Old 06-19-2009, 05:14 PM   #1 (permalink)
walis's Avatar
Power window
just curiuos if anybody have this problem with the power window switch on passenger side..it wont go up dont know if its loose wiring in the switch or motor.dont think its the track cuz sometimes it will go up some times it doesnt..(06 exige) how hard is it to open up the door panel?
thanks in advanced
walis is offline   Reply With Quote
Old 06-19-2009, 05:42 PM   #2 (permalink)
Alarmed & Dangerous
TheViper's Avatar
From recollection there a some screws, velcro and plastic retainers, go slowly and it will become clear.
Old 06-19-2009, 09:12 PM   #3 (permalink)
Overlander23's Avatar
My passenger side switch went bad (bad contacts.) If pressed at the right angle it would work, but it was getting progressively worse. It was replaced under warranty.
2005 Lotus Elise (Type 25 clone, LSS, Touring, Supercharged)
1970 Austin Mini Cooper, 1971 Series IIA 88" Land Rover, 1999 Land Rover Range Rover 4.6 HSE Callaway #071
Overlander23 is offline   Reply With Quote
Old 06-19-2009, 10:14 PM   #4 (permalink)
buzzy's Avatar
Images: 10
It's very easy to take the door panel off. Remove the 4 hex bolts and one expanding plastic screw and its just velcro'ed in place.
You'll be able to reseat the switch on the panel to see if that's the issue. You can also remove the switch from the door panel and try it on it's own.
Gone to talk about lotus somewhere else.com
buzzy is offline   Reply With Quote
Old 06-20-2009, 06:20 AM   #5 (permalink)
walis's Avatar
thanks guys...
Old 06-24-2009, 04:20 PM   #6 (permalink)
I approve this message
skibum's Avatar
I had the same issue on my 06 Exige. Dealer replaced motor under warranty.
2006 Exige - Solar Yellow BWR S/C - Tillet B5 CF seats - Arqray SS single - PPE Header & sport cat - TR Motorsports F1 w/R888's - 1934#
2004 s2000 - 378 whp 295 trq
2005 Mini Cooper S
2008 Honda Fit - 35mpg y0!
1965 Austin Mini w/ vtec
skibum is offline   Reply With Quote
