Old 08-06-2009, 07:29 PM   #1 (permalink)
Hobby Racer's Avatar
Low Voltage in Fuse Block "C"
Anyone have an idea what would cause the voltage measured from Fuse Block "C" (located under the passenger footwell) to be ~9.4V .
I have my oil pressure and AFR gauges powered from Fuse C3 (Aux Key In) and they stopped working today. After checking everthing else I measured the voltage in the fuse block and its ~9.4V.
The aux power socket (cigarete lighter port) measures 12.4V so the battery is not the problem.
Hobby Racer is offline   Reply With Quote
Old 08-06-2009, 07:41 PM   #2 (permalink)
Alarmed & Dangerous
TheViper's Avatar
Check that the fuse has not blown and you are getting a back flow. Otherwise the only thing that could reduce the voltage to that level when it is OK elsewhere is a high resistance between the ignition switch and the fuse.
Old 08-06-2009, 08:27 PM   #3 (permalink)
I checked the fuse and its ok. I also measured the voltage from the fuse slot after pulling it and thats were I got the 9.4V.
What do you mean when you say "back flow"?
