My Ultimate V1 install
Well I have finalized my V1 install. The main unit is completely hidden inside a plastic box that looks like an interior brake light. It has an unobscured view infront and behind for the best protection. I have my concealed display installed in the stock rear view mirror. Also I have the audiocontrol and a second concealed display in the driver's side cubby hole.
Trackday junkie
But does you fake light light when you hit the brake...JK best "stealth install I've yet seen!
kudos
Driving an EVO but hope to get an Elise fast enough to entertain me! Exige T-2 test car....got to teach the turbo boys some respect |
#3 (permalink) | |
Scotty, I was out test fitting in my car and it seems that putting the bottom of the V1 box on the small ledge at the bottom of the window, might be too low. It seems like the lin of sight behind the V1 is interrupted by the raised section of the rear engine cover. Do you think this is not a problem?
I am also thinking of creating a simple mod to the V1 box to incorporate LED based backlighting on a pcb mounted surface mount array that can sit behind a red lens.
Please do not PM me. My box is full. Thanks. |
please don't hit my car
http://www.valentine1.com/laserhowto/
Does the fiberglass obstruct radar that much? I've always mounted as high as possible. |
#6 (permalink) | |
#7 (permalink) | |
As for the hight. I originally had it mounted to the roll bar next to the drivers seat. I found that it obstructed my view with respect to the rear view mirror. My new position is much better for me. I don't think it makes that much difference in the Elise since we are so low down to the ground anyway. I think the absolute best placement for maximum detection would be about 1 to 2 feeet above the roof of the car. Maybe someone will fabricate some crazy wing, periscope, or antena for that. ![]() |
#8 (permalink) | |
We have any other EE's on the list who have done RCS studies on car paints? |
#9 (permalink) | |
#10 (permalink) |
>>>This is because of the size and the shape of the metal crash structure in the front of the car.<<<
Actually the front crash structure is composite. But the alloy frame and higher frame elements are likely pretty noticeable to radar. |
#11 (permalink) | |
A good question would be does the composite crumple/crash zone absorb any radar? That would be cool indeed. |
#13 (permalink) | |
http://www.apexcone.com/prod_invisimirror.html They use bmw & boxter mirrors wich are smaller than the stock Elise (GM) mirror. About $300 Or you can go to: Steve Courtney Impact Product Development Inc. impactpd@telusplanet.net He will install it in a stock mirror for you for about $450. |
#15 (permalink) | |
Take the cealed display apart. Then take the mirror apart. You can scratch the silver lining off the back of the mirror where the display is going to be. Secure the concealed display card with glue or acrylic. I wish I took pictures of my mirror when it was apart. If you can soilder then you shouldn't have a problem with the mirror. If you screw it up, just buy another GM mirror $40. |
#17 (permalink) |
FWIW some of the old Corvettes were pretty good radarwise. The C3 (late 60s to early 80s) had an angled radiator (tilted rearward viewed from the open hood) that reflected the signal to the sky. So the distance at which the radar gun could get a lock was cut way, way down - giving the driver plenty of time to react to the warning emanating from the radar detector. Our radiator is horizontal and the front frame elements are pretty much vertical. I wouldn't be surprised if the Elise's radar stealth factor could be improved with some tweaking.
#18 (permalink) |
COM Court Jester
laser/radar
When looking into radar detectors and laser blockers, I learned quite a bunch from some websites. Radar is not affected by the paint color (unless the metallic content is high) but laser is. Therefore, a black vehicle will have a smaller laser return.
Laser is highly focused, and cops are taught to aim at your front license plate (most are now made with special coatings/materials that reflect laser even better than a normal metal plate would!) and if that is not available, your front headlamps. Our cars are good against laser primarily becase most of us dont use a front plate and the cops have to work hard to paint the front headlamps with the beam. That is ALSO why the all-in-one detectors like V1 and Bel RX65 score lower onlaser detection than the more expensive "component" detectors/blockers. The laser detector is usually mounted high up, for better radar detecting, but then doesnt get hit by the laser beam - unless the cop paints someone else and you detect the scatter. Its not that big a deal though, cause most times you dont have enough warning time with laser to slow down ... the detector simply lets you know your about to get a ticket! That is why component units like the "Blinder M-20 X-treme Laser Jammer" (for a low low price of $284 ... best price ive seen yet place their detection/jamming units in the front grill of cars/trucks, close to both the headlamps and the license plate. Check this out for more info... http://www.speedzones.com/ they LOVED the Blinder... said it jammer laser each time, every time, all the time. I am going to pick one up as soon as I get some spare cash!
Night life guide and other things to do in New York City! Limited Slip Mafia member since Dec 2005; COM member since Oct 20th, 2004. 2005 Southern New York SCCA SS Championship: second place. "The passenger seat is smaller than the driver's seat, and it is bolted in place. It is there where you tell someone, 'There is your spot; keep your elbows out of the way and hold on.'" ---Lotus Cars USA spokesman Colin Price |
#19 (permalink) |
COM Court Jester
oh ! and!
Scotty:
Awsome job on the install!! Looks totally professional, I love it! Kudos! -=cixel
#20 (permalink) |
Scotty,
The install looks great! I would love to do something similar to my elise. After all the work you did, why didnt you use a smaller rear view mirror? I think the stock one is too big for the car.
Carlos 05 Elise CO, touring 02 Audi Allroad |
