#41 (permalink) | |
Waiting for next Lotus...
yes, the Uni-key is awesome, I have one too, and you are right, it would be very difficult to accidently unlock the car with that thing in your pocket.
2009 Mini Cooper JCW - Dark Silver/Black - sport suspension/cold weather package 2008 997 GT3 - Carrara White/Black - PCCB's - 350 lbs of weight reduction Past Lotus Cars: 2005 NFB Elise, 2007 CO Exige S, 2005 AR Elise, 2008 CO Exige S 240 |
#42 (permalink) | |
Yes, you can get the wire at radio shack. I used solid core wire, but I see no reason why you can't use regular stranded wire; the piece that is already on there is stranded; but then again, the stock piece does not work very well.
#43 (permalink) | |
Are you sure??? If you do not arm the alarm (or disarm it) and don't insert the key and turn the ignition on, the immobilizer automatically activates (unless you have re-programmed it not to) which starts the dash light flashing. The car is disabled, but the alarm doesn't re-activate, and if you open the door, nothing happens. You just can't start the car without pressing the key fob button again to deactivate the immobilizer.
#44 (permalink) |
Loves Curves
I finished the mod and I'm mostly done bleeding. In my car there was a huge piece of foam obstructing the alarm (and wires) from view. I had to remove the foam to figure out where the wires were.
I did the 27" version mostly snaked into the windshield. I'm not seeing the super long distances people are reporting here but I'm happy to be able to do without holding the fob direclty over the car. Be careful not to unplug your speakers as well. |
#45 (permalink) | |
and the sarcasm was a nice touch... and i know... i have no idea how i've survived without knowing where to get that kind of wire... i've just been lucky i guess... but my question about where to get the extra wire was because i wasn't sure if it was a certain type of wire... if so... then i would have needed to know what type and where to get it... and your analogy would have been better if you had written... "where do i get that kind/type of food?"... anyway... since you've done the mod... was the black antenna wire marked 13? and i'm curious if those numbers were written on your connector as well...
KG Exige Delivered 5-9-2006 POLL:check for scratches "in" your headlights Excessive tire wear? It may be your alignment My Example Hiro's Example codymac's Example to be installed: stebel horn, fumoto valve current mods: arqray twin muffler, itg intake, 3M film full wrap and full rockers by X-Perts, rear lotus letters removed, locking gas cap, CF Mirror Covers, CF Side Scoops, black lotus nose/wheel badges future mods:wheels, forced induction |
#47 (permalink) | |
but anyway... "It is the black wire on the same end as the pink and green wire." from the picture on post#1... it did say 13... so i'm hoping that there will be numbers like the one in the picture... then finding number 13 and hoping that it's black won't be difficult... but going by just the description "...same end as the pink and green wire." i'm not sure where to look at... from the left... i see what looks like 2 pink wires... and then 2 green ones in the middle... green/white and green/red?... and then another green on the far right... and then like 3 purples in the middle along with what looks like red/white... oh... and a bunch of black wires all over the place... i'm sorry for asking so many questions before opening up my car... but i just want to make sure i've got everything down...
#48 (permalink) | |
Stephen
#49 (permalink) | |
I think that if you arm/lock the car and then unlock/disarm the car WITHOUT opening a door, after a few minutes it rearms the car, but does not relock it. So if you or someone else walks up to open the door the alarm goes off. I think this is done for the reason I mentioned earlier. If you accidently hit the button and are close enough to unlock/disarm it unknowingly, then it assumes you made a mistake and rearms the car if you do not open the door (not sure what opening the trunk will do). This way at least the car is protected, even though someone can still open the door and steal something inside the car. I will test this later today and report back; there might also be something in the manual about this.
#50 (permalink) | |
Car Guy
Bill '07 BMW M Coupe, '05 Lotus Elise (Traded) www.billswebspace.com/lotus www.syntheticfirst.com |
#51 (permalink) |
Hmmmmmm..... Veeerrrryyyyy interestinggggg.....
Now I'm going to have to investigate. Maybe I never hit the right conditions (I guess I've always opened the door after disarming the alarm).
#52 (permalink) | |
#53 (permalink) |
Meow!!
I just did this mod -it took a whopping 10 minutes.
I couldn't manage to get my fingers around the Cobra unit to release the connector so I just spliced into the existing black antenna wire. I previously had an effective circular range of around 20 feet... after adding a single 20" CAT-5 strand (I picked blue) and pushing it as straight / far forward / behind the Cobra unit as possible... my new range is around 60 feet from the front /rear and 40 feet from the sides. Keep in mind this is with a year-long-used remote with no so hot batteries... still... Perfecto! Nice mod... with no added weight... well 0.002 lbs. maybe... ![]()
#54 (permalink) |
Yahoo! Got my Rotus!
Just done myself, I located the black wire easily, gave it a tug, it's only about 4" long! 20" of single strand wire, in a lazy loop (and aluminum taped down) inside the cavity, and I've got 50' range with 2+ year old batteries. This is a must do mod. I can add, be sure to center the clip type fasteners that hold the panel on to keep annoyances down when trying to get the screws back in during reassembly.
David Avery 05 Lotus Elise ~ Arctic Silver ~ BWR SC ~ Gray RACs ~ Larini SE 08 BMW 135i Stock visit Spyderclub.com |
#56 (permalink) | |
Meow!!
#57 (permalink) |
loading...
Holding your fob in your mouth and tilting your head back will triple or more, the range of a fob. The back of your head acts as a great parabolic dish. Try it! I can go for over 50-75 feet with the stock arrangment. Try it right now, from inside your house! Save your blood for another project. The fob works fine as is.
Boom Boom, shakka-lakka BOOM Last edited by turbo2nr : 09-17-2006 at 12:55 PM. |
#58 (permalink) |
Certified Fun Stopper
O.K. I just tried this. I couldn't get the damn foam out of the way to see anything. Are you guys just ripping it out and then stuffing it back in later. (I would actually have to rip mine apart I think).
I did manage to cut my hand in three different places, even after taping the bottom edge. ![]()
'06 Exige; Polar Blue; Track/Touring/Stage II/LSD-TC '05 Elise; Arctic Silver/Ruby Red (R.I.P) |
#60 (permalink) | |
ToYoTa dRiVeR
you just need to pull up the harness and pull the black wire out, the black wire is very obvious, give it a tuck and it will come out for you to work with. |
