#182 (permalink) |
From close to Roswell....
I would do it again in a heartbeat, now that I know my neighbor and I are the same blood type!
Just kidding. Not a tough job. If you are hesitating, I would suggest mechanics gloves and a little caution. Not a big deal and worth it.
2006 Elise, Graphite Grey/Red leather, Sport Elise Suspension, Hardtop 1992 900SS Ducati Race Spec Built by Ferracci 2006 KTM 950 SuperMoto, a work in progress Wife drives a 2007 Cooper S, our BIG car! ![]() Old stuff gone: Ferrari 275GTB/4, '69 1275 Cooper S. '72 500 Fiat, old Jags, etc. Never bought a boring car. |
#183 (permalink) | |
Dude, There's My Car
Were both of them Elises? If they are another brand of car, the frequency of the transmitter might be different and then you have to use a different lenght of wire. However, the most probable cause is that your battery for your remote needs to be replaced. I replaced the battery in the remote I use all the time when I did the mod. The other remote that I dont use that much seemed not to have as much range, so I replaced the battery and now I have good range again on both. The owners manual says to replace it once a year. On my other cars (non Lotus) I had never replaced the batteries and the cars were 5 years old and they stilled work fairly good, but also worked a lot better when I replaced the batteries. My garage door battery seemed to wear out about once a year, and it was 12 volt, so I hard wired it into the car and now the range is somewhat better too. If the battery is weak, then the transmitter is sending out a signal that is not as strong, so the reciever has less of a chance of picking it up. I also extended the wire on my garage door opener, to the correct length based on its operating frequency but it didnt make that much of a difference in my case because my garage is not in the line of site when I am going down the street until I am almost in the driveway. |
#184 (permalink) | |
I'm Lovin' It!
The Cobra installation manual warns not to put the antenna wire into any cable harness, but I guess the Lotus factory workers don't RTFM.
'05 AR Mods: Stebel Nautilus horn; tesprit's rearview mirror; Custom Interior Pictures; PPF full front clam wrap |
#185 (permalink) |
Hi everyone
Just had the dash all appart for replacement of the switch pack relay board and thought to do the mod for the alarm. I added the full 37" length of wire and had the sill cover off. It has a couple of slots in the aluminum that the wire will lay in nicely. Once all back together I have about 75' of range which is huge considering I had to always stand next to the car before mod. I would agree with others on this being one of the best and easiest improvements to make. Keep these kind of mods coming! Mark |
#186 (permalink) | |
Ex-Brit
Mark,
Coupled with the same length of wire, that range is about what I got too .By the way do you have any detailed info and photo's on replacing the Switch Pack? Incidentally did you do my simple A/C mod? Michael Quote:
A/C Improvement Modifications http://www.lotustalk.com/forums/f3/e...ent-mod-59938/ 1) Insulate the cockpit from Solar (3M Crystalline Tint) & Convected (insulate sills) heat. 2) Replace evaporator thermostat with an upgraded electronic version to prevent freeze up. 3) Increase airflow into cockpit by removing both driver & passenger side footwell intake panels & blocking 2 outside air intakes in nose. |
#187 (permalink) |
Hi Michael
I did not take pictures of the process of relay change but it was somewhat straight forward. I could do a write up if no ones has done this before. Round trip it took about two hours and you need four special plastic clips for the reinstall of the dash airbag. They break on the removal process. I had read the pack was $120 but I paid $88. I will look at your mods for air conditioning but we don't get as hot as you and I will try to remeber warm air this winter when it drops below zero. Mark |
#189 (permalink) |
Form and Function
can't wait to do this
www.FaceNBody.com 2005 Lotus Elise: Larini SE exhaust,HID's,turn signals delete,rear fins delete, CFside scoops, CFbinnacle,CFcenter console,Zoom CF mirror,Gut Aero wing,Gut front splitter,CF 5-element diffusor,Exige mesh, Ohlins DA,RAC monolites,Toyo R888's,Pagid RS Blues,CO painted calipers,SS lines,Reverie XC CF seat, Reverie CF steering wheel,V force harness bar,Schroth Profi II 6 pt harness,shifter re-Enforcer, BWR key to BWR S/C! 2007 E63 M6 (many mods...) |
#190 (permalink) |
Be a Lotus blood brother! Fix your remote!!
#191 (permalink) |
Form and Function
I'm waiting for the mod day to do this Nov. 22 ...
SOCAL MEET: Let's organize a MOD day!!! come join us!
#192 (permalink) |
can it kill me?
Such a simple but great mod! Less than 10 min and you have a remote that works from many yards away ... instead directly beside the car.
I didn't add any wire to the existing one. Simply tucked it to the left of the panel you open. It was difficult to get the panel off. I had to use a flat head to gently pry it loose. It appearers as if the foam that keeps it from touching and rattling adhered to both side. Unless it should be sticky on both side? Either way ... wasn't a problem.
06 Chili Red Exige, 1st Mod (Extended Remote) |
| Display Modes | |
