Key won't turn?
My wife just tried to take out my baby. She comes back in saying "I didn't do anything". My reply, "you obviously did something wrong". The key will no longer turn. I suspect she did something with the alarm, but have not had time to disconnect the battery and reset the system or look in the alarm manual. It happened two minutes ago. I have to go get the pizza now, so hopefully there might be a couple of insights when I get back. Thanks for the help.
PS it's not the steering lock, I checked that first soulman |
#3 (permalink) | |
Meow talk lotus one day?
#4 (permalink) | |
toys toys toys
If it's the steering column lock, try gently rocking the steering wheel back and forth while you try to turn the key. Sometimes the pressure on the lock mechanism is enough to prevent rotation of the lock cylinder. I have this problem with my VW Golf on a fairly frequent basis (at least once a week).
Randy V. |
Fly N Lowr
My wife told me the same thing about my Passat a few weeks ago and that was the problem, a little pressure on the steering wheel and all was good. Let us know if that is all that was wrong.
If you're not living on the edge you're taking up too much space!www.GoodBodyHealth.com |
#7 (permalink) | |
05 Mag Blue LSS/HT
#9 (permalink) |
My son is now in bed so I will attempt to trouble shoot. It is not the steering lock. The wheel was free the whole time till I moved it and it finally locked. Yes, I've had the steering lock prevent the ignition from turning in other cars. So I know it is not that. I will give the key hole a shot of lubricant to see if the pins are stuck. Probably the problem.
soulman |
#10 (permalink) |
It has to be something with the lock. Has anyone else noticed that when you take your key out you usually get a pretty decent click and then the power to the stereo shuts off. It's always been louder and heavier sounding than any of my other cars. That click is no longer there. The key slides too easily in and out of the lock. I've tried both keys and no love. I'll wait till morning and then give the dealer a call. This should be fun. Maplecrest is only 85 miles away.
soulman |
#11 (permalink) |
Registered Loser
if it like the BMW's that loud click is the steering lock pin being released........ so in an emergency, where you need to shut the eng down with the key (stuck gas pedal), you don't inadvertantly lock the wheel in the process
#12 (permalink) |
formerly known as fastwrx
I have had this problem a few times. In my case, it was not a matter of the steering wheel "leaning" on the steering lock. Even after moving the wheel, the key would not turn. Only after taking the key in and out a few times and jiggling it, was I able to get it to finally turn. I will bring this up at my next service.
Mike
The "car-tist" formerly known as Fastwrx! 2004 Subaru WRX STi 2005 Lotus Elise CO, LSS, Hardtop, Starshield - Got it!! |
#13 (permalink) |
I had the same problem a couple of months ago. It turned out that the key mechanism on the steering wheel needed to be replaced. I was told that this has happened to a number of Elise’s in England too. What is your Vin #. I bet a few of us got defective parts. It was an easy fix, they just swapped out a new key ignition mechanism and then swapped all the locks on the car.
#14 (permalink) |
Scottyb, that's what it seems like. Thanks for the info.
Congrats on the turbo, I am trying to talk the wife into it before I am forced to leave the east coast. I've got a year and a half.soulman |
#15 (permalink) | |
#16 (permalink) |
My vin # is 3320.
Scottyb, did you have to get towed? If so, did Lotus reimburse you for it? I should have a very nice tow bill when this is all done. It actually has to go from dover, DE up to Rothrock outside of Philly. I know, I accidently said Maplecrest earlier, I meant Rothrock. The flatbed truck should be here this afternoon sometime. soulman |
#17 (permalink) | |
No I actually finagled my key in and got the car started and drove to HRM. When I got there, I told them to not take the key out or turn it otherwise the car couldn’t be started again.
I think my vin is 952 Quote:
#18 (permalink) |
Wicked
Something like this happened to me the other day. In my case the cylinder was stuck in the in/out direction. I needed to insert the key, and push it in very hard to pop it loose. While in that stuck state, the steering wheel was not locked, and it wouldn't lock. I could turn the wheel as much as I wanted. It was weird, but hasn't happened since.
S |
#19 (permalink) | |
#20 (permalink) | |
Wicked
S |
