#61 (permalink) |
Big head man
I would do anything not to remove the clam. There must be a way to reach it, a wire hanger, or like I said, a spring loaded grabber (I got mine at Sears).
The lights hang beside the brackets with the bolts entering on either side. Make sure you took the grill off, right?
My car both sucks and blows. Now with added all natural smoky goodness!
#62 (permalink) |
I have a grabber, and it can not pull the wire and it can't really do anything with what is holding it up (I can't really tell what is holding it.
I took the grill off and have the brackets mounted on the crash structure and I was trying to get the lights, with the new brackets to mount to the bracket on the crash structure. The instructions for these things is a joke and my car must be special. |
#63 (permalink) | |
Big head man
I agree, the instruction are a joke. Speaking of which, when it tells you to install the relay under the passenger side, it's not, it's just to the driver side of the A/C under the dash, just put it in the only open site.
#65 (permalink) | |
GR8 SCAPE
I really hope you don't have to remove the clam. That's major! Hope the pics help. Regards, Wayne
_______________________ '05 Elise Magnetic Blue, Black, Touring, Hard Top, Star Shield, Stage II Exhaust, Arqray decat pipe, S2 Front Splitter (UK), Sector 111 Rear Tow Hook, Driving Lights, De-Snorkled, K&N Air Filter, Shift-I System, LSS Dampers & Springs, Sector 111 V-Bar, Schroth Profi II 5 point harness, Exige S Probax seats, 1/4 turn undertray screws, Stealth bulbs, BWR SC with PES tune, Innovative engine mounts, SS brake lines. |
#66 (permalink) | |
#67 (permalink) | |
Richard Williams '06 Chrome Orange Elise - LSS, Touring, Hard Top, SS, CO A/C Surround, Track Pack Shocks, Cup Airbox, Manley's Motor Mount Inserts, Lotus Driving Lights, Stage II Exhaust, Larini De-Cat Pipe, 4Tress Bar, 5 lb. Battery, Pagid Blues, HIDs, Micro Mirror, Carpet Buttons |
#68 (permalink) | |
GR8 SCAPE
I used a mirror and a flashlight to actually find and see the connector. I then used a long X-Acto knife to slice the tape and pull out the connector. Regards, Wayne
#70 (permalink) | |
#71 (permalink) | |
GR8 SCAPE
They clearly did not want this thing to come loose in the course of driving the car! Regards, Wayne
#72 (permalink) | |
As for the brackets, the mounting bracket that comes on the lights must be removed, and replaced with the one supplied by Lotus. This bracket mounts to the bracket that's attached to the clam. Early cars didn't have this bracket attached, and, in my case, I had to mount the bracket that came with the kit. The photos in the beginning of this thread should show the proper brackets...
#73 (permalink) |
I took the light bracket off the lights and attached the new ones. My car did not have the brackets attached to the car either, so I attached them too. I then went to put the two brackets together and the crash structure will not allow the holes to match up. I can get the out holes, light side, to line up though I can get the bolt in. The other, towards the center of the car, has a piece of the crash structure in the way. The welded on nut will not allow it to slide up into position.
I may have to wait until July to install these... ![]() |
#74 (permalink) | |
The bracket on the light is mounted with the nuts to the rear. The bracket on the crash structure hangs down so that you slide the light bracket up behind, and insert the screws from the front. If you are hitting the crash structure, you might want to loosen the bracket mounted to the crash structure, let it drop down lower and then tighten it in place. That should allow the light bracket to clear the structure.
#75 (permalink) |
ZAMMY
at this point i notice that my brackets are mounted, i've released the two sockets so they can hang down the front. (i have the front clam off....that's another story)
where do the two cable/sockets go, will it be obvious when fitting the clam back on the car? there must some space where people can thread the cables down with the clam on. thanks, sam |
#76 (permalink) | |
#77 (permalink) |
Ancient Briton
I finally got round to installing mine yesterday, but not without some bad words, despite the excellent advice in this thread.
The first problem was getting the connectors out. The passenger's side was easy, but the driver's side connector was well inside the clam, and had hung up on something. I got all the tape off, then wiggled and jiggled and cussed, then jiggled and swore some more and it finally came free. Installing the relay and switch was easy - mine's a later '05 with the switch wiring in place, but mounting the lights was also a pain. I'm not sure if the crash-structure brackets, which are pre-installed, are mouted a fraction high, or if the clam sits a bit low, but there was no way my thinnest, spindliest 4mm nut driver would pass between clam and light, particularly to access the outer screws. However, I could make clearance by pressing the lip of the clam up, and then by good fortune I pushed up underneath the bottom of the clam (the bit that grounds on high kerbs) and space appeared. At this point, though, I was running out of hands. One held the light, another the nut-driver, and I needed a third to lift the clam to give clearance. With much trepidation and extreme caution I slid my trolley jack under the clam, with a bit of 5/8" plywood to spread the load, and gently jacked up the clam about 1/8 to 3/16" - just enough to get the screws in and tightened. There was enough "give" to allow me to do that, and when I lowered the jack, all was well. Thanks again Tim, Randy & Co! |
#78 (permalink) |
Mt. Diablo Hiker
Hey Roger and anyone else,
Are these lights still available. I've always wanted to install a set on my early 05, but haven't seen them for sale anywhere. I could always call one of the dealers, but anyone know if they are available online anywhere? Thanks And thanks for the info on the install. I'm not sure if I have the balls to jack up my clam. Steve
05 BRP Elise 08 BMW 335i 97 E36 M3 / 01 Dodge Durango 90 300ZX / 85 Toyota Cressida (with velour seats) and son's red 08 EvoX (The Acura type S met a brutal end) |
#79 (permalink) | |
perfututum futūtor
#80 (permalink) | |
If you have a very early (i.e. non-"pre-wired") car, then you probably don't have the mounting nuts pre-installed either (again, I didn't). In that case, you have to use a bolt and nut as described in the beginning of this thread. Later car were supposed to have the "nut-zerts" already installed in the crash structure to make it easier.
