last edited by TheViper : 06-10-2009 at 04:31 PM. |
#37 (permalink) |
AR #1275
My wife's daily driver - a Camry exhibited the same problem. I can hear/feel the solenoid moving and trying to move the lock to the open/lock position but could not move it enough. I took the inner door panels off and with a blast of wd-40 into the lock mechanisms while using the door lock controls to actuate them dramatically freed up the movement and it's worked since then - almost 1 year ago.
'06 Ardent Red Elise - black interior with LSS, Touring, HT, Starshield, Lotus Sport Clutch, Moroso Oil Pan, 2ZZ(#2), Ekological HIDs, Lotus Driving Lights, Stebel Horn, Bootie, Razo '06 Pedal mod,Snorkel Delete,Odyssey 680 with s111 bracket. Future Mods:LETSLA (ordered), Rear toe link brace Thank you FVMC! ![]() WOO-HOO!
#38 (permalink) | |
burning bright!
I just had this problem too. It's much worse when it locks but doesn't unlock, trust me. It was late in the day, I was in Brooklyn, it was raining, and I had the roof on and windows rolled up. Luckily I was near Ft. Hamilton, so I went to the PX and bought pliers, some hangers, and picture-hanging wire. I made a slip knot with the picture wire and guided it onto the passenger locking post with the hanger wire (the hanger wire alone wouldn't grip the little groove on the post adequately).
It's definitely not a problem with the alarm itself – that arms and disarms just fine; moreover the CDL console button locks, but also will not unlock, the doors. Has anyone had success fixing this problem? I'm guessing I'll need to replace the CDL module, but I'd like to hear what's worked for others. ~T Quote:
#39 (permalink) | |
Alarmed & Dangerous
Almost certainly the CDL module, sorry.
Michael Quote:
