#41 (permalink) |
really light stuff
![]() Join Date: Jul 2003
Batteries + brackets out this morning. Sorry for the delay. Watch for UPS.
07 SY Exige S Really Light Stuff Intercooler . RLS Tubes . RLS Water/Methanol Injection . RLS 3.0" Pulley . RLS Wing Plates . RLS CF Window Panel |
#42 (permalink) | |
DENNAB
Why the switch in part numbers for the battery cable? Is it ok if I ordered the 112705 - 12" Lead Battery Cable, 6 Ga, Top Post?
#43 (permalink) | |
really light stuff
The battery cable that you ordered is made for a top post battery, so if you intend to use it with the Odyssey battery you will need to clip off the top post connector from the battery cable that you ordered, and you will replace it with a lug to fit the Odyssey. Just a little extra work. The battery cable that is listed now is ready to go: it already has the proper lug on each end.
#44 (permalink) |
NOT ßANNED!
Just got it in, looks good, just have to work on cleaning the way I connected it up.
#45 (permalink) |
Elise Driver
yea looks good.i think i need to buy one back from thomas.i like the red anodizing.i still have the prototype in my car.did you try mounting the battery lugs to the battery with some 6mil screws?thats what i did on mine.i found a smaller positive boot for it too.there is a pic of it on the other thread i started.i didnt have the pc680 post adapters.
rls west~nci motor sports fabrication |
#46 (permalink) | |
NOT ßANNED!
I swapped over what I had on my giant thing of a battery, used posts from a post kit, and screwed some bolts tight.
#47 (permalink) |
Elise Driver
the pic doesnt have the positive boot installed.just so we are on the same page here.i just used some small button head 6 mil screws to hold the battery lugs to the postsAttachment 122647
#49 (permalink) |
thats a beautiful setup, when my braille goes dead I'll get this and batt from you. They want $146 + tax just for the battery locally! good deal you got
06 Exige CO BWRized 05 Civic "Special Edition" 05 Elise CO, Trim shop interior and other things...SOLD |
#51 (permalink) |
really light stuff
I'll post some. New batch will be back from anodizer Monday / Tuesday, ready to ship. Batteries are in stock too.
#52 (permalink) |
DENNAB
What's everyone using for screws to hold the switch to it's face plate? It didn't come with any and the techies at delcity are gone for the weekend. :/ There also weren't any instructions or any markings on the switch so I'm not sure which terminal is for the battery and which is for the negative terminal on the car.
#53 (permalink) |
really light stuff
You can use double sided tape. With the cutoff switch, you can remove and replace the plastic gates at the four sides to suit the positioning of your cables.
#55 (permalink) |
Solder slugs
just a small point of interest on the solder slugs. Make sure you take penty of time to push the cable in.
If you go in too fast the solder will splash out. wear gloves as the cable heats up real nice. You'll want to hold the cable in as the solder sets up. They make alot better connections than the crimp type. If you wanna use the solder slugs with the copper eyelet types, I've had success using two slugs.
Yes, that's very nice, Thank You.![]() ![]() ![]()
#56 (permalink) |
really light stuff
Battery brackets, batteries, and cutoff switches are all boxed and ready to ship. PM to order.
#59 (permalink) |
cog
Haven't seen any posts comparing this to Sector's Xtender.
Looks like they both fit the PC680 and are price competitive if you add in the cost of the switch. Xtender: 79.99 RLS: 54.00 + 33.00 = 87.00 The RLS comes in red. Am I missing anything? -chris |
#60 (permalink) |
Elise Driver
the big difference for me is that the nci bracket holds the battery on all for sides.uses both stock mounting points.the sector one wedges the battery in the corner.i didnt like that too much so i built this one.i read the story about the guy that totaled his rear clam when his battery came loose.so i wanted my battery very secure.
| Display Modes | |
