Old 02-07-2008, 09:24 PM   #1 (permalink)
Plug Whisperer
turbophil's Avatar
Images: 3
Nxt Mod: Replace Stock Gauge Cluster with DASH2
As if I don't have enough going on with my car, I'm thinking it's time to replace the stock gauge cluster with a DASH2 as I install a DL-1...
I've gone back and forth with Charlie quite a bit and I think this is doable. THANKS CHARLIE...
I'm open to suggestions as I don't have every wrinkle ironed out here, but here's the basic idea.
Simply unplug the stock Gauges, mount a DASH 2 in its place. Aside from track specific data logging, I believe I can get all the basics covered with the OEM sensors minus oil pressure. I'm planning to tap into all the needed wires/sensors close to the ECU (easy to do with the clam up)...
1- Fuel tank Metering, Tap ECU pin 76- Need the equation still
2-Speed- Tap ECU pin 77- Should be easy to establish pulses per revolution. Always happy to profit from someone else if you already know though
3-RPMs- Induction, which I've I already donend in the cab...
4-Water Temp- Tap pin 33- Although I need the equation to turn the signal into degrees for the DASH2... any ideas here?
5- Switched 12V- Easy enough
6- Oil Pressure- No Dice. Need to get a sending unit
Other things: I should be able to simply wire the high beam indicator and turn signal directly to the D2. Charlie has told me that the ABS and air bag lights will need a resistor to fool the system into thinking everything is OK. No big deal. I'm not too worried about trouble codes, as it's easy enough to check for codes on a random basis since the ALDL isn't impacted by this mod.
Other2: It's important that the D2 receive an internal (analog) signal for speed even though it has the ability to display GPS speed. The odometer will only read the internal signal and I think that's an important function for resale (like I ever plan on selling this car)...
Mounting: I would think that should be easy enough in the stock binacle...
Any other ideas or comments? Let me know... I'm thinking this could be a pretty fun mod. The Dash2 appears to have sooooooooo many capabilities for the track car and a lot of cool gadgets for the street car
Best,
Phil
| '05 GG LSS Elise | A Track Chariot | BOE ClamHinge | BOE TVS SuperCharger 275whp/175wtq | EFI Standalone Engine Management |
See my car at BOE Fabrication: www.boefabrication.com ----->Last Updated: 11/09/08
If something ain't worth doing right, it ain't worth doing at all...
Old 02-08-2008, 05:00 PM   #2 (permalink)
Plug Whisperer
turbophil's Avatar
Images: 3
Progress Made!
Today was a good day...
I spent quite a bit of time on the phone with Al Seim at RTUSA today and ordered the DL-1 and Dash2 along with some fun sensors like 1.5Bar MAP
Al was a big help. We decided that my assumptions and information Charlie helped me with were correct. Darksol is also a freak about his DL-1 and has all 4 wheel speed sensors, along with TPS and several others already figured out and connected to his DL-1. So I know I'll be able to use internal and OEM feeds to the D2 for the critical inputs for daily driving along with a non-resettable Odometer.
The D2 measures about 4" high by 6" wide. The opening for the gauges is about 4" by 8" so the fit should be great and it doesn't look like I'll have to send all that much wire up front either.
Not sure if anyone else is interested in replacing their stock dash, but I'll keep updating this thread just in case. I'm going to try and keep this mod looking good while adding function and gadetry to the car Total cost so far is about 1,600 bucks and it looks like that's going to be close to about it, as everything else is stuff to make in the shop along with a couple switches...and that won't be much...
Best,
Phil
Old 02-08-2008, 05:54 PM   #3 (permalink)
King Alexander
Why not use the AIM dash?
alexandertg4 is offline   Reply With Quote
Old 02-08-2008, 07:04 PM   #4 (permalink)
right seat driver
Brent Bauman's Avatar
I'm putting in a Aim MXL Pro. All duetch connectors and CAN com with the ecu. I have most of the parts and sensors but it is a few steps down the road in the project.
