Old 04-26-2009, 10:49 AM   #1 (permalink)
Flickering / Winking / Blinking Battery Light
I have a 2005 Lotus Elise that begun winking or blinking the battery / alternator light during my last track day. The winking (it's not a constant blinking) is very sporadic and seems to come and go.
I was able to capture some of its behavior on video. The battery light is the red light on the left bottom row that stays lit up.
Before I start the engine it seems to blink as some solenoid pulses(maybe the fuel pump?). Then after I start the car the light flickers and then seems to flicker out as the engine revs.
I've also recently experienced the battery light not even coming on when the ignition is keyed, it stays dark for a few miles and then seems to come back when the car is slowed down to idle.
I have checked the battery terminal connections and have charged the battery. I also checked the fuse on R3(Position Alternator Sense) and it's still good. The serpentine belt visually looks good but I remember smelling some burnt rubber aroma from the engine compartment after my first session or two at the track.
tempaccount is offline   Reply With Quote
Old 04-26-2009, 11:10 AM   #2 (permalink)
Holy Guacamole!
apk919's Avatar
Images: 20
Do you have a voltmeter? If so, measure the voltage at the battery while the engine is running... report back.
Oh, BTW, is your car still N/A or aftermarket supercharger?
2007 Aspen White Lotus Exige S (street ride)
2010 Isotope Green Lotus 2-Eleven (track ride)
Lotus Challenge Series
Old 04-26-2009, 12:03 PM   #3 (permalink)
I checked the voltages at the battery. I only have a cheap Radio Shack multi-meter so I don't have a lot of confidence in its accuracy.
Battery voltage (at rest): 12.6
Battery voltage with engine running: 14.3
The car has a Black Watch Supercharger and is currently running a slightly shorter belt 75.08" (75.50" stock), with less than 500 miles on the belt.
Old 04-26-2009, 12:23 PM   #4 (permalink)
Originally Posted by TheViper View Post
Typical symptoms of a bad battery or connections.
Cheers, Michael
The battery was replaced 18 months ago with a new Interstate and seems to hold a charge well. I checked the water and all the cells are full without any signs of leakage or boiling. The connections at the battery are clean and tight.
I have investigated the alternator splice for the BWR kit and wiggling the wiring at the splice location doesn't seem to effect the battery light flicker. The loop by the alternator still has slack and as I rev the motor I can't see any pull or flex.
Maybe one of the smaller gauge purple, brown, green alternator wires has come loose?
Old 04-26-2009, 12:36 PM   #5 (permalink)
Holy Guacamole!
apk919's Avatar
Images: 20
Voltages are fine.
I agree with TheViper... sounds like a bad connection or wire somewhere... I've seen similar symptoms after a track day on another BWR S/C car... I think in that case the alternator wire was actually fraying...
Old 04-26-2009, 12:40 PM   #6 (permalink)
Alarmed & Dangerous
TheViper's Avatar
I believe the alternator output is below what it should be. This could be because there is a defect in the alternator or the belt is slipping.
Cheers,
Old 04-26-2009, 01:06 PM   #7 (permalink)
Holy Guacamole!
apk919's Avatar
Images: 20
Cheers,
I'm only getting 13.9V at the battery while the engine is idling...
Old 04-26-2009, 01:15 PM   #8 (permalink)
Alarmed & Dangerous
TheViper's Avatar
Right in the 13.5V to 14.5V range. I have heard that there are alternator issue with these aftermarket supercharged cars, is this one of them?
Cheers, Michael
Old 04-26-2009, 01:24 PM   #9 (permalink)
Cheers,
From this post it looks like voltage is where it should be?
At idle take a voltage reading across the battery, with a correctly operating alternator you will see 13.45V +
I guess if my meter is off by more than 5%... I'll see if I can muster a better meter.
Old 04-26-2009, 01:25 PM   #10 (permalink)
Holy Guacamole!
apk919's Avatar
Images: 20
Cheers, Michael
I know of two potential problems with aftermarket supercharged cars and their alternators... one is that some aftermarket kits relocate the alternator to a place where it gets very little airflow, leading to overheating and early failure, two is that the replacement cable to the relocated alternator is a bit short, and when the engine torques in its mounts (especially with track usage), the cable is pulled taught and can fail from fatigue.
Old 04-26-2009, 01:29 PM   #11 (permalink)
Alarmed & Dangerous
TheViper's Avatar
Do you have another battery that you can temporarily install to see if the same symptoms prevail?
Cheers, Michael
Old 04-26-2009, 02:12 PM   #12 (permalink)
jallingt's Avatar
FWIW, I have been experiencing this same issue, but my light does not stay on.... it only flickers a few times then goes away after start up.
No blinking when the car is not running either.
It seems to only happen to me when:
1. The car has not been driven for more than a week, and has not been on a battery tender.
2. The car is cold, after the car warms-up no more flicker.
I have not checked any of my voltages yet. My battery is a repalcement one for the "leaky" OEM, it must be about 4yrs old. After sitting for a few days off a tender sometimes the car will start with a very short crank ~1sec, other times it may take ~4sec.
2005 Bordeaux Met #21 (HT, Touring, Quicksilver ext, TRM F1 wheels, Stan Stud, HID lights, BWR S/C,Filled motor mounts, catch can, no camber shims, Tillett saddles)
2004 Audi S4 Sedan (Tip, GAIC Chip, AWE Cat-back, Team Dyanmics Pro 1.2 wheels, H-sport sway bars)
2002 F-350 (Powerstroke, 4x4, Banks power pack, 6th alternator)
Couple nice bicycles, way too many snow skis.
jallingt is offline   Reply With Quote
Old 04-26-2009, 02:37 PM   #13 (permalink)
I borrowed a professionally calibrated (and expensive) Fluke meter to rule out an erroneous reading.
The voltage at the battery with the car at idle is reading 14.35 so I think I can rule out a bad alternator, and likely not the belt.
I had also heard about the wiring being stressed with the alternator relocation before I did the install so I was careful to leave a lot of slack...
If there was a bad connection with one of the smaller gauge wires would it give these symptoms? If so which wire should I start with and any suggestions on how to diagnose?
Old 04-26-2009, 02:50 PM   #14 (permalink)
Alarmed & Dangerous
TheViper's Avatar
As you are getting 14.35V at idle, the alternator is operating within parameters. Change the battery and see what happens.
Old 04-26-2009, 03:20 PM   #15 (permalink)
jim-clayton's Avatar
Shawn's car melted the small wires on the alternator. He has BWR.
I have a new connector with high temp wire if you need it.
My alternator reads 14.1 fwiw.
Old 04-26-2009, 03:29 PM   #16 (permalink)
glb
Unattractive Nuisance
glb's Avatar
when you measured battery voltages, did you use the battery post or cable clamp? If it was the latter, check @ the post as well, to ensure good connection at clamp.
"Political language is designed to make lies sound truthful and murder respectable." G. Orwell.
"Incontinence Emergency Hotline- Can you please hold?"
Old 04-27-2009, 08:34 AM   #17 (permalink)
I have the GReddy supercharger installed and had this thing with flashing battery when the cables connecting the alternator to the electrical circuit were cut due to vibrations. Battery light flashes or remains constantly lit when the electrical circuit does not get "fed" by the alternator.
GoatOfRafin is offline   Reply With Quote
Old 04-27-2009, 09:58 AM   #18 (permalink)
Which alternator connections?
Old 04-27-2009, 12:43 PM   #19 (permalink)
Have you checked to see if the battery terminals are tight? Weird things can happen when the terminal is loose.
Old 05-01-2009, 04:23 AM   #20 (permalink)
The connections between the alternator and the rest of the electrical circuit.
