I just called your Mom
My alarm situation - help pls?!
ok, I dont have too much time to search here because my alarm is going off periodically! as u can guess I'm NOT popular with the neighbors! HELP please:
background is that the alarm ran the battery down. I hooked up the battery tender and about 45 minutes later, enough juice got in so that the telltale alarm light was flashing like normal. I clicked the A button on the remote, but the car wouldnt unlock. Now the alarm is going off again! brb... anyone pls.... (Edit) back now... so even though I can put the key in the ignition and turn the ignition, i cant start the car of course bc of the alarm. The power windows go and up down slowly so there's not much juice. I checked the light on the fob and when u push it in, it flickers red so that has enough juice right? what the hell do i do?
2002 Brian Moore C55 >> 2002 Ibanez AR250 with Gibson Burstbuckers >> 2001 Taylor Grand Auditorium >> 2000 Les Paul Custom 3 pickup >> 1998 Brian Moore C90 >> SRF chassis 543 >> 1976 Rickenbacker 4001 >> 1972 Fender Telecaster >> 1939 Gibson Archtop Last edited by snuggles1 : 07-31-2009 at 02:06 PM. Reason: came back in |
and i tried the "reset" idea, where you hold both fob buttons down for 10 seconds and then the large button... that did nothing.
2002 Brian Moore C55 >> 2002 Ibanez AR250 with Gibson Burstbuckers >> 2001 Taylor Grand Auditorium >> 2000 Les Paul Custom 3 pickup >> 1998 Brian Moore C90 >> SRF chassis 543 >> 1976 Rickenbacker 4001 >> 1972 Fender Telecaster >> 1939 Gibson Archtop |
and i tried using the CDL button to unlock the doors... that doesnt do anything either
If you only have the battery on a tender, do not attempt to do anything with the alarm for at least a day. A nearly dead battery will take a few days to completely charge using a tender and if it was deeply discharged, it may not ever recharge using a tender. Your best bet is to get a standard battery charger to fully charge the battery and once it is fully charged, then try to turn off the alarm and immobilizer. The set alarm does not like low voltage and can perceive this as an attempt by someone to steal the car by tampering with the battery. Once full voltage is restored, the alarm should respond to your alarm fob again or at least to a reprogramming/resync. Remember, tenders are only for maintaining a battery and not for recharging a dead battery..
welll i've gone thru most of LT looking for a solution...
Viper if u're here, do u think i need to disconnect the battery? i dont know why that'd help but I'm up for anything. I really dont want the alarm going off anymore (there's a very old neighbor next door) THANKS
thanks, i forgot to mention that i attached my other car up with jumper cables (knowing that the tender wouldnt get her done soon). but the alarm kept sounding so I unattached it... see my problem?
thanks
#7 (permalink) | |
#8 (permalink) |
right..."shut off the alarm"... i must be dumber than i thought, but HOW DO I shut off the alarm? this is why I started this thread... like i said the fob isnt doing anything even tho the red lite is on.
#9 (permalink) | |
Alarmed & Dangerous
The car battery is too low and switching over to the alarm back-up battery. As Tesprit says, you need a proper battery charger to bring the battery up to full charge. An alternative is to jump start it and take a substantial drive to recharge it. If you disconnect the battery, after a few alarm cycles it will not sound anymore. Use some jumper cables to apply 12V then turn off the alarm.
Michael Quote:
#10 (permalink) |
You need to access the battery and restore full voltage to the car even if the alarm is still blaring. You then need to shut off the alarm by using the remote, but if that no longer works, you will have to resync. your fob or use the manual method of entering your alarm PIN using the ignition key to turn off the alarm. Right now the alarm thinks someone is stealing your car (low voltage and a door has been opened with the alarm still armed) and it won't stop until you get full voltage restored and the alarm off. Is there anyone there that can jump your battery to a fully charged one or has a start pack that you can attach to your weak battery?
#11 (permalink) |
jump start it? how? the car is not responding to the fob...therefore even tho I put the key in the ignition and turn it, the immobilizer disallows it from starting!
#12 (permalink) |
ok so if i understand, i should allow the alarm to periodically sound while i pump more voltage into the battery from my other car? eventully it gets enuff power to respond to the fob?
#14 (permalink) |
i wonder if i messed it up by resetting it so many times...this is beyond frustrating. i got 2+ hours into this. more time than i spend driving the car in a week.
#16 (permalink) |
thx for your help... i cant believe how long this is taking tho
edit: this is unbelievable. i just clicked the large fob button and wow! the car responds and the door locks pop uo! great right? well the car wont fire. fine. didnt expect it to necessairy but then five minutes later the ALARM SOUNDS AGAIN! how?? the locks are up.... what does it think it is doing?
2002 Brian Moore C55 >> 2002 Ibanez AR250 with Gibson Burstbuckers >> 2001 Taylor Grand Auditorium >> 2000 Les Paul Custom 3 pickup >> 1998 Brian Moore C90 >> SRF chassis 543 >> 1976 Rickenbacker 4001 >> 1972 Fender Telecaster >> 1939 Gibson Archtop Last edited by snuggles1 : 07-31-2009 at 03:46 PM. |
#17 (permalink) |
Alarmed & Dangerous
The voltage is marginal, I guess there was enough voltage to enable the DSL but not enough to turn off the alarm.
Don't you have another car to jump from? Or a least apply voltage to turn off the alarm. A fully charged battery is the answer. Michael
#18 (permalink) |
yeah, we covered that .... the good car has been hooked up and revved > 2000 rpm. etc... this is confounding.
and now the speedo and tach are stuck, not anywehre near zero
#19 (permalink) |
Alarmed & Dangerous
So you have the battery jumpered to another battery and the alarm won't turn off? Your remote appears to be in sync if it unlocked the doors. You can always reset the instruments later.
#20 (permalink) |
sorry, whats a dsl? again, the locks came up, i thought i was home free. now getting too late since people are home from work to allow the alarm to sound every 10 minutes, the police will come and haul me off like an african-american professor at Harvard!!!!
