Old 10-11-2005, 10:48 PM   #1 (permalink)
Talking Emergency Unlock Switch – Easy Mod Pictorial
A few of us have had door lock and alarm unlock issues. Here is an easy mod that shows how to install an emergency unlock door unlock switch in the boot.
Below is a picture of the Inertia Reset switch in the car. This switch is tripped when an Elise is hit and it turns off the fuel pump and automatically unlocks the doors.
Old 10-11-2005, 10:48 PM   #2 (permalink)
Disconnect the wiring harness to the switch. Be careful you will need to contort your arm a bit to get at it. The harness has a plastic release on it and then it just slides out.
Old 10-11-2005, 10:49 PM   #3 (permalink)
There are three wires that connect to this switch. The center White wire is the one that goes to the Central Door Locking Mechanism. When ever this wire receives +12 volts, the doors automatically unlock.
Old 10-11-2005, 10:50 PM   #4 (permalink)
I bought a momentary switch from Radio Shack, $1.50 and soldered two wires to it.
Old 10-11-2005, 10:51 PM   #5 (permalink)
I placed this switch in the Plastic battery housing.
Old 10-11-2005, 10:51 PM   #6 (permalink)
I connected one of the wires to my +12 volt lead on the battery. I recommend you have a fuse between the battery terminal and the switch.
Old 10-11-2005, 10:52 PM   #7 (permalink)
I ran the other wire through the rubber grommet in the trunk that connects to the engine bay. Sorry no Picture. I then connected that wire to the White wire in the wiring Harness.
Old 10-11-2005, 10:52 PM   #8 (permalink)
Now is when you want to lock the car doors with the central lock. Then press the switch to make sure all your connections are good. The doors should unlock.
I then wrapped that connector with electrical tape.
Old 10-11-2005, 10:53 PM   #9 (permalink)
Then I reconnected the wiring harness to the Emergency Inertia Reset switch.
Old 10-11-2005, 10:53 PM   #10 (permalink)
I then carefully tucked my wires behind the Battery cover and replaced the battery cover. I am not sure of the clearance between the switch and the stock battery since I replaced mine with the Oddessey P680. However, if you have the stock battery you can place this switch anywhere in the boot.
Old 10-11-2005, 10:55 PM   #11 (permalink)
All in all it took 30 minutes, but I was taking a lot of pictures. Now I have piece of mind that I can unlock my doors incase of an emergency.
Old 10-11-2005, 11:16 PM   #12 (permalink)
Serebo1's Avatar
Images: 4
Great job - nice pics!
Matte Black, Sport, Touring, ***** intake (TBA), RAC Mono wheels, Painted Shift knob, smoked turn signals, Alpine SPS 6.5" rear speakers, MB Quarts, JVC Nav, Starshield, LBH exhaust, Dpic perf. gauge, Custom true HID projectors, GUT wing and splitter, Mesh side pods, Sector111 harness bar and 4-point harness, Lotus Sport Ohlins double-adjustable suspension, swaybar, '06 LED tailights, Toda flywheel, Lotusport interior.
Serebo1 is offline   Reply With Quote
Old 10-12-2005, 05:09 AM   #13 (permalink)
huncher's Avatar
This might be one of the more practical/useful tips posted here in some time. Thanks for the detailed documentation.
huncher is offline   Reply With Quote
Old 10-12-2005, 05:34 AM   #14 (permalink)
burning bright!
Tyger's Avatar
Cleverly done, but it sounds like most people have had a problem unlocking their doors when the battery has died, which this will not solve.
I guess everyone's fear is having the fob/alarm suddenly stop working properly when the top is on and the windows are up, but I do not think that will happen very often in practice. It all comes down to the odd design where the key does not have anything to do with the alarm or the automatic door-locking mechanism.
Old 10-12-2005, 05:44 AM   #15 (permalink)
You know what...I'm half British...and can partially understand the situation. Maybe you have to be all-Brit to shrug it away completely! I recall that a Jag V12 Sedan I used to have (Daimler Double Six) also had pretty strange locks...
Old 10-12-2005, 07:17 AM   #16 (permalink)
Yes, but since you have access to the boot, you could always get a jump from someone, which would allow you to unlock the doors and then jump start the car. Otherwise, you can't open the door to get in and start the car.
Old 10-12-2005, 08:28 AM   #17 (permalink)
burning bright!
Tyger's Avatar
I'm not sure I understand. Under normal circumstances, you'd hook up to the other battery at which point you can unlock your doors with the fob, then get in and start the car. If the fob really does not work at all, you'll have a problem with the immobiliser anyway.
Old 10-12-2005, 09:07 AM   #18 (permalink)
Meow!!
darkSol's Avatar
As long as you have your 4-digit bypass code you dont need the immobiliser disable fob button.
I love this mod, but I would place the button in the engine compartment and not in the trunk where stuff could bounce around and press it accidently.
d.a..v...i....d
David Thomas Stewart - davidtstewart@gmail.com
TVS Supercharged 2005 Graphite Grey Lotus Elise: 286whp, 1781lbs.
Lotus cars aren't made, they're hand built from dreams.
If you must choose between two evils, pick the one you've never tried before.
darkSol is online now   Reply With Quote
Old 10-12-2005, 09:16 AM   #19 (permalink)
burning bright!
Tyger's Avatar
Yeh, not just the code but the knowledge of how to enter it. I've programmed my system to disable automatic immobilisation.
Old 10-12-2005, 09:30 AM   #20 (permalink)
TimMullen's Avatar
Images: 19
Knowing which wire to jump to open the doors is the important thing here. All you really need is a piece of wire with a clip on one end. In the unlikely even that you are locked out, unclip the connector on the inertia switch, clip the wire to the positive post on the battery, and touch the other end to the proper terminal in the connector. No need to cut up and modify the wiring for the safety switch...
Modifying wiring and using vampire taps is a great way to cause corrosion and electrical problems down the road in a few years...
94 Miata R Package - Black
