Chris
Sometimes the Immobilizer is still on after unlocking, sometimes its not?
Hello
I've been reading a little bit on the alarms for these cars and it seems that it is possible to program the alarm system so that pressing the big "A" button on the fob arms the alarm but does not activate the immobilizer. It is also of course possible that both alarm and immobilizer functions are activated when pressing the A button. But both of these programming settings can't be switching arbitrarily unless I change the programming with the alarm code, right? My problem is that sometimes when unlocking the car and getting in, the immobilizer light is still flashing red and I need to press the A button once more so I can start the car. Other times, both alarm and immobilizer are deactivated together at once. Is this a wiring/battery issue, or am I doing something that changes the alarm behavior? (I havent messed with any programming) One thought I have is that it has to do with how I use the fob to lock the car. Sometimes I have to press the A button a few times before I see the door pins move down to the lock position. I would press the button and the parking lights would flash as if the car were locked, but the doors pins were still up. Is this a problem that is contributing to the weird behavior of the alarm? Also, what is the function of the interior lamp being in the down vs up position? I've read that this may cause the alarm to go off randomly/intermittently without provocation? I'm asking because my landlord called me telling me my alarm was going off for the "last hour" and did't say if it was intermittent or just continuous blaring. But it didn't seem like there was a problem when I went to check on the car. I have it now locked via keys without the alarm function Last edited by 6i9 : 09-11-2009 at 08:41 AM. |
#2 (permalink) | |
Alarmed & Dangerous
Cobra OEM - Alarm, Immobilizer, CDL Emergency Override with warranty Additional Emergency Touch Keys - see link above Brand New Cobra Alarm Remote with warranty Cobra Remote Key Fob Strap Cobra Window Closing Module - Add to your existing Cobra alarm 3 Piece Front Clam Protection Kit with Center Bumper Undertray Removal Tool INFORMATION Improved AC & Heating System Battery Choices & Information Remote Key Fob, Alarm & Immobilizer Programming Light Bulb Conversions 2005 Last edited by TheViper : 09-11-2009 at 09:01 AM. |
Chris
So to get the arming/lock function sync'd with the immobilizer function, I should press the A button within a minute after parking? That way, the door pins lock, alarm is armed, and the immobilizer is active with the first button press. This is assuming I am under the passive immobilizer programming, correct?
In order for the immobilizer to only activate whenever i push the A button, I need to reprogram the immobilizer to active mode (no longer passive) that doesn't activate after a minute on its own? |
#4 (permalink) | |
Alarmed & Dangerous
