The Hardwire Thread (DIY)
Front 12v power outlet install (Note: These instructions came from tesprit & Viper.. I just took pictures of all the steps) Adding 12v lighter outlet
Next week I will actually hardwire my radar detector (not using a 12v power outlet) & post pics. The steps will pretty much be the same as in the 12v power outlet install. Last edited by txdude : 10-03-2009 at 09:44 PM. |
#2 (permalink) | |
Alarmed & Dangerous
Hardwired means using permanent wire connection, as opposed to a wireless or a plug in connection
Thanks for your modesty ![]() Front 12v power outlet Quote:
Cobra OEM - Alarm, Immobilizer, CDL Emergency Override with warranty Additional Emergency Touch Keys - see link above Brand New Cobra Alarm Remote with warranty Cobra Remote Key Fob Strap Cobra Window Closing Module - Add to your existing Cobra alarm 3 Piece Front Clam Protection Kit with Center Bumper Undertray Removal Tool INFORMATION Improved AC & Heating System Battery Choices & Information Remote Key Fob, Alarm & Immobilizer Programming Light Bulb Conversions 2005 Last edited by TheViper : 09-04-2009 at 06:26 PM. |
#3 (permalink) | |
Thanks for the link. That's what I'm talking about, good instructions for adding extra devices (in this case, an outlet). I think the power load I want will be too much for the fuse panel location used in this particular DIY, so I'll continue to look at other options.
by the way... was that a custom made "wall" or plastic piece that he mounted the outlet in that link? or can we purchase that somewhere? Don't answer that, it's probably somewhere in that thread & I'll re-read it. |
the devil's advocate...
it really depends on what you current consumption requirements are. If you need switched high current then what you do is use a 40A SPDT relay with the contact pole running to the battery through a fuse. then you can switch the relay with any switched igniton source since the relay coil is very low current.
