Old 10-26-2009, 01:21 PM   #1 (permalink)
06 elise
MNlotus's Avatar
Elise headlight problem
i got HID's installed about two years ago, but about a year ago it started cutting out. when i turn on the ignition, the light comes on every time so the bulb must still be good. but when i actually push the start button it flickers out. The only time the light actually works is when i shut the car down and turn it back on after driving for a while.(like 30 mins) i just got a floor jack so i can take off the inner wheel lining now. any one have any ideas? i really dont want to buy a new set of HID's. heres a video of it too, to help.
2006 Lotus Elise-way too many mods to list (k24 swap planned. 300+whp)
http://www.youtube.com/watch?v=tjIcCsvhWvY
2003 Caterham Super Seven DeDion
http://www.youtube.com/watch?v=Z1ysO...e=channel_page
MNlotus is offline   Reply With Quote
Old 10-26-2009, 01:49 PM   #2 (permalink)
Alarmed & Dangerous
TheViper's Avatar
Seems like a voltage drop problem. What happens if you only turn on the lights after you have started the engine? As it recently started, I would look for loose or corroded connection on the lights that may be causing a high resistance.
Old 10-26-2009, 06:51 PM   #3 (permalink)
06 elise
MNlotus's Avatar
i cant turn on the lights after the engine has started, as soon as i turn on the ignition they automatically turn on and stay on.
Old 10-26-2009, 07:01 PM   #4 (permalink)
Mods are good for you
Dave's Avatar
I just replaced my driver side HID that was doing the exact same thing...ended up being a bad ballast which is not uncommon. Easy enough to test by swapping your lamps. You can p/u a complete set for @ $65 from dabears2k.
2008 Solar S240 Exige
2005 Saffron Elise - BOE TVS Supercharger 291WHP w/ EFI Engine Mgmt
Dave is offline   Reply With Quote
Old 10-26-2009, 07:01 PM   #5 (permalink)
Alarmed & Dangerous
TheViper's Avatar
Interesting....has it always been that way, as it sounds rather unusual.
Old 10-26-2009, 07:06 PM   #6 (permalink)
06 elise
MNlotus's Avatar
it has always been like that, the HID's are the daytime running lights too.
to replace it do i just switch the bulb and that it?
Old 10-26-2009, 07:18 PM   #7 (permalink)
Alarmed & Dangerous
TheViper's Avatar
As Dave said it could be the ballast but if both are going out that would seem unlikely. Same applies to the bulbs. Could also be a bad relay in the SPM, do your side lights go off too?
Old 10-26-2009, 11:33 PM   #8 (permalink)
Baysailor's Avatar
As MNLotus said, the headlights are the daytime driving lights on 2006 and above, so they come on when the ignition is first switched on. They then cycle back off during the start and back on again once started. That being said, it is VERY HARD on HIDs for them to be cycled like this (allowed to come on, then cut off and then then back on again). I have HIDs too and what I do to get around this cycling is I push and hold the start button while switching the ignition switch on, letting go of the ignition switch once it has started. It is a very smooth easy process and has become habit for me now. Alternatively, you could do the green wire mod which would permantently disable the daytime driving lights, but I like having DRLs.
I have also been considering installing a time delay relay on the green wire. This would allow time to start the car in the conventional manner and then would "connect" the green wire back thus switching on the DRLs. Alternatively you could set the relay to trigger off of the parking brake... basically it would function where by when the parking brake was engaged, the relay would "disconnect" the green wire. When the parking brake was released, the relay would "connect" the green wire.
2006 Lotus Elise - Solar Yellow, HT, LSS, LSD/TC, Touring, StarShield, S111 RTDbrace, S111 microMirror, S111 Carpet Buttons, Painted A/C Surround, CF Center Console, Nitron S/A, Tempest BAB26-12 AGM Battery, Fujita Intake, Top Speed Pro 1 Exhaust, 4Tress Harness Bar, 6000k 35w HID kit, Moroso Oil Pan, Plinthless front clam, Team Dynamics Pro Race 1.2 Wheels w/ RE01-R's for street use, Heater Core By-Pass, Shifter Reinforcement, LETSLA v2 Shift Kit
Baysailor is offline   Reply With Quote
Old 11-11-2009, 08:04 PM   #9 (permalink)
06 elise
MNlotus's Avatar
well thats great. i just wasted $150 on new HID's just to have the new one do the EXACT same thing. Any ideas now!?
Old 11-11-2009, 10:09 PM   #10 (permalink)
Steers and Queers
Have you checked all your connections where you're splicing into your wiring harness?
kabob is offline   Reply With Quote
Old 11-11-2009, 11:13 PM   #11 (permalink)
fm78.tv - check it.
Serebo1's Avatar
Images: 4
Disable DRL and turn on HID's only after engine is started?
Matte Black, Sport, Touring, ***** intake (TBA), RAC Mono wheels, Painted Shift knob, smoked turn signals, Alpine SPS 6.5" rear speakers, MB Quarts, JVC Nav, Starshield, LBH exhaust, Dpic perf. gauge, Custom true HID projectors, GUT wing and splitter, Mesh side pods, Sector111 harness bar and 4-point harness, Lotus Sport Ohlins double-adjustable suspension, swaybar, '06 LED tailights, Toda flywheel, Lotusport interior.
Serebo1 is offline   Reply With Quote
Old 11-12-2009, 05:03 AM   #12 (permalink)
06 elise
MNlotus's Avatar
they are completely new HID's and were installed by the local lotus dealer. i did try what BAYSAILOR said earlier, pushing the start button and then turning on the ignition and that seemed to work. i think im gonna do the green light mod though and see if that works. So once i disconnect the green wire, which button in the control panel would i use to turn them on?
Old 11-12-2009, 07:29 AM   #13 (permalink)
glb
Unattractive Nuisance
glb's Avatar
just in case, there's no need to lift the car to remove frt fender liner; turn the steering wheel all way over, plenty of room.
Lazily,
glb
Old 11-12-2009, 07:48 AM   #14 (permalink)
06 elise
MNlotus's Avatar
yeah that would give you room, but i like having as much room as possible
Old 11-12-2009, 09:50 AM   #15 (permalink)
perfututum futūtor
RoadDad's Avatar
MN,
You would still push the second button from the top to turn them on.
Me... I don't need to.
Bite me." -Randy
