Old 08-19-2008, 07:56 AM   #1 (permalink)
Frank Amoroso's Avatar
Help please: Airbags removed, now what about SRS Control Unit? See pics...
Greetings all,
I have removed my driver's side airbag by virtue of going with S111s Works Bell removable steering wheel hub. I've also disassembled the dash and removed the passenger side airbag while I was at it. See first pic below.
The Works Bell comes with a 2 ohm resistor to wire in-line that fools the SRS system from throwing a fault code. I assume I can just wire another 2 ohm resistor in place to fool the SRS system as it pertains to the passenger side airbag.
Here are my questions though: Can I also remove the SRS Unit (part number A121B0060F, see second pic below)? It would be great to remove this piece seeing as how I don't have any airbags to deploy anymore. If I remove this piece, will its absence throw an SRS fault code / light? If not, then I assume that I could remove it and I wouldn't need to wire in the aforementioned 2 ohm resistors?
THANKS!
Frank Amoroso
Whatever Press Vehicle(s) I'm driving this week
www.twitter.com/famoroso
Ever take a risk? A real risk? The kind of risk that makes you feel alive? It's... spectacular, isn't it?
Frank Amoroso is offline   Reply With Quote
Old 08-19-2008, 08:36 AM   #2 (permalink)
OSX Black hat
charliex's Avatar
don't see any obvious reasons in the circuit diagram as to why it can't be removed, the resistors would be connected to the srs unit, so they wouldn't be needed, and you shoulnd't get a warning light either.
Black Exige S - http://goth.am 265 Mule / Elan M100 ECU Tuning, http://www.elisetalk.com/forums/showthread.php?t=39660
Arguing with an engineer is like wrestling with a pig in mud. After a while, you realise the pig is enjoying it.
Old 08-19-2008, 10:55 AM   #3 (permalink)
xtn
McLareghini Bugatterrari
xtn's Avatar
subscribed...
Please update with results.
xtn
Old 08-19-2008, 12:21 PM   #4 (permalink)
2008 XP National Champion
fzust's Avatar
I removed mine and did not get an ABS light. Can't remember if I got an airbag light or not. Then I removed the Dash and the ECU so the point was mute.
2008 X Prepared Solo National Champion
Old 08-19-2008, 12:24 PM   #5 (permalink)
OSX Black hat
charliex's Avatar
i did the opposite of fred and didn't get a warning light ( removed the car, left the dash and ecu)
Old 08-19-2008, 02:50 PM   #6 (permalink)
TimMullen's Avatar
Images: 19
In case you didn't know, the SRS unit also "fires" the seat belt pre-tensioners (tightens the seat belts in a wreck).
If you remove the SRS processor, you loose that capability. Of course if you remove the seat belts, and replace them with harnesses, it's not a problem either...
94 Miata R Package - Black
TimMullen is online now   Reply With Quote
Old 08-19-2008, 03:27 PM   #7 (permalink)
2/3 hp to the paws.
Simba's Avatar
If you want your tensioners to work, keep the computer and snip the SRS warning light lead on the cluster harness.
Simba is online now   Reply With Quote
Old 08-19-2008, 10:17 PM   #8 (permalink)
Actually, seeing as how the stock seat belts work with the Mulsanne Cs, I'm keeping them for street use. Do you know which is the warning light lead in the cluster harness? I don't plan on snipping it, but I would pull the electrical connector out of the "molex" connector.
Thanks,
Frank Amoroso
Old 08-19-2008, 10:31 PM   #9 (permalink)
OSX Black hat
charliex's Avatar
should be black and purple.
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
cobrabyte
HTML code is On
