#41 (permalink) |
the devil's advocate...
charlie, if you could check whatthe bit map patterns are for the progressive shift lights that would be excellent... I am already started writing the code for the translator but need to know what a few of the bits do... here is the known mapping:
Code:
400h 8 AA BB CC DD EE FF GG HH AA -----------------------> adjusted speed ~= d(XXh)-11d (61h-->97-11=86 mph) BB --------------------> unused (always 00) CC DD --------------> tach rpms [d(CCh)*256]+d(DDh) 06 D2 = 1746 rpm EE -----------> fuel level (00=empty, FF=full) FF --------> engine temperature ~= d(XXh)-14d (D0-->208-14=194F) GG -----> MIL (04-oil, 02-engine, 01-shift) HH --> unused (always 00) bitmask patterns: 01 00000001 shift light 02 00000010 engine light 04 00000100 oil light 08 00001000 10 00010000 20 00100000 40 01000000 80 10000000 Finally the text frame only shows 7 bytes being able to be sent... have you ever seen a message on the cluster that is bigger than 7 bytes and if so can you post a quick trace. thanks. |
#42 (permalink) |
2zz exorcism complete
My measurments showed:
AA -> speed (mph * 1.5) FF -> temp (degs C * 1.6 + 64) It could be coincidence that my speedo was inaccurate by the difference between kph and (mph * 1.5). I believe the temp calculation is accurate - the 1.6 multiplier in essence converts from dec to hex.
-2ZZ +K24 +150hp +118tq +7mpg +LSD -30lbs -CoG +F.bias |
#43 (permalink) |
OSX Black hat
speed is just km/h
rob i'll work on the bitfields.
#44 (permalink) |
To get my dash to read 100 mph I had to send 150 decimal to the cluster. Sending the speed in kph makes it over-read by 8%. The two dashes I tested had errors of 7.5% and 8% as measured by GPS, so I figured the 8% was a standard Lotus speedometer over-reading fudge factor.
#45 (permalink) |
OSX Black hat
it is, the error is set in the dash.
#46 (permalink) |
mpsalm slayer
Amazing, isn't it?
2005 Ardent red Elise, Stage 2 exhaust, Sport pack, Touring pack, Hard top, starshield, driving lights, Leather center console with tan leather shift boot, Handbrake cover, Custom painted engine cover and a/c surround, Center console re-enforcement.......I think that's all. Lexus ES300 Suzuki RF900R (mint) |
#47 (permalink) |
OSX Black hat
the 0x401 text frame is fixed size, the mesages are really short, like FAULT, LH TYRE(or something like that, i'd have to go check the actual text)
there is more data in the can stream than there was originally. remember though the localised version of the speed/temps for 08+ is set in the can frame, unlike previous years where its fixed to metric and translated by the cluster you can alternate it obviously.
#48 (permalink) |
OSX Black hat
Current strings are
"LTC OFF " "LTC ON " " LTC " " % Slip" "Launch " "LF LOW " "RF LOW " "LR LOW " "RR LOW " "TPMS " "FAULT " my guess is with the spacing they're not clearing the display and overwriting it with spaces instead, so the if the message is smaller than the last it has to be padded with spaces, thats typical with LCD's
#49 (permalink) |
OSX Black hat
Updated my 08 cluster wiring diagram.
