NEED HELP. Fan switch wiring.
I need some help with the fan switch wiring. I took off the cover to paint it and thought I had to pull off the 5 green wires to the switch to get to the screws. I did it careful but I am not sure I am putting them all back on the correct way. They all seem like the same coloring basically and nothing way different with them. Can anyone help me to figure out which wires go where on this switch. There are 5 wires and I am not sure where to put them. I can get it to work and it has off, then the slow seems like medium, the medium seems like high and the high is the same so I am not sure what I am doing wrong. I did a search and could not find a wiring diagram or picture of the wires going in. Any help would be great.
Thanks Troy I also have only had the car for like a month so as far as I can remember it only had like off, then medium, then high, and then same. Is this the correct wiring or is there really a slow speed? I would think so. |
Ex-Brit
Hope this helps.
A/C Improvement Modifications http://www.lotustalk.com/forums/f3/e...ent-mod-59938/ 1) Insulate the cockpit from Solar (3M Crystalline Tint) & Convected (insulate sills) heat. 2) Replace evaporator thermostat with an upgraded electronic version to prevent freeze up. 3) Increase airflow into cockpit by removing both driver & passenger side footwell intake panels & blocking 2 outside air intakes in nose. |
