peregrinus caelum
...on my way home from work tonight, my right turn signal blinked at three or four times the normal rate while my left turn signal continued to operate normally...
...when i got home, i tested a host of light combinations, hazards, brights, engine on/off, interior light on/off, and the problem persists - while my left turn signal and all my hazard lights operate normally, my right turn signal flashes at a very high rate...any ideas?..
2005 Federal Elise | Touring | Storm Titanium ...67,000 miles and aging beautifully... |
peregrinus caelum
...yikes - i should go check!..
edit: ...indeed i do; thanks for the pointer...ah, just found it on page 46 of the manual...
2005 Federal Elise | Touring | Storm Titanium ...67,000 miles and aging beautifully... Last edited by ...m... : 09-30-2008 at 09:04 PM. |
Or a poor electrical connection somewhere in the right signal circuit. If the bulbs are working, check to make sure their bases are tight to their sockets and there is no corrosion. Check all the wiring connections to the light assemblies as well as all the ground connections for good contact and a lack of corrosion too.
#5 (permalink) | |
peregrinus caelum
#7 (permalink) |
GGM ENFORCER
happened to me with LEDs...bad relay. left blinker
** save ~10 lbs gain 1 hp ** EQ: Y=(190*X) / (1984-X) where Y is (HP) and X is (lbs) '07 GG EXIGE S ** MY CAR ** VIDEO CLIPS! ![]() '08 ACURA TSX 6-speed http://www.makeNYNYagain.com |
#8 (permalink) |
n. Chiefly British.
Had the same issue when my LED's were installed. Turned out to be a loose connection in the trunk to one of the rear lights.
UK Expat with an 05 Starlight Black Elise | Touring | Hardtop | Starshield | 06 LEDS | 07 Badging | SS Brake Lines | Lotus Sport Indicator Stalks | Polk Speakers | Alpine iDA-X001 | Multivex Mirrors | S111 Lidbone | S111 Bootie New Ride: 08 Black Magic GTI | Autobahn Package ![]() "I wish I was still a teenager, I used to know everything back then" ' or '1' = '1 |
#9 (permalink) | |
peregrinus caelum
...corroded contacts...
...having disassembled the lot, i can't quite work out where water got into there...there's a crack along the upper lens, so possibly it slowly dripped through during heavy rains, but it's a very tight fracture with no visible gap... ...now i'm left with a dull mirror where water pooled at the base of the the lens assembly - is there any viable technique for opening the lens housing to polish/rechrome the dull bit and possibly seal the crack from inside?..
