Et tu Lotus?
Power outlet too large... Fixes?
Sorry, but search fails me. The diameter of the 12V. power outlet is too large to hold my GPS plug. I'm sure someone has fixed this but I can't find the thread. Help?
Thanks, Todd |
G-200 Driver
Radio Shack.
G-200 Driver
They sell a generic replacement..... fits right in. There IS a whole thread here somewhere.....
G-200 Driver
#7 (permalink) |
Another option available from Radio Shack is a 2 into 1 adapter that does fit snugly into the Lotus outlet and standard accessory plugs remain tight in. This does not require removal of the original outlet and lets yu use a GPS and radar detector at the same time. Sorry I don't have a picture, if you happen to make it to the rally, I'll show it to you....Dave
#8 (permalink) |
perfututum futūtor
The UK power socket has a slightly larger hole for the plugs which allows the US plugs to wiggle and not fit snugly.
The generic US power outlet replacement from RS will fit directly into the existing hole once you remove the existing socket. You can also get a sleeve adapter that fits and makes the larger UK power outlet more snug like the US one without removing anything.
#9 (permalink) |
I did the RS mod, works great. If your "cupholder" is wrapped in leather you will have to remove the cap on the new one so it snaps in place properly.
05 AS Elise. Tour and Sport Pack. Hard Top.Stage II Exhaust, Sport ecu, Pagid RS 4-2s,Toyo R888's, Shifter Matrix brace, Micro Mirror |
#10 (permalink) |
insert clever title here
Back when I connected my V1 via the power outlet, I found that I could modify the V1's plug to fit better - I unhooked one end of one of the metal contacts, so the end was resting outside the main connector body rather than tucked inside, and this increased the overall diameter enough for a snug fit.
#11 (permalink) |
V Not my picture V
Or for $2.50 get a sleeve that goes over your plug-
https://www.escortradar.com/store/european-adapter.html
Tracy 1996 Porsche 993TT Big news coming @ 3pm onTuesday.....(hopefully). 2008 Toyota FJ Cruiser LOG 29 photos |
#12 (permalink) |
Mods are good for you
Like mentioned above, pick up one of these at Radio Shack and replace the console socket...takes just a few minutes. I installed another in the blank spot on the light panel that was just begging for one.
2008 Solar S240 Exige 2005 Saffron Elise - BOE TVS Supercharger 291WHP w/ EFI Engine Mgmt |
#13 (permalink) |
Alarmed & Dangerous
I used the same one but mounted it here.
#14 (permalink) |
British by extrapolation
Just FYI, instructions are here: How to replace your 12v DC outlet for a better one for the mod to the US spec 12V outlet.
#15 (permalink) |
Anyone have pictures of the wires you tapped into for this mod? My multimeter is busted & I don't feel like driving back into town to buy one. Thanks.
Edit: I'm referring to those of you that added a 2nd outlet, not swapped out the original. |
#16 (permalink) |
Alarmed & Dangerous
Here it is, a tap off of the C2 fuse which is an ignition switched circuit.
Cobra OEM - Alarm, Immobilizer, CDL Emergency Override with warranty Additional Emergency Touch Keys - see link above Brand New Cobra Alarm Remote with warranty Cobra Remote Key Fob Strap Cobra Window Closing Module - Add to your existing Cobra alarm 3 Piece Front Clam Protection Kit with Center Bumper Undertray Removal Tool INFORMATION Improved AC & Heating System Battery Choices & Information Remote Key Fob, Alarm & Immobilizer Programming Light Bulb Conversions 2005 Last edited by TheViper : 07-22-2009 at 04:33 PM. |
#17 (permalink) | |
perfututum futūtor
That's the one. I couldn't find it before.
