Old 10-28-2009, 12:52 PM   #1 (permalink)
Flashing red light on tachometer after start-up
Hi
Just bought a 2005 Elise. Occasionally, after disarming the alarm/immobiliser with the fob, I turn the ignition key only to find that the engine does not even turn over. The red light on the tachometer is not flashing at this point. A few days ago this problem occurred, and after repeatedly turning the key the car started. The problem is intermittent. Any thoughts?
Also, I just started the car (it started on the first attempt), and let it warm up before pulling away. For some reason, the red light flashed intermittently for the first minute or so that the engine was running (before pulling away, so engine was idling). Any thoughts?
A
Skins is offline   Reply With Quote
Old 10-28-2009, 12:56 PM   #2 (permalink)
Chris Mackey's Avatar
IIRC, might be a loose battery connection. There are several threads about the issue.
2006 Elise, Ardent Red, Black Pack, LSS wheels, shocks and springs.
ChuforiaGraffix.com SDD Lives On! SweetDaddyDelicious(at)hotmail(dot)com
Chris Mackey is offline   Reply With Quote
Old 10-28-2009, 01:09 PM   #3 (permalink)
tesprit's Avatar
Calling TheViper!
He is our LT guru when it comes to all things related to the alarm/immobilizer.
Old 10-28-2009, 01:31 PM   #4 (permalink)
Alarmed & Dangerous
TheViper's Avatar
Does not sound like an immobilizer issue. As Chris said it sounds more like a bad battery connection. Check both the main battery connection and the adapter connection in the cable a few inches away.
Cheers,
Old 10-28-2009, 02:59 PM   #5 (permalink)
xxxotic's Avatar
How many times does it blink? There is something in the manual about the light blinking different numbers of times if an alarm went off, the battery was disconnected, the front panel was removed, etc.
Compare the number of blinks to what the manual says to find out what the problem is.
xxxotic is offline   Reply With Quote
