#41 (permalink) |
Yes.
* V E R I T A S * A E Q U I T A S * No Longer the ADMIN here, please do not PM me asking for help. Thanks! http://www.facebook.com/randychase 1991 Toyota MR2. AutoX Beast 2006 Noble M400. Track weapon. 2009 Rossion Q1. Monaco Orange. Canyon Carver. In build: 2009 Toniq R (300whp? 1100 pounds?). Chrome Orange. Lexus GX-470 tow vehicle. On Order: Lotus Evora Next: McLaren MP4-12C |
#42 (permalink) |
Big head man
Well, got my driving lights installed.
Thanks Randy for your help over the weekend. Next time feel free to tell me that I should consult the owners manual (found the description of the turning signal removal in there after getting help from you). Thanks Tim for your excellent write up. Thanks to who ever it was that wrote the desciption of installing the relay. I would have been lost without that. They look and work great! |
#43 (permalink) | |
At least on mine, there feels like there is a "catch" that I find with the rod/screwdriver, but when I push, nothing happens. It appears that the actual "catch" is slightly behind that one (at least on mine). Once you get the right spot, it pops off easily without having to push hard at all. If you have to push hard and nothing happens, you probably need to move the rod/screw drive slightly back and try again. There is definitely a feeling of satisfaction when you get them loose... It's one of those things that is so simple, it can be frustraiting...
#44 (permalink) |
One of my is very easy. Put slick tires on the car. Drive at 60mph. Slam on the brakes. Out it comes!
#45 (permalink) |
Head LOONY
Thanks for the excellent write up. I am going to buy these and install them.
Tony Vaccaro 2005 Ardent Red, Katana Supercharger, Touring, Hardtop, Driving Lights, HIDs, Rear Window Shield, Red Mounts, Laser Shifters, V1, LETSLA Shifter, www.lotusowners.com LOONY (Lotus Owners of New York) and the Church of the HolyLotus Supplier of Polycarbonate Shield for Rear Window IN STOCK , Drive Fast Take Chances |
#46 (permalink) |
Head LOONY
Did my lights today. Tim's thread and pictures helped a lot.
My only hang up now is that they only gave me 2 of the small screws that mount the lamp to the bracket...the smaller ones.. Oh well..that is Lotus and I will go out and try and find some tomorrow. Took me about 2 hours. I had the same problem as Tim. The lip on my turn signal catch is thicker that the other side. Also...why the heck do they tape the wires so out of the way. It took me a while to get them loose. Is the spot for the relay under the dash? I think I read that somewhere in Tim's instructions. I will install the new panel tomorrow and test the lights. Thanks Tim.
#47 (permalink) |
Big head man
The relay is described in the instructions to be under the dash on the passenger side. It is not. It is on the driver's side, near the middle. You do not need to remove any relays that are already there. Find the blank spot and stick it there.
My car both sucks and blows. Now with added all natural smoky goodness!
#48 (permalink) |
AR #1275
For the relay - mine ('06) was on it's own little box meant for just 1 relay. Accessible from the driver's side and near the middle.
'06 Ardent Red Elise - black interior with LSS, Touring, HT, Starshield, Lotus Sport Clutch, Moroso Oil Pan, 2ZZ(#2), Ekological HIDs, Lotus Driving Lights, Stebel Horn, Bootie, Razo '06 Pedal mod,Snorkel Delete,Odyssey 680 with s111 bracket. Future Mods:LETSLA (ordered), Rear toe link brace Thank you FVMC! ![]() WOO-HOO!
#49 (permalink) |
I thought I posted this in this thread, but apparently I never got around to it. The two screws that you need to remove to get the light panel out of the car are not Phillips head screws, they are Posix Head Screws. They are close to Phillips and Phillips screwdrivers usually work, but it will be easier and the tool will fit better if you use a Posix bit in your screwdriver - the difference is that the Posix bits are not quite as pointy and the cross blades are a bit thicker. Using a Phillips on a Posix increases the risk of stripping the screw head, but for small light duty screws like this one, you probably will not notice the difference.
If you don't have any Posix bits, you probably ought to gets some if you plan on working on the Elise - there's a lot of them on the car.
#50 (permalink) |
Oh, NOW I get it!
On a federal car, the driver side IS the passenger side, so it seems you have to reverse the instructions regarding the relay.
I tried omitting the switch panel and the lights would not come on, so if you are wired for the switch you have to put it in. (I would always leave it on.) My mounting brackets were preinstalled, which is good, because I would have thought I screwed it up if I installed them like that. They used the funny looking crush washers at the factory. The first ridge under the signal lights is the fiberglas body. Feel that first and then go lower to find the proper place to push. Final note, the new switch for the driving lamps is a tight fit into the dashboard. It is longer, due to its "memory" and it HAS to go there. It will fit if you flex the panel as you insert it. WHEW! (What an easy install! ) |
#51 (permalink) |
Alarmed & Dangerous
Maybe this will help
#52 (permalink) | |
Head LOONY
#55 (permalink) | |
Sears has a three bit set: The first photo show the difference between the drivers, the red arrow points to the "rib" on the posi driver. The green arrow points at the tapered end of the Phillips - not the Posi blades don't taper to a point as the Phillips blades do. The second diagram shows various types of screw heads. Note the small square where the blades cross in the center of the Posi, and the "tick marks" between the blade slots.
#56 (permalink) |
Alarmed & Dangerous
On Sale tomorrow only
On sale at Sears tomorrow, Saturday 5/19 only.
On line it is $34.99, in store $29.99, Sale $14.99 83 pc. insert bit set of insert bits includes: 1 and 2 in. Phillips, square, Pozi, slotted and Torx insert bits and nut drivers for most household projects.
#57 (permalink) |
Does anyone have some good ideas as to how to get the plugs out, without having to take the clam off? I got the passenger plug out with no problem... the driver side is another story. Whoever put this thing in was extra sadistic. The wire was taped just like the other side, but it is wrapped\taped to further down to what almost looks to be the depth of the nose badge. Now I admit that I workout and I am no spring chicken, but I there is no way I can even get 1/4 of my forearm into the turn signal hole. I am think about a long rod and a light coming through the other side to poke at it...
Dan |
#59 (permalink) |
Oh, NOW I get it!
That seems to be what everyone finds. The tape must be removed first.
I freed the closer end and kinda pulled down, tucked under and pulled down again. To finally unravel and free the plug my wife and I each poked from opposite ends with long screwdrivers. Even her arms were not thin enough to reach in very far. We did it in one session. Don't give up. |
#60 (permalink) |
Still no luck on the wire... it looks like I am going to have to remove the clam to get to it.
I looked at the mounting brackets and I do not see how the lights mount to them. Are they different (right\left)? Is there a spacers that need to be installed between the brackets and the car? The holes on my brackets are so close the the car the light bracket will not go behind it and line up with the hole. |
