Old 01-26-2009, 07:03 PM   #21 (permalink)
OSX Black hat
charliex's Avatar
immo 5 and 6 are the starter switch to starter relay.
so its IMMO-6 would be the deadlock for the starter switch at IMMO-5, they're listed in that first sheet.
if you get an on/off reading off MFRC 7 when the starter is depressed that should mean its ok.
RMC1/5 is where the output to feed the starter is.
Old 01-26-2009, 07:15 PM   #22 (permalink)
Alarmed & Dangerous
TheViper's Avatar
Jumper out these two immobilizer plug pins on the female side of this plug for the fuel pump and starter, but am doubtful (hope i'm wrong).
Old 01-26-2009, 07:48 PM   #23 (permalink)
Casey's Avatar
Put a meter on the starter soleniod wire and have someone hit the starter button.....I know it's bitch to get in there
Casey is offline   Reply With Quote
Old 01-26-2009, 08:18 PM   #24 (permalink)
really light stuff
Thomasio's Avatar
I think that the single click that others are referring to may have been the relay sound. When I say "single click", technically the relay is making a click at the same time that the solenoid is making the loud click.
A few minutes ago I tried jumping the immobilizer, and achieved the same results that I've been having all along...
At this point I'm 90% certain that it is the starter and/or solenoid. Looks like it is time to ship her off to FVMC for a warranty repair.
I'm just happy it is winter in the midwest, else I'd be less amused than I am.
07 SY Exige S
Old 01-26-2009, 08:20 PM   #25 (permalink)
really light stuff
Thomasio's Avatar
P.S. Thanks to everyone for their help... Charlie, Michael, Casey... I really appreciate your time and suggestions.
07 SY Exige S
Old 01-27-2009, 05:14 AM   #26 (permalink)
Alarmed & Dangerous
TheViper's Avatar
Sorry you didn't find or fix the problem but after you do, perhaps you can repost the exact cause.
Good luck,
Old 01-27-2009, 08:59 AM   #27 (permalink)
OSX Black hat
charliex's Avatar
did you measure the voltage on the starter/out of of the mfrc ?
Old 01-27-2009, 09:53 AM   #28 (permalink)
really light stuff
Thomasio's Avatar
Not yet, will do that.
07 SY Exige S
Old 01-27-2009, 11:05 AM   #29 (permalink)
ZAMMY
to actually test the starter, disconnect the small wire on the starter solenoid.
when you jumper the terminal you disconnected the small wire from, to the big terminal on the starter, the starter should crank.
if it does not, then it IS the starter at fault.
make sure it's out of gear when you do this.
good luck, sam
Old 01-27-2009, 11:12 AM   #30 (permalink)
tesprit's Avatar
good luck, sam
+1
Good advice Sam!
(I must be getting old--totally forgot about trying that procedure )
Old 01-27-2009, 11:30 AM   #31 (permalink)
ads_green's Avatar
Fuel pump will still prime even when the car is immobilised
ads_green is online now   Reply With Quote
Old 01-27-2009, 11:42 AM   #32 (permalink)
Alarmed & Dangerous
TheViper's Avatar
How can that be, it's open circuit?
Old 02-07-2009, 04:15 PM   #33 (permalink)
2/3 hp to the paws.
Simba's Avatar
No, it won't. Power goes from the fuel pump relay, to the inertia switch, to the immobilizer, to the fuel pump. If the immobilizer is open, no fuel pump.
This is one of the reasons the current at the fuel pump sucks and most people elect to run another relay in the system.
Old 02-07-2009, 06:12 PM   #34 (permalink)
Alarmed & Dangerous
TheViper's Avatar
"Current sucks"..interesting..."most people"..who are they?
Old 02-07-2009, 07:52 PM   #35 (permalink)
2/3 hp to the paws.
Simba's Avatar
A bunch of people who have done forced induction of some type and run into pressure issues.
The pump wiring is of a very light gauge which does not conduct current particularly well, and goes through a lot of circuits before it gets to the pump.
Old 02-07-2009, 08:04 PM   #36 (permalink)
Alarmed & Dangerous
TheViper's Avatar
Not true, the wiring is sufficient for the pump and only goes though simple contacts, no resistive loads.
Old 02-07-2009, 08:08 PM   #37 (permalink)
2/3 hp to the paws.
Simba's Avatar
I saw a gain of several psi at higher revs/boost going to thicker wire and a secondary relay. That implies a significant increase in current at the pump.
It goes through several relays which are, to a degree, resistive.
Old 02-07-2009, 08:36 PM   #38 (permalink)
Alarmed & Dangerous
TheViper's Avatar
The wiring for an electrical device is sized according to it's current draw & voltage drop, are you saying that the pump wiring is undersized?
Old 02-08-2009, 10:56 AM   #39 (permalink)
OSX Black hat
charliex's Avatar
Are you sure you weren't seeing the effects of a poor ground vs better ground ?
Old 02-08-2009, 11:51 AM   #40 (permalink)
2/3 hp to the paws.
Simba's Avatar
For applications that are moving a lot more fuel, yes.
I tried a more robust ground as well, but didn't see any real improvement.
One of these days when I have time, I'll take some ammeter readings of the pump at a set pressure with the stock versus larger gauge wiring.
