really light stuff
![]() Join Date: Jul 2003
Testing MFRU multi function relay unit
A strange starting problem has appeared... '07 Exige S...
I've done all of the usual checks: battery is good, connections are good, grounds between engine and chassis are good, etc. Here is what happens: I turn the key to the on position, press the keyfob button to disable the alarm... fuel pump primes for a few seconds... when I press the start button, I hear a solid "click" from the engine bay (seems to be the starter solenoid)... then nothing. No starter groan, nothing but one solid click. Since the fuel pump is working, doesn't appear to be the immobilizer or the inertia switch. Since the solenoid is working, doesn't appear to be the immobilizer. Pulled the multi function relay unit... is there any way to test it for obvious faults? Any other thoughts? I have researched this thoroughly here on LT for the usual suspects. The battery voltage only drops to about 12.4 volts when I push the start button. I've tried two different batteries, even jumped the battery with another car.
07 SY Exige S Really Light Stuff Intercooler . RLS Tubes . RLS Water/Methanol Injection . RLS 3.0" Pulley . RLS Wing Plates . RLS CF Window Panel |
OSX Black hat
since you didn't list it, i'll say check the fuses, theough i'm guesing you did that.
i'll look up the mrfu circuit see what the pins are if no else gets to it before i do, i've got 3 people ahead ![]()
#3 (permalink) | |
really light stuff
You are correct sir, checked each fuse in the forward fuse bank and the engine bay fuse banks (2). Also didn't mention that I turned over the engine by hand, it is turning over normally. I appreciate your help Charlie.
Alarmed & Dangerous
If it's the starter solenoid that you are hearing then that infers the starter relay is working. I would check the connections at the starter motor, especially the ground. A high resistance battery connection could also be responsible.
OSX Black hat
Here are the diagrams, first page has the starter via the immobiliser
RMC1/7 is VE+ Rear stud RMC1/5 is the starter energise. So 7 is VE+ ____/ ______ starter RMC2/6 is the immobiliser RMC2/4 is the ecu control IIMOB 6, 6 ----[] --- 4 ECU LG2 control
really light stuff
Thank you Charlie.
Michael: the only connections that I can see at the starter are: 1) two large red cables, one is perhaps 6 gauge and the other is perhaps 4 gauge, both mounted to the same copper post... and 2) a very small black wire (with white stripe as I recall) that goes into a connector at the starter, in close proximity to the copper post but electrically isolated of course. Wouldn't the starter ground through its body into the transmission? If there is a separate ground, I cannot see it from beneath the car.
#7 (permalink) |
Alarmed & Dangerous
You are right, 3 cables:
Red 20mm from battery Red 20mm looped to alternator Black 2mm to start relay. Seems to me that if all fuses are OK..... Battery is OK..... Starter Solinoid is operating (check the click you hear is not the Start Relay.... Makes me think its the starter or if the Start Relay is clicking then the Solinoid is suspect too)Michael
#8 (permalink) | |
really light stuff
The car has never hinted at a starter problem, and has been sitting in heated storage for a couple of months... this was a recent attempt to start the car that alerted me to the problem. Original battery (Exide) was low, charged it, same symptoms... replaced w/ a new Odyssey 680 same symptoms... charged 680 overnight, same symptoms... just one click. P.S. Free Exide battery, pick up only... ![]()
#9 (permalink) |
really light stuff
P.P.S. Starter appears to be a true nightmare to replace... anyone done it? What's involved? (I haven't convinced myself it is the problem yet).
#10 (permalink) |
Alarmed & Dangerous
Do a "Load" test on the battery:
If the battery's state-of-charge is at 75% or higher, then load test the battery by : Turn the headlights on high beam for five minutes, DURING the load test, the voltage on a good battery will NOT drop below 9.7 volts with the electrolyte at 80 degrees F (26.7 degrees C). [If the electrolyte is above 80 degrees F, add .1 volt for every 10 degrees above 80 until you reach 100 degrees. If below 80 degrees F, subtract .1 volt for every 10 degrees until 40 degrees.] After the load is removed, wait five minutes and the battery should "bounce back" to the 50% state-of-charge level or above. If the battery drops below minimum test voltage, does not bounce back, or will not start the engine, then you should replace it. If the battery passes this test, you should recharge it to restore it to peak performance.
#11 (permalink) |
2/3 hp to the paws.
If the battery is low or otherwise toast, you'll generally hear a series of clicks from the solenoid as you hold down the start button, not just one.
My guess is your starter is done. Whack it with a hammer and see if it comes to life, if so there's a dead spot on the armature. |
#12 (permalink) | |
One other thought would be to check for a grounding strap between the chassis and the engine/trans. assembly and make sure it is clean and secure. Again, I haven't looked for one on my car, but just about every car I have seen has one. A bad connection at the grounding strap can cause the symptoms you are describing. If it is not making good contact to ground there will not be enough juice to spin the starter motor, yet there will be enough to make the solenoid click. Last edited by tesprit : 01-26-2009 at 05:33 PM. |
#13 (permalink) |
HaHa....Ive seen this problem similar to this on an ExigeS and it had me stumped for 2 weeks. I changed starter...a real pita on the supercharged car...removed the clam and pinned out the entire wiring harness. It ended up being an immobilizer problem. I can't remember which wire(they are all black) but there was supposed to be 12 volts key on but there wasn't....I jumped 12v to the wire and it blew a couple fuses up front...replaced them and the worked fine. This whole problem occurred after disconnecting the battery.
#14 (permalink) | |
Alarmed & Dangerous
The only thing, in this case is, that the fuel pump is priming & the starter relay or solenoid is active, therefore it does not seem to be the immobilizer.
Michael Quote:
#16 (permalink) |
OSX Black hat
from casey's description i'd hazard a guess at RMC2/6 on the first sheet i posted.
#18 (permalink) |
really light stuff
I had an accomplice press the starter button while I held my head perilously close to the starter... the single click is definitely the sound of the solenoid.
So I should be looking at the immobilizer? My understanding was that the fuel pump and the solenoid action ruled that out, but perhaps not?
#19 (permalink) | |
really light stuff
#20 (permalink) |
OSX Black hat
yeah i have it, i'm pretty sure its that one though, thats the engergise for the starter.