Brent Bauman is offline   Reply With Quote
Old 02-08-2008, 07:10 PM   #5 (permalink)
Mods are good for you
Dave's Avatar
Phil...the disease...the disease
Very cool and watching this thread like a hawk...would be a great integration.
Mod Maniac: '05 SY - Supercharged (3.2") TVS soon! . EFI Engine Management . ACT HD Clutch . FF Cold Air . Center Fed Fuel Rail . Catch Cans . PPE FI Headers w/ 2Bular 6" . FF Damper . Ported Throttle Body . Black LSS . Braille 9.5lb B129 . Boot Lid Pin . LED Tail Lights . CF Console . CF A/C Surround . CF Diffuser . FF Half Lip Spoiler . Custom Gut Wing . B&M Shifter . Painted Stripes . Rubbertite Mats/Buttons . S111 Booty. HIDs . LED Lighting . VonHep Dash Bag . Tinted Glass . Tesprit Mirror
Dave is offline   Reply With Quote
Old 02-08-2008, 07:23 PM   #6 (permalink)
Super charged!
Vishus_1's Avatar
Images: 19
Any pictures?
Vishus_1 is offline   Reply With Quote
Old 02-08-2008, 07:31 PM   #7 (permalink)
disproving HD MTBF daily
charliex's Avatar
Black Exige S - http://goth.am 265 Mule / Elan M100 ECU Tuning, http://www.elisetalk.com/forums/showthread.php?t=39660
Arguing with an engineer is like wrestling with a pig in mud. After a while, you realise the pig is enjoying it.
charliex is online now   Reply With Quote
Old 02-08-2008, 07:38 PM   #8 (permalink)
jasond's Avatar
Ooh, that's very hot. It'll be cool if you get it working!
jasond is offline   Reply With Quote
Old 02-08-2008, 08:10 PM   #9 (permalink)
Super charged!
Vishus_1's Avatar
Images: 19
Hmmmm - not my taste. It's just so....digital. It doesn't seem like it fits the style of the car. I prefer the analog-type gauges.
I thought the japanese dash in another thread looked good because it was balanced. But to each their own... good luck.
Old 02-08-2008, 08:14 PM   #10 (permalink)
I agree the Defi cluster looks amazing, with a analog tach. Would anyone know what the guage on the left dial would be if it was the N/A cluster.
Waiting for someone to bite the bullet first on the Defi Super Sport Cluster before i give it a go.
07 Exige S - PhB., TP, TP, LSD, Rear Panel Delete, Custom Magnaflow Exhaust, Custom AEM Intake, 6k HIDs, Schroth 4pt ASM Harnesses
Sh4rkattk is offline   Reply With Quote
Old 02-08-2008, 08:22 PM   #11 (permalink)
charliex's Avatar
I don't care for the dash 2/aim style either, but i'm going all 'digital' still at least with that you can change the graphics to anything you like.
the defi is a nice mix , bet it ain't cheap though, i really like my Defi gauges though
Old 02-08-2008, 09:32 PM   #12 (permalink)
Plug Whisperer
turbophil's Avatar
Images: 3
Some Clarification...
While all digi isn't my preference, I like data...and lots of it... Oh yes, and gadgets too... This is one of the most tried and trued systems out there... Ran by racers all over the world and seamlessly integrates with the DL-1... 'er so that's what I'm told
Really though, this isn't an "if" I get it working, it's "when" All critical sensors, wheel speed, water temp, tach, fuel level, are all pulled with out any additional senders--> just wire taps...
Some cool bits about the D2 is that it was designed to be a true dash replacement and not just suction cupped to the wind shield or dash board. Little things like the gear selection display, shift lights, lap time display, multi-sensor disply, etc all make it seem like the proper fit for a track/road car. The Dash3 is coming out which will display some data but is really just another peripheral in the car. I want the data display to be *installed* and part of the car. I'm not a gifted computer hack like Charlie nor do I want to troubleshoot marrying two different systems together... so that's how I came to the DL-1/D2 combo. Our stock gauges are pretty useless anyway (inaccurate speedo, slow tach) and aren't particularly pretty, so I figure why not just toss them on to the discard pile along with the NA intake manifold
Best,
Phil
Old 02-08-2008, 09:34 PM   #13 (permalink)
charliex's Avatar
where's the fuel display !
