Old 07-03-2009, 11:24 AM   #1 (permalink)
jim-clayton's Avatar
How do I hot wire my AC compressor?
The AC compressor is controlled by the stock ECU.
I no longer have a stock ECU.
Any ideas on how to run my AC compressor. I have located the trigger wire.
I currently have it connected to a cycle timer. I cycle the compressor 30 seconds on, 30 seconds off. I can adjust the time interval if needed.
Any ideas? Will my cycle work?
It blows nice and cold but I don't want to damage my AC system.
2005 Elise Storm Titanium
Old 07-03-2009, 11:32 AM   #2 (permalink)
Alarmed & Dangerous
TheViper's Avatar
Looks like the ECU gets inputs from the Trinary Switch and allows the Compressor to work only if the pressure is within limits.
Old 07-03-2009, 11:41 AM   #3 (permalink)
Thanks Michael.
I started to look at the Trinary Switch. I wasn't 100 percent sure if the Trinary
is what I needed to connect to.
Old 07-04-2009, 09:51 AM   #4 (permalink)
the devil's advocate...
Originally Posted by jim-clayton View Post
Thanks Michael.
you are on the right track... the AC button passes ground to the ECU via the trinary switch. it looks like the ground is passed thru to the ECU if the pressure is not low or high (need to confrim that on a working elise). the ECU then activates the compressor relay by also sending a ground.
in theory it might be as simple hooking the two together through an ignition activated relay. i dont know what the ECU does with the signals though... there might be some programmed logic in the ECU that also controls when the compressor is or is not activated like based on temperature,etc.
rob13572468 is offline   Reply With Quote
Old 07-04-2009, 03:07 PM   #5 (permalink)
TimMullen's Avatar
Images: 19
More likely, it's simply that the ECU turns off the AC compressor whey you give it wide open throttle - a lot of cars do this.
94 Miata R Package - Black
Old 07-04-2009, 05:49 PM   #6 (permalink)
untitled
Beanie's Avatar
Electronic Thermostat - Cana Kit
It is all about "Other".
Beanie is offline   Reply With Quote
Old 07-04-2009, 06:07 PM   #7 (permalink)
Alarmed & Dangerous
TheViper's Avatar
I don't think that this device addresses the issue. What is required is to take into consideration all the relevant inputs into the ECU, that though logic, control the compressor, temperature is not one of them.
Old 07-04-2009, 10:47 PM   #8 (permalink)
HKFEVER's Avatar
For sure temp. is not the only control to turn on or off the compressor. We are in HK and we need as much A/C as possible, but with no reason the A/C will switch off the compressor, and I am also wonder how to keep it on full time.
2008 Exige S Sport in HK (S240) almost stock.
HKFEVER is offline   Reply With Quote
Old 07-05-2009, 04:50 AM   #9 (permalink)
Alarmed & Dangerous
TheViper's Avatar
The compressor can not run all the time because it will freeze up. It is cycled by the Evaporator thermostat the purpose of which is to turn off the compressor just before it freezes. Have you done any of these mods IMPROVED A/C & HEATING SYSTEM
Old 07-05-2009, 07:20 AM   #10 (permalink)
stinkyonion's Avatar
Images: 2
This Zeitronix product will solve turning off the ac at full throttle:
TCAC
Installation seems simple, posted at same website.
2006 polar blue Elise, VF stage II, clam hinge, von Hep exhaust, HID, Zeitronix/Dashdaq (GPS, wideband O2, EGT, fuel+oil pressure), BWR fuel rail, moroso oil pan, HD SS clutch, RTV brace, green wire mod, harnesses, Oddysey 625, alpine pdx-5, jvc avx77 head unit, jl speakers, voltmeter on dash, custom gauge pod, etc.
stinkyonion is offline   Reply With Quote
