Old 10-11-2008, 08:41 AM   #1 (permalink)
Fibreglass Junkie
hackzi's Avatar
Power Source for Boost Gauge
Does anyone know an "easy" power source for a boost gauge? One that doesn't cut out when cranking the engine. Thanks in advance.
'07 Exige S
L&C Motorsports - Parts for Lotus Elise/Exige in Asia
LotusClubSG - Lotus Club of Singapore
hackzi is offline   Reply With Quote
Old 10-11-2008, 08:53 AM   #2 (permalink)
I took radio wire.
Elise 2006, white, Katana
Europa 1969, green, H22A, 194 whp, 1550#
CONFIGTECH.ca / Solidworks
elise/europa is offline   Reply With Quote
Old 10-11-2008, 09:04 AM   #3 (permalink)
Fibreglass Junkie
hackzi's Avatar
But radio gets cut out when cranking the engine ya? I need a power source that doesn't as the Stack gauge I have recommends the use of a suitable power source so their "auto zeroing" feature will work. Otherwise, the gauge might not read accurately according to the installation instructions.
'07 Exige S
Old 10-11-2008, 09:16 AM   #4 (permalink)
Tr4
Tr4's Avatar
Can you run a wire all the way up from the battery? It might be one of the only ways to get a constant source of power
Tr4 is offline   Reply With Quote
Old 10-11-2008, 10:10 AM   #5 (permalink)
disproving HD MTBF daily
charliex's Avatar
Depends what the voltage range it can drop too, you'll probably see as low as 6V at the battery on cranking too.
Black Exige S - http://goth.am 265 Mule / Elan M100 ECU Tuning, http://www.elisetalk.com/forums/showthread.php?t=39660
Arguing with an engineer is like wrestling with a pig in mud. After a while, you realise the pig is enjoying it.
charliex is online now   Reply With Quote
Old 10-11-2008, 01:10 PM   #6 (permalink)
I also would like to know where i can get switched power with out a start drop out. I believe OP has a innovate product to measure boost.
07 Exige S - PhB., TP, TP, LSD, Rear Panel Delete, Custom Magnaflow Exhaust, Custom AEM Intake, 6k HIDs, Schroth 4pt ASM Harnesses
Sh4rkattk is offline   Reply With Quote
Old 11-27-2008, 10:12 AM   #7 (permalink)
Fibreglass Junkie
hackzi's Avatar
Hmm, still a mystery....
'07 Exige S
Old 11-27-2008, 10:46 AM   #8 (permalink)
charliex's Avatar
Its not really possible without adding something to buffer it.
Old 11-27-2008, 05:45 PM   #9 (permalink)
Fibreglass Junkie
hackzi's Avatar
Oh well... mechanical gauges might be the better choice for our cars then...
'07 Exige S
Old 11-27-2008, 09:47 PM   #10 (permalink)
charliex's Avatar
i don't usually need to read the gauges when cranking the engine, but a simple capacitor will in all likelyhood fix it.
Old 11-28-2008, 07:03 AM   #11 (permalink)
Ex-Brit
TheViper's Avatar
Another alternative is if you really want to get crazy is to give it its own small battery power supply Maybe that would work, don't know for sure.
A/C Improvement Modifications
http://www.lotustalk.com/forums/f3/e...ent-mod-59938/
1) Insulate the cockpit from Solar (3M Crystalline Tint) & Convected (insulate sills) heat.
2) Replace evaporator thermostat with an upgraded electronic version to prevent freeze up.
3) Increase airflow into cockpit by removing both driver & passenger side footwell intake panels & blocking 2 outside air intakes in nose.
Old 11-28-2008, 07:30 AM   #12 (permalink)
2/3 hp to the paws.
Simba's Avatar
If you need constant power, there's a distribution block under the dash that goes directly to the battery.
If you need switched, you can tap the ignition switch, though the best way to do it is to run a relay via a separate fuse that is switched by the ignition power.
Old 11-28-2008, 07:37 AM   #13 (permalink)
Ex-Brit
TheViper's Avatar
I believe he is asking for a power supply that does not dip due to voltage drop during cranking rather than a unswitched source.
Old 11-29-2008, 12:32 PM   #14 (permalink)
2/3 hp to the paws.
Simba's Avatar
In that case you'll have to do a relay to the battery (or distribution junction) that is flipped by ignition power.
I do this on all my cars, and the Defi boost gauge in the Elise is quite happy with that arrangement.
It will dip slightly when the starter runs, no way around that short of rigging up a capacitor, but no gauge should be that picky.
Old 11-29-2008, 12:40 PM   #15 (permalink)
charliex's Avatar
It drops to about 6V, if theres a 12V to 5V regulator in the gauge, it'll probably power off/reset.
HTML code is On
