Wizard of Pugz!
New Sealed Battery Option - Cheaper, Better!
BAB26-12***TEMPEST High Performance SEALED LEAD-ACID AGM BATTERY
Exactly the same size as Odyssey PC680 but 53% more reserve (26AH vs. 17AH) Cost is ONLY $86.00 - 47% cheaper (compared to $127 for the PC680) Fits perfectly with Sector111 Battery Bracket. I just installed one and it fired right up on my S. Last edited by qball : 09-25-2008 at 10:21 PM. |
Wizard of Pugz!
Slightly less reserve and CCA, only $64.50
BAB22-12***TEMPEST High Performance SEALED LEAD-ACID AGM BATTERY Last edited by qball : 09-25-2008 at 10:22 PM. |
(Formerly PESTODUDE)
15 lbs....not bad but my Voltphreaks battery weighs 4.5 lbs, is half the size and has worked flawlessly for almost a year now.
Randy '07 Phntm Blk Exige S. Proalloy chargecooler, RLS IC tubes, Sector RTD brace, Manly's motor mounts, cup air box, CF Sector front splitter, wing, and side scoops/ mesh removed, SS brake lines, Sector and "Stan's" shifter mod, "Stan's" clutch pedal mod, Voltphreaks 4.5lb battery, Gotham tune. |
Unfortunately, in lead acid, LBS = AH capacity to first order. I really doubt they are really getting 52% more capacity in the same weight as a PC680. If you look at most LA batteries, they get 1AH per lb. This one is claiming 1.5AH per LB.
Not saying it won't work, I just don't think it's really 26AH, at least not when tested the same way the Odyssey or Braille batteries are. |
#7 (permalink) |
Regurgitated User
yeah - i picked mine up for a dollar a pound, expensive true! - but i have to also say that i have had no issues what so ever - it can go 2 weeks with no charge and starts better than the stock battery ever did - starts the HID when car is not running etc...
Driving it around!
#8 (permalink) |
Alarmed & Dangerous
I compiled this, and you guys may find it interesting
![]() I know what works for me, but everyone has different requirements.
#9 (permalink) | |
Wizard of Pugz!
I think you meant a hundred dollars a pound, right? ![]() |
#10 (permalink) |
Wizard of Pugz!
I just wanted to post an update.
I have had ZERO problems with this battery. If my Exige sits without use, it lasts about twice as long as the PC680 it replaced before I have to add a trickle charger. Starts like a champ. Extremely good bang for the buck! ![]() |
#11 (permalink) |
Head LOONY
I may put one of these in my Elan. Does anyone have a source for the adapters that go from regular battery "post" ends to the screw ends that are on this battery?
Tony Vaccaro 2005 Ardent Red, Katana Supercharger, Touring, Hardtop, Driving Lights, HIDs, Rear Window Shield, Red Mounts, Laser Shifters, V1, LETSLA Shifter, www.lotusowners.com LOONY (Lotus Owners of New York) and the Church of the HolyLotus Supplier of Polycarbonate Shield for Rear Window IN STOCK , Drive Fast Take Chances |
#12 (permalink) | |
short angry bloke
SLA Battery Adapter Connectors Search for "Odyssey battery adapter" but be warned - the socket head cap screw in the adapter is captive under a threadsert so it might take a bit of fettling if the threads on the captive screw and the battery don't match up.
torque (tôrk) n. - an excuse for the lack of momentum. - let's bring back CanAm & Group B! - have you hugged your Exige today? I'm currently working on my performance driving merit badge. There's always somebody faster, sometimes it's me. |
#14 (permalink) |
Track Addict
I dont drive my car that much. Can this battery qball mentioned last longer than the OEM battery? My concern is more on the longetivity, not weight. What's a few pound for me if I can't drive it after a week? I am skinny dude anyway, so it's already compensating, hahaha.
#15 (permalink) | |
Head LOONY
i just started up my car after being parled for almost 2 months. Started rigjt up. I only wanted to use this cheaper one as I did not want to spend that much on my elan. i still think the odyssey is the way to go on the elise.
#16 (permalink) | |
Alarmed & Dangerous
In your circumstances you need the largest capacity (AH) you can find.
See schedule in post #8. Michael Quote:
#17 (permalink) |
2009 XP National Champion
![]() Join Date: Oct 2003
Qball,
Sounds like a winner my PC680 lasts almost a week now.... I would worry about weight, but with the amp in the trunk.....
#19 (permalink) |
Idle @ 5700rpm
Hmm.. What's up with Voltphreaks?
Their LiFePo4 based batteries carries an insane price. VPH700 (14Ah) @ $1,220 ? Say they are using LiFePo4 1200mA cells, that's 40 cells combined. Each of these cells cost about $0.99 from my source, and that's proper quality with high discharge. Cheaper ones can be gotten for half that and less. What exactly is driving up the cost of these batteries? I mean.. c'mon.. under/overcharge prot. and discharge circuits cost? ;p Edit: http://www.valence.com/sites/all/the...ta%20Sheet.pdf 40Ah @ $890 incl. CANbus datamanager.
2005 Saffron Yellow Fed. Lotus Elise [Touring, Sport, Premium and Blackout Pack, Stage 2 Exhaust, Hard/Soft Top] - [Currently @ 6500 Miles] [CF Centre Console, Zoom Eng. CF Rearview Mirror, iTG Cold Air Intake, 55w 8000k HIDs, Engine Dampers, reVerie CF Engine Covers, Raised Rear-Lotus Letters, A/C Bypass Switch] Last edited by xceed : 01-05-2009 at 07:28 AM. |
| Display Modes | |
