#41 (permalink) | |
the devil's advocate...
#42 (permalink) | |
Plug Whisperer
.Further support from my buddy darksol is that the speedo is off, but the odo is dead-nuts accurate. indicating the possibility of a different source for distance traveled than CAN. Maybe it's the brain in the cluster that causes that delta??? Why would the odo have it's own 12v source that splices on page 3 rather than using either of the other 2 12v sources going to the dash... it doesn't jive to me... I guess I'll play with it. If it turns out that it's just a 12v source coming from fuse 8 up front, the wheel speed signals (all 4 of them) are running down the center of the cabin for super easy access. This project is looking to be pretty easy on paper. Your CAN converter would be sweet to make it SUPER easy though ![]() ![]() Best, Phil
| '05 GG LSS Elise | A Track Chariot | BOE ClamHinge | BOE TVS SuperCharger 275whp/175wtq | EFI Standalone Engine Management |See my car at BOE Fabrication: www.boefabrication.com ----->Last Updated: 11/09/08 If something ain't worth doing right, it ain't worth doing at all... |
#43 (permalink) | |
I agree that it looks wierd that the A1 pin happens to go right to the odometer so maybe it is. Further when I first did the CAN research and did my famous 150 mph sitting still in the garage the odometer did not advance even though the CAN was getting speed signals so it also lends credence to the seperate speed wire idea. the question is which wire is it? |
#44 (permalink) |
Plug Whisperer
Installed!
The dash is a complete standalone... Not quite finished but should be tomorrow
#46 (permalink) |
Plug Whisperer
I didn't want to cut off the pig tail for the stock cluster. This way the Dash2 is a standalone unit that I can revert back to stock if I want to... I still need to clean up the installation a bit, but it's pretty close how it is...
Best, Phil
#47 (permalink) |
Plug Whisperer
All Done
So here are the pics... I'm all done... Details.
I routed 2 CAT5 wires of different color. One for the Dash and one for the DL1. I tapped wires to avoid cutting. I prefer this method. All taps are just under the air box and pretty well protected. The dash looks pretty OE sitting in there . Notice the 4 button by the key hole. Those are the function/menu buttons for the Dash...The Dash PC software is very easy to work with and I had some fun tinkering with different configs. For the doubter out there, the below pics clearly show it working with car running ![]() Best, Phil
#48 (permalink) |
Mods are good for you
Oh yeah! That looks like OE and fantastic. Guess my wallet is about to shrink (again)
Mod Maniac: '05 SY - Supercharged (3.2") TVS soon! . EFI Engine Management . ACT HD Clutch . FF Cold Air . Center Fed Fuel Rail . Catch Cans . PPE FI Headers w/ 2Bular 6" . FF Damper . Ported Throttle Body . Black LSS . Braille 9.5lb B129 . Boot Lid Pin . LED Tail Lights . CF Console . CF A/C Surround . CF Diffuser . FF Half Lip Spoiler . Custom Gut Wing . B&M Shifter . Painted Stripes . Rubbertite Mats/Buttons . S111 Booty. HIDs . LED Lighting . VonHep Dash Bag . Tinted Glass . Tesprit Mirror |
#50 (permalink) | |
Plug Whisperer
Best, Phil
#54 (permalink) | ||
Plug Whisperer
I have a high beam light, fog light, and alternator/charging system light (the old battery light). It has a warning light for the brakes. Although, I learned that our cars simply connect the circuit to ground when blake fluid is low or park brake is on. The D2 looks for a hot wire. So I'll have to wire a relay if I want that light to work... No biggie... A project for another day. At this point my back hurts to much to tinker with it for a while ![]() The only things you lose are a handful of idiot lights: Airbag, MIL, ABS, Seat Belt. The ALDL/OBDII port still works, so the above can be checked there if one cares to look from time to time... It's hard to take a good photo of it. It really does sink right in there and it looks pretty cool. I can't wait to plug in the DL1 and get it displaying all sorts of stuff on it... I'm big supporter of wiring the dash up so that it can be a standalone such as I did. Of course if I ever sell the car, I can install the stock dash with little effort since all I did was splice... Quote:
![]() ![]() It seems to have more than sufficient contrast for sunlight. It was designed to replace an OEM dash, so RT had sunlight in mind when they made it... Not planning any kits at this time. I'll be happy to provide all the support I can for anyone wanting to do this yourself. It's really not that hard... Very timing consuming, but not hard...(Although I can't think of many things that are hard to do on this car. Some things just take more time than others )Plus, as it is, I'm backed up with clam hinges and a few other items for quite a while. I think Andrew (my partner in crime) would unplug the beer fridge if I took on another product ![]() Best, Phil
#56 (permalink) |
disproving HD MTBF daily
speed pulse should be brought out to the cluster, which is the odo.
the speedo are seperately calibrated, so even if the signal was sourced from the same place they dont have to match, but speedo is can, odo isn't i also have the connectors for the stock wiring harness/cluster plug for people who want to make a harness.
Black Exige S - http://goth.am 265 Mule / Elan M100 ECU Tuning, http://www.elisetalk.com/forums/showthread.php?t=39660 Arguing with an engineer is like wrestling with a pig in mud. After a while, you realise the pig is enjoying it. |
#57 (permalink) |
Looks awesome!
I wish my wife would let me tinker like that!
05 GG Elise: Exige clam, LSS, Stage 2, ACT HD, DBA5000, CF scoops/splitter/mirrors/panels Others: Lexus ES300 Coach, Volvo V70R 300hp/250k Missed: 01 Wrangler Sport, 04 Wrangler Sport, 71 CJ5 (225V6) Need a personal injury attorney in Kansas City? http://www.kcatty.com Need a Johnson County DUI lawyer? http://www.JohnsonCountyDUI.com Need a Johnson County speeding/traffic ticket attorney? http://www.JoCoTraffic.com |
#58 (permalink) | |
Plug Whisperer
![]() Well I guess it wouldn't have saved that much work, but I'll still take one... Mind dropping one in the mail to me? ![]() Best, Phil
#59 (permalink) |
#60 (permalink) |
Plug Whisperer
Thanks, maybe she will after she sees it at the next GTG
![]() Cheers, Phil
