Old 09-02-2009, 10:55 PM   #1 (permalink)
Right/left blinkers only come on when hazard button is down - maybe wiring problem?
Fascinating phenomina on my 05 Elise...
If the hazard button is up and not lit, the blinkers (ie. right/left signals and blinker tell tale) will not work.
If the hazard button is down and lit, the blinkers will work fine and the tell tale will appropriately INDEPENDENTLY blink if a turn is signaled with the lever around on the steering column.
I have _no_ hazards functionality where both blinkers SIMULTANEOUSLY blink.
Based on this description, what do you think the wiring problem might be?
NorCal is offline   Reply With Quote
Old 09-03-2009, 04:21 AM   #2 (permalink)
Alarmed & Dangerous
TheViper's Avatar
Fuse F6 has blown.
Cheers,
Old 09-03-2009, 04:33 PM   #3 (permalink)
Thank you so much! It was actually F9 (the hazards fuse) that had blown, but you got me looking in the right place. Problem solved!
Old 09-03-2009, 05:59 PM   #4 (permalink)
perfututum futūtor
RoadDad's Avatar
Thank you so much! It was actually F9...
That's what he said.
You're just reading it upside down.
Me... I don't need to.
Bite me." -Randy
Old 09-03-2009, 06:04 PM   #5 (permalink)
Alarmed & Dangerous
TheViper's Avatar
The funny thing is from the symptoms "described" it could be neither F6 or F9
Old 09-03-2009, 06:44 PM   #6 (permalink)
perfututum futūtor
RoadDad's Avatar
I figured if the OP had said "fuse F6 is fine" you would have directed him to F9 next.
Bite me." -Randy
Old 10-25-2009, 03:19 PM   #7 (permalink)
chemo's Avatar
I have the same problem. But fuse 6 and 9 are fine. Replaced them and still have the problem.
SMB
chemo is offline   Reply With Quote
Old 10-26-2009, 01:07 AM   #8 (permalink)
SMB
I had this on my car, it's the trim around the button. A few quick smacks to the side of the gear stick and it sorts itself out
Neil.
-Neil- is offline   Reply With Quote
