JnC's Programmable Intermittent Wiper Relay Hack - LotusTalk - The Lotus Cars Community
User Tag List
Old 04-14-2006, 08:42 PM   #1 (permalink)
JnC
JnC's Avatar
Quoted: 0 Post(s)
Background
This is the story of a little black relay. It started life at the Doduco plant in Germany, then immigrated via a blister pack to Neuspeed in the USA. Around 1991, I purchased it and plugged it into a 1990 VW Corrado. When I sold the car, I pulled the relay. Then it found it's way into a 1999 Porsche Boxster. That is, until I drove a Lotus Elise at Deal's Gap (courtesy Mike Silberman of Lotus of Durham ), and knew I had to sell the Boxster. But not that relay. It came out and went on a shelf pining for the Elise. I'm pleased to announce that this 15 year old relay has found a new home, in my 2006 Elise delivered earlier this week.
This relay is a marvel of Teutonic engineering. Simple, transparent, intuitive. Daily drivers will wonder what they ever did without it. Being smaller than the stock relay, it may actually improve your 0-60 times. Curmudgeons will rue the day, as this is too much luxury for them to handle. Ok, so...
What does it do?
It does two desirable things for the Elise wiper system. The major one is the programmable intermittent time function. The minor one is it changes the number of wipes during a spritz to 3 instead of 5.
Instead of wiring up a potentiometer and repeatedly twiddling with a knob like you normally have to do with most cars, you can set a comfortable interval on the first try. No hacking up the interior, or splicing wires, or changing stalks. Just replace one relay.
Here's how it works... envision that it's misting on the windshield due to the weather in the canyons.
1. Flip the wiper stalk to the intermittent position to clear the windshield with one pass, then flip it back off.
2. While off the relay begins counting. In German...
3. When the mist on the windshield needs another wipe, flip the stalk back to the intermittent position.
4. The relay will now wipe the windshield based on the time interval that you set. The relay can "count" between 2-45 secs. The limits may vary by manufacturer.
In other words, push up on the wiper stalk to the intermittent detent to have it wipe once, push down to off and wait until you need to wipe again, then push back up to the intermittent detent and leave it there. Ta-da!
If you've not used the intermittent since starting the car, the intermittent default time is about 6 seconds, IIRC.
This hack may be familar to the VW owners out there or Europeans. It's very popular.
VW carries the relay: either 357 955 531 or 1HM 955 531B
Some VW aftermarket suppliers carry it as well. Cost ranges from $10-50 depending where you find it. Here's one for about $29 + S/H: World Impex Relay
Installation
Replacing the relay requires some dexterity. More so for the Elise.
First find the relay. It's mounted beside the hazard light relay. Turn on your hazard light and gently feel around for the relay block, located above and to the right of the OBDII connection port. There are two relays there, one above the other. You'll feel both of them pulsing due to their proximity. Turn off your hazard light. The lower relay is the wiper relay. To remove it, I found it was far easier if I opened the passenger door, and sat in the drivers seat with my feet out of the car's passenger side. Pull the relay towards the drivers door to free it. Pay some attention to how the relay was rotated when you pull it out. You can't insert the new one the wrong way, but it will save time if you have the correct orientation. Look at the pins, and replace with the new relay.
Disclaimer
And remember before attempting any project, be sure you possess the ability to perform the task correctly. I'm not responsible for running part changes, twisted backs, damage you may cause to your car, etc.
P.S. Thanks to Stan for putting up with my repeated PM's for electrical schematics. It wouldn't have happened without his info.
2007 Cross Country Travelblog
11 Lotus Elise Final Edition :: Chrome Orange
11 Honda CR-Z EX
76 Porsche 912E
JnC is offline   Reply With Quote
Old 04-15-2006, 12:05 AM   #2 (permalink)
Florida Chris's Avatar
Quoted: 0 Post(s)
Thanks for the tip. Great mod. I'm off to the VW parts counter on Monday to pick one up.
Florida Chris is offline   Reply With Quote
Old 04-15-2006, 12:09 AM   #3 (permalink)
Serebo1's Avatar
Images: 4
Quoted: 0 Post(s)
+1! Great job!
Matte Black, Sport, Touring, ***** intake (TBA), RAC Mono wheels, Painted Shift knob, smoked turn signals, Alpine SPS 6.5" rear speakers, MB Quarts, JVC Nav, Starshield, LBH exhaust, Dpic perf. gauge, Custom true HID projectors, GUT wing and splitter, Mesh side pods, Sector111 harness bar and 4-point harness, Lotus Sport Ohlins double-adjustable suspension, swaybar, '06 LED tailights, Toda flywheel, Lotusport interior.
Serebo1 is offline   Reply With Quote
Old 04-15-2006, 03:37 AM   #4 (permalink)
Chococar's Avatar
Quoted: 0 Post(s)
Sounds great, but I'm confused about something.
What does: ":based on the time interval (between 2-45 secs depending upon manufacturer) that you set" mean? I expected you to say that the wiper interval would be programmed to be the same as was just done (i.e., "learn mode").
Thanks!
I hope it's loo late to benefit from this mod this year. I've had enough rain -- even light rain.
Old 04-15-2006, 03:40 AM   #5 (permalink)
Quoted: 0 Post(s)
Thanks for info JnC. I'm being not too bright, had to read the post twice to understand the programming thing
ct_mazi is offline   Reply With Quote
Old 04-15-2006, 03:47 AM   #6 (permalink)
GaryD's Avatar
Quoted: 0 Post(s)
I think that's exactly what he meant - just that you can't get it to go less than 1 sec interval or more than 45 secs when you teach it. ie you move the stalk the first time to set the gizmo counting and the second time to stop it and set the interval which is variable anywhere between those time limits ...
