Old 09-30-2008, 02:58 PM   #1 (permalink)
TroyLotus's Avatar
NEED HELP. Fan switch wiring.
I need some help with the fan switch wiring. I took off the cover to paint it and thought I had to pull off the 5 green wires to the switch to get to the screws. I did it careful but I am not sure I am putting them all back on the correct way. They all seem like the same coloring basically and nothing way different with them. Can anyone help me to figure out which wires go where on this switch. There are 5 wires and I am not sure where to put them. I can get it to work and it has off, then the slow seems like medium, the medium seems like high and the high is the same so I am not sure what I am doing wrong. I did a search and could not find a wiring diagram or picture of the wires going in. Any help would be great.
Thanks
Troy
I also have only had the car for like a month so as far as I can remember it only had like off, then medium, then high, and then same. Is this the correct wiring or is there really a slow speed? I would think so.
TroyLotus is offline   Reply With Quote
Old 09-30-2008, 03:02 PM   #2 (permalink)
Ex-Brit
TheViper's Avatar
Hope this helps.
A/C Improvement Modifications
http://www.lotustalk.com/forums/f3/e...ent-mod-59938/
1) Insulate the cockpit from Solar (3M Crystalline Tint) & Convected (insulate sills) heat.
2) Replace evaporator thermostat with an upgraded electronic version to prevent freeze up.
3) Increase airflow into cockpit by removing both driver & passenger side footwell intake panels & blocking 2 outside air intakes in nose.
Old 09-30-2008, 03:30 PM   #3 (permalink)
TroyLotus's Avatar
That is just what I need, but I can not tell the colors of the wires from that, meaning the little yellow stripe on one, the blue stripe on another and if one is solid green.
Old 09-30-2008, 03:36 PM   #4 (permalink)
TroyLotus's Avatar
I got it. Thanks a lot. After looking at your picture for a bit and the wire size, guage/thickness I figured out what ones to put where and it works good now so thanks for the help.
Troy
HTML code is On