Old 02-08-2008, 09:41 PM   #14 (permalink)
Plug Whisperer
turbophil's Avatar
Images: 3
Good question.... You can toggle displays. Here's another screen:
Old 02-09-2008, 07:28 AM   #15 (permalink)
reganfin's Avatar
Best,
Phil
Sounds like you are hardwiring in all of the sensors. Did you buy the can adapter from Al?
Whisky may not cure the common cold ……
but it fails more agreeably than most other things.
reganfin is offline   Reply With Quote
Old 02-09-2008, 09:28 AM   #16 (permalink)
Plug Whisperer
turbophil's Avatar
Images: 3
I didn't... I didn't think it would talk the same language and I didn't want to try and figure it out- again, not a computer wiz here (Maybe I assumed wrong???)... In any event, there's only a few wires that I need to run directly to the Dash2-- Speed, rpm, and fuel. Each of those is only one wire each. That way if I ever need to pull the DL1 for some reason, the Dash will still operate just fine for street driving. I'll run engine temp and others straight to the DL1. The Dash2 and DL1 communicate bi-directionally so anything I hook up to the Dash2 will also be logged through the DL1 and anything hooked up to the DL1 can be displayed on the Dash2.
All this will be completely reversible should I ever want to go back to the stock dash since all I'm doing is tapping into a handful of wires...
I'm going to use a remote start/stop button for the DL1 and the Dash2 requires 4 momentary buttons as well. So I'll have a total of 5 momentary buttons that I need to mount someplace. I'm going to order 4 of our trip reset buttons from Lotus so that all these buttons match. So now I need some ideas of where to hide the DL1 and where to mount these buttons...
Ideas?
Best,
Phil
Old 02-09-2008, 11:00 AM   #17 (permalink)
Twisties Addict
Bgwilly31's Avatar
what about odometer?
That would be very important on resale.
-Aspen White Exige S
04' Lexus Turbo IS300 BSM "track car"--SOLD
"Straight lines dont mean sh**"
Bgwilly31 is offline   Reply With Quote
Old 02-09-2008, 11:15 AM   #18 (permalink)
right seat driver
Phil,
When I was deciding between the different replacement dashes/dataloggers there were pluses and minuses to each system. The Aim's minuses were its cost. There is a brand new dash from Racepak, IQ3, that has tons of features built in, and expantion room. The Aim and Racepak combine the datalogging and display into one unit, where the Race-Technology unit is a datalogger with add on display. The Aim unit can combine video, data logging, display, lap timing, track mapping, Lamda, switch control, and sensors for nearly anything. It is expensive, I have over $5000 in hardware, but its limitations are few. I think the only system that is limitless in capabilities is motec. The Racepak IQ3 have put most of the high end features into a more cost effective package for applications that aren't full race.
Old 02-09-2008, 11:23 AM   #19 (permalink)
XPRMTL
perryeyges's Avatar
If you look along the bottom there is an odometer at the left and a trip meter on the right..
I want this mod!! My inst cluster has burned out lights anyway
One thing i don't see is a CEL... I like.... I want.....
How much????$$$$$$$ installed?
05 Elise Spyder II, Chrome Orange, 1586lbs. Stasis/Alcon "lotus cut" brakes, Supercharged and Intercooled @305 Crank HP
"My dream car is now operational!"
perryeyges is offline   Reply With Quote
Old 02-09-2008, 11:49 AM   #20 (permalink)
right seat driver
Perry,
Why don't you use the EFI dash since you have their ecu? It's capabilities are nearly endless as well.
HTML code is On