Great idea - I am going to get one too!
Edit: ordered - I hate the 5 / 6 wipes after the cleaning fluid hits the windshield and everything gets smeared up and look forward to being able to adjust the intermittent cycle... I can see the real test is going to be getting it installed - I am about as flexible as a 2x4
Thanks for the post.
GaryD is offline   Reply With Quote
Old 04-15-2006, 04:37 AM   #7 (permalink)
Not the admin anymore
RacyTracy's Avatar
Images: 2
Quoted: 0 Post(s)
Interesting idea.....driving the car in the rain..... I'll give this some thought.
RacyTracy is offline   Reply With Quote
Old 04-15-2006, 04:55 AM   #8 (permalink)
Žob's Avatar
Quoted: 0 Post(s)
Wow, you read my mind. I remember this being a popular mod for the Audi/VW guys that didn't have this option, and I was thinking it should be an easy retrofit.
Žob is offline   Reply With Quote
Old 04-15-2006, 05:07 AM   #9 (permalink)
Žob's Avatar
Quoted: 0 Post(s)
Here is one other article on this. Note it has a different part #
http://www.audiworld.com/tech/int26.shtml
Old 04-15-2006, 05:14 AM   #10 (permalink)
Žob's Avatar
Quoted: 0 Post(s)
The Bosch part number is 0 986 335 058.
This relay also works in a 2001 Boxster 2.7 and a polo 1.0L
Old 04-15-2006, 05:22 AM   #11 (permalink)
JnC
JnC's Avatar
Quoted: 0 Post(s)
Yes, that's correct. Sorry for the confusion. You can teach it to any range within about 2-45 secs. I think the upper limit may vary by manufacturer, but I don't see needing more than half a minute.
11 Honda CR-Z EX
76 Porsche 912E
Old 04-15-2006, 07:31 AM   #12 (permalink)
Andrikos's Avatar
Quoted: 0 Post(s)
Congrats on your new Elise JnC.
I see it didn't take you long to start tinkering with it.
My recommended first two mods:
1) Left light pattern adjustment
2) Removal of shims including the ABS bracket.
Both are easy and can be done on a weekend morning.
Welcome to the Lotus experience, and sorry I stole the CO eBay Elise from you..
My daily driver is an orange plastic toaster
Andrikos is offline   Reply With Quote
Old 04-15-2006, 10:15 AM   #13 (permalink)
Johnny B's Avatar
Quoted: 0 Post(s)
I had a Jetta and remember this feature. I need to get this. I too hate how many times the wiper sweeps after spraying with windshield cleaner.
Johnny B is offline   Reply With Quote
Old 04-15-2006, 12:28 PM   #14 (permalink)
JnC
JnC's Avatar
Quoted: 0 Post(s)
Yup, who do you think wrote up the hack on Gary Samad's & Porsche Pete's pages?
Do you have a Polo in the US? TDI?
11 Honda CR-Z EX
76 Porsche 912E
Old 04-15-2006, 12:34 PM   #15 (permalink)
JnC
JnC's Avatar
Quoted: 0 Post(s)
Thanks Andrikos! Yes, I removed the shims this afternoon with the help of arandolph. Got my first beauty scrape on the clam too. No biggie, had to happen sooner or later.
Sorry I stole the CO eBay Elise from you.
Yeah, you're so lucky my esnipe bid of $34100 didn't go thru.
11 Honda CR-Z EX
76 Porsche 912E
Old 04-15-2006, 04:34 PM   #16 (permalink)
Chococar's Avatar
Quoted: 0 Post(s)
Thanks JnC,
I'm going to get one!
--Joe
Old 04-15-2006, 04:35 PM   #17 (permalink)
pixlpush's Avatar
Images: 126
Quoted: 2 Post(s)
very cool, I just ordered one too. Only problem is rainy season is just about over. I'll be ready for next year.
2005 Elise, CO, LSS, Hard Top
2006 Mini Cooper S - peper white
1986 BMW E30 325E - 24 Hours of LeMons race turd
The B-Team, 24 Hours of LeMons Race Team
pixlpush is offline   Reply With Quote
Old 04-15-2006, 04:37 PM   #18 (permalink)
Andrikos's Avatar
Quoted: 0 Post(s)
Happy 1,000 posts!
Hey, all's well that ends well...
Enjoy your '06 and its probax seats, DBW and LED lights.
Sweet stuff.
Too bad I can't use your wiper mod as it NEVER rains around here...
Old 04-15-2006, 04:44 PM   #19 (permalink)
Dave's Avatar
Quoted: 0 Post(s)
Great write-up...nothing beats a good mod project
Dave is offline   Reply With Quote
Old 04-15-2006, 05:04 PM   #20 (permalink)
JnC
JnC's Avatar
Quoted: 0 Post(s)
I thought this could be done from the get go. Had to buy an Elise just to find out. I feel whole now.
(Done so far... micromirror, trunk carpet removal for bootie, TrafficPro install w/ aux in, rocker stickers (cheapo, i think yours are better), shim removal, third brake light blinker, and the relay. On the todo list, showercap velcro, nautilus horn, v1 wiring, garage door opener wiring.)
11 Honda CR-Z EX
76 Porsche 912E
Powered by vBulletin® Copyright ©2000 - 2015, Jelsoft Enterprises Ltd.
User Alert System provided by Advanced User Tagging v3.1.0 (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
