Need Pics/Info on Headlight Switches/Panel - LotusTalk - The Lotus Cars Community
Old 12-26-2012, 09:22 AM   #1 (permalink)
100% Braj
SwingLo's Avatar
Can someone hook a brotha up?
My car is in storage and not near me and my searches have been fruitless.
Can someone tell me the order of the 3 light switches (top to bottom). Specifically:
1 (top)
2 (middle)
3 (bottom)
Also, can you snap a pic with the lights on? I ask because I think my switches may be reveresed from when my interior was redone (and I think I have an LED or two out).
Thanks!
You are sleeping. You do no want to believe. You are sleeping.
SwingLo is offline   Reply With Quote
Old 12-26-2012, 09:24 AM   #2 (permalink)
The Doombringer
antinym's Avatar
I only have 2 buttons.
top = parking
middle = head lights.
Though with DRL, I don't have to hit the middle.
And yes, they can be reversed, I reveresed mine accidentally once.
...and as always, my opinion is worth what you paid for it.
antinym is online now   Reply With Quote
Old 12-26-2012, 10:06 AM   #3 (permalink)
MotoGeek's Avatar
Luckily, since it's a Lotus, you can claim it came that way from the factory and most people will believe it.
MotoGeek is offline   Reply With Quote
Old 12-26-2012, 10:23 AM   #4 (permalink)
2009 Cup 260 M/Sport
<@¿@>'s Avatar
OEM for 2009 Exige Cup 260 M/Sport (Track only car right from the factory...1 of 12 built by Lotus)
All I want out of life are the keys to Jay Leno's Garage...
A man's mind, once stretched by a new idea, never regains its original dimensions.
[Oliver Wendell Holmes]
<@¿@> is online now   Reply With Quote
Old 12-26-2012, 10:59 AM   #5 (permalink)
100% Braj
SwingLo's Avatar
Ok, so I know what I'm looking at:
Top - Parking Lamps
Middle - Headlights?
Bottom - Driving Lights?
Old 12-26-2012, 11:22 AM   #6 (permalink)
Top - Parking Lights
Middle - Headlights
Bottom - (optional) driving lights
2005 Lotus Elise Katana2 and much more
JohnnySniper is offline   Reply With Quote
Old 12-26-2012, 11:23 AM   #7 (permalink)
Bottom is rear fog lights. That's not a standard switch for NA street cars.
2009 Elise SC
Surge is offline   Reply With Quote
Old 12-26-2012, 03:32 PM   #8 (permalink)
mspenard's Avatar
Anyone know the part# for the bottom fog light switch and where it can be purchased?
mspenard is offline   Reply With Quote
Old 12-26-2012, 04:09 PM   #9 (permalink)
<@¿@>'s Avatar
Switch, rear fog lamp, yellow tell-tale A117M0056F
Decal, rear fog lamp graphic, LHD A117M0046F
Old 12-27-2012, 07:41 PM   #10 (permalink)
90% go, 10% show...
Apex_in_sno's Avatar
1 (top)
2 (middle)
3 (bottom)
Thanks!
It's not possible to put the switches in the wrong openings, each switch is mounted to a circuit board, which are all daisy chained together via ribbon cable.
VFII, Eliseparts Sequential, Geartronics Paddle shift.
You name it, I've probably got that installed too...
1864lbs, full tank
Otherwise, it's bone stock....
Apex_in_sno is offline   Reply With Quote
Old 01-10-2013, 02:40 AM   #11 (permalink)
German Reimport
Mr.C's Avatar
Originally Posted by Larrynelson View Post
Hello
Have you tried sites like ebay? You will get plenty of good headlights at very affordable prices.
Nobody asked to purchse headlights. Your post sounds like spam, just like the other one you just posted
Mr.C is offline   Reply With Quote
Old 01-10-2013, 02:50 AM   #12 (permalink)
German Reimport
Mr.C's Avatar
This is not true
The circuit boards are just for iluminating the labels and they have their own power supply which is independent from the switches.
The switches are mounted thru a hole in the switch panel and circuit board and then everything is held together in the back with a nut.
You actually do need to pull the switch thru the circuit board in order to get them out.
The switches themself have a connector in the back which is identical on all three switches.
Therefore it is very much possible to hook the switches up wrong.
This link has some pictures:
Fog light circut added
Old 01-10-2013, 03:01 AM   #13 (permalink)
German Reimport
Mr.C's Avatar
Looks like someone also installed your switch panel incorrectly.
From the factory the switch would be on the left and the label on the right like in the attached picture.
I guess this is so one can see the labels better from the driver position without them being hidden behind the protruding switch.
Yours are turned around.
This can happen since there are two holes for each switch.
Old 01-10-2013, 04:57 AM   #14 (permalink)
<@¿@>'s Avatar
Or it was done intentionally at the factory because mine came from the factory with the full roll cage. This is 1 of 12 Cup 260s built in 2009 for track only use...mine is special!
Old 01-10-2013, 06:29 AM   #15 (permalink)
100% Braj
SwingLo's Avatar
Attachment 198518
Yeah. No biggie. I got it all squared away and even did the 'red LED bulb' for the start engine mod.
Thanks
Old 01-10-2013, 06:38 AM   #16 (permalink)
JWA
Exige Sport 260
JWA's Avatar
FWIW, the stock switches that Lotus uses throughout most of the interior are the APEM IP series. You want the IPR (round), and then whatever color/finish/action/light/lugs option. Here's a link to their catalog:
http://www.apem.com/files/apem/broch...IP-mom-ENG.pdf
JWA is offline   Reply With Quote
Old 01-10-2013, 07:53 AM   #17 (permalink)
German Reimport
Mr.C's Avatar
But if it was done for access reasons, then how do you get to those coins in your cubby