#50 (permalink) |
OSX Black hat
Still a work in progress
Code:
unsigned char m_Speed1; /// Instrument speed unsigned char m_Speed2; /// Mileage speed unsigned short m_RPM; /// Engine speed unsigned char m_Fuel; /// Fuel level, not desloshed unsigned char m_Coolant; /// Coolant temp unsigned char m_CAN08_BFa; /// shift lights, mil, oil pressure, tc, config unsigned char m_CAN08_BFb; /// service, coolant overtemp, fog warning Code:
m_CAN08_BFa unsigned char m_Shift:3; /// shift lights unsigned char m_MIL:1; /// fault unsigned char m_Oil:1; /// oil warning unsigned char m_TC:1; /// TC unsigned char m_Config:1; /// localisation bit Code:
m_CAN08_BFb unsigned char m_Service:1; /// service light unsigned char m_NA:3; unsigned char m_CoolantWarn:1; /// over temperature unsigned char m_FogLights:1; /// fog light open circuit
Black Exige S - http://goth.am 265 Mule / Elan M100.ECU Tuning, http://www.elisetalk.com/forums/showthread.php?t=39660 West Coast Lotus Meet - Las Vegas - November 6-9 2009 http://www.westcoastlotus.com/ Last edited by charliex : 01-16-2009 at 11:15 AM. |
#51 (permalink) |
Code:
2005 2008 Chng Color Function C7 B7 ** U CANL C1 A7 ** R CANH A2 A2 BP GND B11 B11 PW Lightsbuzzer C5 A10 ** RO Illum B6 B6 RO Illum B9 B9 RW Illum switch A9 A9 UW Main beam A8 A8 RY Rearfog B12 B12 BP SRS A10 A4 ** NY Alt B3 B3 BY ABS B1 B1 BW Brake B4 B4 BP Seat B8 B8 GR Fuse C3 A5 A5 G Ign power A12 A12 GW Indicator A11 A11 GR Indicator A3 A3 P Fuse 8 B7 A6 ** PK Alarm
-2ZZ +K24 +150hp +118tq +7mpg +LSD -30lbs -CoG +F.bias Last edited by dstevens : 01-16-2009 at 07:01 PM. |
#52 (permalink) |
OSX Black hat
they're rows.
the 08 drops one. i posted a clearer version of the 2005-2007 diagram, i marked some of the changes with *'s, here it is again
Black Exige S - http://goth.am 265 Mule / Elan M100.ECU Tuning, http://www.elisetalk.com/forums/showthread.php?t=39660 West Coast Lotus Meet - Las Vegas - November 6-9 2009 http://www.westcoastlotus.com/ Last edited by charliex : 01-16-2009 at 12:45 PM. Reason: marked as 2005-2007 diagram |
#53 (permalink) |
I've corrected my initial diagram - it seems there only 5 wiring changes to make.
I've got a 2008 dash on the way. Next week is full but I should be able to look at it starting on the 26th.
#54 (permalink) | |
#55 (permalink) | |
incidentally one more question: Code:
unsigned char m_Speed2; /// Mileage speed |
#56 (permalink) |
The 05 cluster increments the odometer by integrating speed over time. If you get the speed accurate then the odometer under reads - which shows me the over-speed is deliberate from Lotus.
Also with the 08 cluster a 180 mph speedo is a waste of time when the maximum it can ever show is 158 mph (255 kph). I guess that will be a little higher with the inaccuracy - about 170 mph.
#57 (permalink) |
OSX Black hat
The second speed byte is because the 08 cluster can send speed in km/h or mph since the cluster doesn't necessarily know which its using, it uses the second byte which is fixed at km/h
The 08 cluster can show 180MPH too, so its not a waste of time, well at least for those that can reach/ exceed that speed ![]()
#58 (permalink) |
can it kill me?
Could any of you tell me the weight of the 06 and 08 cluster it's self? I'm wondering because it seems like an ultra thin & light LCD could look almost the same but save a little weight. As well as give you a load of extra functionality.
06 Chili Red Exige |
#59 (permalink) | |
2006 Lotus Sport Elise #4 of 50 |
#60 (permalink) |
Dan D
Charlie, Rob, et al... Good job gentlemen!!! Can you please PM me when you have this all figured out? I would love to convert my 07 cluster, and will have Qais install it for me.
07 Exige S 265: GG, Track Pack, V1, RV Camera, S111 CF roof and splitter, 4.5-lb Voltphreaks battery, 10-lb Von Hep Exhaust, Green filter, 265 crank hp +/-, Volk TE 37 Wheels, RTDbrace, Scroth 6-point ASM harnesses, Innovative Motor Mounts, Saiku Michi Catch Cans. To come: IC fans, headers, and sport cat. 1955 lbs total weight (est w/tank half full) 05 Elise: Storm Titanium, Sport, Touring, Stage II (SOLD) (May '05 - Sept '06) |
