Chris
Headlights working intermittently, sometimes they turn on sometimes not??
Hello
Ive been having an issue with my lowbeam headlights, particularly the passenger side. When I turn my lights on, only my driver's side will light up and my passenger one will not light up immediately. The first time this happened, the passenger light did come on a few seconds after the drivers side and I went along my way. Earlier this week, when I turned my lights on again, the passenger side was completely out, and would not come back on. I figured the light bulbs had burnt out on that side, so I went to buy new H1 Sylvanias. However, earlier today, both headlights began to work again. Is this some kind of wiring/fuse issue? How can I check the fuse box? Also, I noticed there is some condensation behind the halogen projectors within the headlights (not building up behind the headlight lenses, but the actual projector glass bowls) TIA for your help |
2006 Sport Elise #9
I've had this problem with both sides. The connector on the back of the bulb would come loose. First with the light working intermittently then not at all when the connector finally came completely off. Just follow the steps to adjust the headlights to gain access to the connector and reattach it.
Jason Current: '06 LotusSport Elise, #9 of 50 Lost in divorce: '00 Ford Explorer XLT Sold: '96 Jeep Cherokee Sport, '03 Dodge Dakota Sport, '99 Chevrolet Cavalier, '94 Dodge Stealth RT, '88 Toyota Corolla DX, '84 Dodge Daytona Turbo, '82 Pontiac T1000 |
#4 (permalink) | |
Alarmed & Dangerous
It is either a bad bulb/connector or as Tesprit said a defective Switch pack Module (SWP). If you find it to be the SPM, I have some used ones for sale, PM me if needed.
Michael Quote:
Engineer of Record
I had the same issue and got a new switchpak and it seems to have fixed it.
02 Phoenix Yellow M3 (fast and fun) 06 Autumn Gold Elise (faster and funner) 07 328iT (wifey's car) |
#7 (permalink) |
I also had this happen to me, however my Parking & high beams work but the low beams don't. I had just washed the car and jumped in to move it and turned on the parking light first then the head light heard a "snap" like a fuse went out. Highs work but not the lows, been driving it all summer like that having to rush home before dark.
#8 (permalink) |
Alarmed & Dangerous
Seperate issue, check the connections.
SPM location.
Cobra OEM - Alarm, Immobilizer, CDL Emergency Override with warranty Additional Emergency Touch Keys - see link above Brand New Cobra Alarm Remote with warranty Cobra Remote Key Fob Strap Cobra Window Closing Module - Add to your existing Cobra alarm 3 Piece Front Clam Protection Kit with Center Bumper Undertray Removal Tool INFORMATION Improved AC & Heating System Battery Choices & Information Remote Key Fob, Alarm & Immobilizer Programming Light Bulb Conversions 2005 Last edited by TheViper : 10-10-2009 at 02:48 PM. |
#9 (permalink) |
Live from the Bubble Room
I had the same problems with Left headlight low beam and flickering start button, loose connector on the low beam and replaced the start button........Fixed
"Never leave well enough alone" Raymond Loewy |
#12 (permalink) |
Alarmed & Dangerous
1. Remove the upper and lower steering column covers (6 screws ). Removing the trip reset button connector is recommended.
2. Remove the instrument cluster cover (four spring clips, pull toward the steering wheel, do not pull on the instrument shroud, only on the sides). 3. Remove instrument cluster (4 screws). 4. Remove the two lower column cover mounting brackets (4 screws). 5. Gently remove the instrument cluster, disconnect connectors (2). 6. Two machine screws hold the Switch Pack module to a dash bracket. Don't drop them! 7. Gently pull out the Switch Pack module. 8. Test and Reassemble. Be careful with the instrument cluster connectors and cable routing.
#13 (permalink) | |
Chris
Thanks Michael! I will let you know if I need a SPM |
